Pete Cornish - G2 Guts, Schematic, Layout (from Tracer's Fund)  [traced]
Has thanked: 183 times
Been thanked: 468 times
culturejam wrote: Eh, I think I get that.
So maybe we should all be doing that to help reduce ground loop issues? :scratch:
I dunno... have you ever had a ground loop in a pedal? I haven't. I think this is why some people don't attach a ground wire to the output jack and instead let it get the connection through the chassis. Personally, I try to return everything to the input jack ground, or if it's an isolated jack, use a chassis star ground point.
Duckman
Has thanked: 320 times
Been thanked: 134 times
Post by Duckman »
John Lyons wrote:C24 is 4.7uf . Where are you seeing the .01, am I blind?
:lol: :lol: this explain the "missing cap" :lol: :lol: My fault :slap:
"My" C24 is in the layout that Dirk_Hendrik posted before in this thread (page 3 - post 18) Any way, you can see the cap in this picture https://www.freestompboxes.org/download/ ... &mode=view (If it's wrong to repost the layout, please moderators do your job and forgive me)
Cornish_G2.pdf
(15.14 KiB) Downloaded 999 times
John Lyons
Been thanked: 30 times
Post by John Lyons »
Ah! Ok, I see now. I didn't think to look at dirk's as well.
John
Visualdistortion
my favorite amplifier: Laney
Completed builds: Many...
Been thanked: 23 times
Post by Visualdistortion »
Thanks a lot for make this!!! You rock guys!
Any PCB(S) (buffer and effect) has been made for test this awesome pedal?
I wanna make it
I wanna make it wit chu
(again and again and again)
French... sorry ;)
Been thanked: 909 times
Visualdistortion wrote:Thanks a lot for make this!!! You rock guys!
http://www.madbeanpedals.com/projects/index.html
#9 Darkside
Pawel
Visualdistortion
Thanks :wink: So the only change is 47KA -> to 470KA?
I wanna make it
French... sorry ;)
Visualdistortion
I can't edit so:
Few capacitors don't have been listed on the DH pdf: C14, C17, C19, C23 and C3 is listed 2 times
I wanna make it
French... sorry ;)
Tube2stomp
Post by Tube2stomp »
Sound wise I never had any interest in any Cornish pedal, let alone a BM.
But still you guys deserve respect and thumbs up for the effort, so in the words J. Peterman:
"Kudos, Elaine, on a job... done."
:lol:
Btw, bootstrapping the input impedance does work, but it depends a lot on the feedback drive level (need to have a gain as close as posible to 1) and the cap size (because it makes the impedance gradual).
joelap
Post by joelap »
Great job guys. Noticed the board says "P2/G2" on it. Obviously their topologies must be the same between those two pedals, any idea where the main sonic differences could lie? Big fan of Gilmour's tone with the P2.
mictester
Has thanked: 32 times
Been thanked: 845 times
Post by mictester »
soulsonic wrote: Personally, I try to return everything to the input jack ground, or if it's an isolated jack, use a chassis star ground point.
I always go for a star point because I almost always use insulated sockets. I often find that a convenient star point is a ring tag around the threads of the footswitch. I have only ever used screened lead inside an effect when there were highly amplified signals that I needed to keep apart - never to try to prevent hum pickup.
ryanuk
Has thanked: 29 times
Been thanked: 28 times
Post by ryanuk »
Visualdistortion wrote:Thanks :wink: So the only change is 47KA -> to 470KA?
Madbean answered earlier in the thread - 47KA
However, Dirk H's schem - who degooped the pedal - says 470KA.
Can this be clarified please?
RyUK
MWichni
my favorite amplifier: HI-WATT DR103
Completed builds: Neo-Vibe, EH Big Muff Ram's Head, MXR Dynacomp, Demeter Compulator, Bk Butler Tube Driver, MXR Distortion +, Maxon OD880, MXR Phase 45, ProCo Rat, Colorsound Power Boost, BOSS CE-2, Rebote Delay 2.5, EH Electric Mistress, Fuzz Face, Tycobrahe Octavia, EH Pulsar. Custom made cabinet with 2x12" Celestion Vintage 30's.
Been thanked: 57 times
Post by MWichni »
RyUK
Hi guys, the correct value of the sustain pot is 47kA. Dirk's schematic has there an error. He changed that in another pdf but I don't know why it isn't uploaded in this thread. If you want to build one you can use madbean document which is 100% correct.
Regards,
Mariusz.
Has thanked: 232 times
Been thanked: 888 times
MWichni wrote:Hi guys, the correct value of the sustain pot is 47kA. Dirk's schematic has there an error. He changed that in another pdf but I don't know why it isn't uploaded in this thread. If you want to build one you can use madbean document which is 100% correct.
Regards,
Mariusz.
47k indeed. Thanks Mariusz
MWichni
Post by MWichni »
Regards,
Mariusz.
No problem. Thank you for the tracing and degooping! :applause:
Regards.
Oliphaunt
Post by Oliphaunt »
I breadboarded the input buffer section of the G2 today and really like it. I can't claim to understand how it works though and would love if anyone wants to chime in with information about it.
TheLemon
Post by TheLemon »
Oliphaunt wrote:I breadboarded the input buffer section of the G2 today and really like it. I can't claim to understand how it works though and would love if anyone wants to chime in with information about it.
I'm in the same situation. I would like to know this as well.
Look up "Bootstrap Follower". That's what the buffer is. It's just a standard simple emitter follower. The input is bootstrapped, which gives it a higher input impedance than you'd normally get with the values used. Nothing special about it. A simple opamp buffer would have better performance.
mictester
Post by mictester »
soulsonic wrote: A simple opamp buffer would have better performance.
A simple op-amp buffer would have much better performance!
True.
But that density of PCB layouting, combined with the high level of the technology used in an opamp, might be too much for mr Cornish.
bear in mind the PCB layouts from the G2 are routed in a style I do know only from early 1970's elektor magazine. Some here call that style artwork by the way. I prefer to call it lack of progress. Thank the programmers for CAD. (not to be mixed with autorouting!)
Duckman
Post by Duckman »
Maybe he's not looking for a better perfomance... just that performance, or... just don't wanna trace a new board! :lol:
