Catalinbread - Formula No. 5  [traced]
roseblood11
Has thanked: 366 times
Been thanked: 314 times
Post by roseblood11 »
BUMP
matt239
Has thanked: 60 times
Been thanked: 5 times
Post by matt239 »
roseblood11 wrote:I built that years ago...
The Formula No.55 is a completely different circuit
What's different? (Formula 55)
Howard says it follows the Fender circuit "exactly."
Is it still mu-amps?
Or now single jfets?
Or mosfets?
Sounds good.
Seems to have improved low gain sounds..
roseblood11
So many great Catalinbread pedals never got traced:
Formula 55
Formula 5F6
Karma Suture
coltonius
Post by coltonius »
Sorry for the necro-bump. I mostly lurk and hardly ever (never) post, but I thought this was worth noting: the Formula 5F6 has been traced! I sent mine over to Robert at PedalPCB, who now sells a PCB. As some might have guessed, the layout is identical to the DLS MKIII- and indeed it uses the same PCB with the same S. Bass & S. Lead designations inside.
Carry on!
KarenColumbo
Post by KarenColumbo »
great news indeed! Been waiting for this one and tried to build one by ear - The AMZ "Tweed Stack" almost got me in the zone, so at least i guessed right :) Ordered a PCB from GuitarPCB and BB'd it using the schematic provided there while waiting for the postman. Since it uses MPF4393 which are not readily available here in good old Austria I substituted MPF102 and some of my trusty 2N5457, will try with NTE457, though. As usual the GuitarPro demo video has a killer sound, the "original" ain't - but that's real life I guess.
matt239
Post by matt239 »
Or mosfets?
Sounds good.
Formula 55
BUMP.
Seiche
Has thanked: 231 times
Been thanked: 189 times
Post by Seiche »
What are you trying to achieve? If you find info or gutshots, post it here. If you're interested in tracing it, buy one, trace it, sell it, post it here. This space depends on it's members to contribute.
simply bumping the topic and saying "schematic please" will not achieve anything.
mpackard
Post by mpackard »
Ive built this one and I think my transistors are facing the wrong way, but I still have a pedal that sounds half decent. Is it possible that I have indeed put the transistors back to front (following the roseblood11 layout the flat side of my transistors face towards the diode).
Any thoughts?
