Catalinbread - Formula No. 5 [traced]
Hmmm...I just realized something. I have the resistor wired to the top two lugs of the spst switch. That means when the switch is DOWN the 2m2 resistor is in place making it sound like the original trace.
So I'm wondering what is going on when the 2m2 ISN'T in the circuit. I must have screwed up the wiring on the switch or something.
- joeboo88
Shiner man i forgot to pull the resistor out, so i can make a comparison. (i'll do that now)
Nocelli wondered wht trannies you used. I used 2 j201's and
2 2n584's. J201's are hotter, so i'm told. The 2n584's are ? I used them cause thats all i had at the time.
Ebay is a fucker ~ Sinner - If this is something unique, then I'm a teletubbie ~also Sinner
I used all 2n584.
- joeboo88
Shiner Man, i pulled out the resistor (and my wife yelled at me to turn that crap down!)
Yeah the thing turns into a snotty biotch( the pedal ), It is louder and way more gain. ( i'm gonna put in a switch now)
You might have to double check you're stuff...But look on the bright side you might have just invented a new pedal!
Good luck bro
Good luck bro
- Nocentelli
- Has thanked: 1152 times
- Been thanked: 954 times
OK - voltages taken with 2M2 resistor in place, Q1-4 are 2N5457:
Power supply 8.95v -
Q1:
D 4.27
S 0
G 0
Q2:
D 8.94
S 4.27
G 2.97
Q3:
D 4.83
S 0
G 0
Q4:
D 8.94
S 4.84
G 2.97
I kind of suspect the different sound and voltages may just be to do with using different FETs to the specified 2N5457... Since you've socketed them, this would be pretty easy to check. Good luck, and give us a shout if you need anything else.
Q1:
D 4.27
S 0
G 0
Q2:
D 8.94
S 4.27
G 2.97
Q3:
D 4.83
S 0
G 0
Q4:
D 8.94
S 4.84
G 2.97
Okay, dumb question. How is that resistor supposed to be wired to the switch exactly?
I have the resistor on lugs 1 and 2 and the wires on lugs 1 and 3. Shouldn't the wires be on lugs 1 and 2?
And why am I confusing myself with such simple electronics? I think I need a beer.
- Nocentelli
Your way of wiring it sounds right (wires to 1+3, resistor across 1+2, as per https://www.freestompboxes.org/download/ ... &mode=view) - If the wires were also on 1+2, it would short the resistor and therefore directly connect Q1's drain and source.
- Nocentelli
er, I mean drain and gate, of course...Nocentelli wrote:Q1's drain and source.
Hmmmm...everything looks right to me.
- joeboo88
Nocentelli, sorry i typed your name wrong b4, would Shiner man's transistors make a huge difference?
- joeboo88
Hi Shiner man, i just did a quick check of your layout, against the vero and it look good, the only thing i can think of is
maybe the pot(s) are different? Sorry i'm just chucking stuff out there.
Good luck bro
Good luck bro
- plesur
- Degoop Doctor
If the PCB you are using is my one viewtopic.php?f=7&t=9373&start=140#p130101 this is the BOM.sjturbo wrote:Rephrasing the last post - If anyone has had a "successful" build using coldcraft's pcb could you please post a BOM including which are box style caps? Thanks!
Code: Select all
R01 Resistor 1M
R02 Resistor 62k
R03 Resistor 1M
R04 Resistor 2M2
R05 Resistor 1M
R06 Resistor 1M
R07 Resistor 10k
R08 Resistor 10k
R09 Resistor 1M
R10 Resistor 1M
R11 Resistor 47k
R12 Resistor 1M
R13 Resistor 10k
R14 Resistor 47k
C01 Capacitor 2u2 Electrolytic
C02 Capacitor 4u7 Electrolytic
C03 Capacitor 100n Electrolytic
C04 Capacitor 47u Electrolytic
C05 Capacitor 1n
C06 Capacitor 470p Styroflex
C07 Capacitor 4n7
C08 Capacitor 100n
C09 Capacitor 100n
C10 Capacitor 47n
C11 Capacitor 1n
C12 Capacitor 1n
Q01 Transistor 2N5457
Q02 Transistor 2N5457
Q03 Transistor 2N5457
Q04 Transistor 2N5457
P01 TONE Potentiometer 1MB
P02 GAIN Potentiometer 1MA
P03 VOLUME Potentiometer 500kA
DC Socket
IN Socket
OUT Socket
ENCLOSURE
BATTERY CLIP
LED
SWITCH 3PDT
BEZEL
KNOB1
KNOB2
KNOB3
D01 Diode 1n4001
Thanks much for th eparts list! much appreciated! Does anyone have a gut shot using this pcb! Also has anybody done a shoot out with this pcb version and the original? I would be interested in hearing it.
Thanks again to plesur and coldcraft!!
- bigmufffuzzwizz
Hey shiner man. I just read up through your troubleshooting. You said you have 2n4548's in your build and the build doc says 2n4547's. I believe those two are different and 2n4548's and J201 transistors are the similar interchangable ones. Try grabbing some of those and see if it fixes your problem. They are pretty cheap!
Also looking at your posted picture, I would trim the leads on the bottom down more if you can. I use a pair of flush cutters and I'm able to get all the excess lead off. Helps to prevent any kind of shorting.
Magic Pedals Home of The Shrine Fuzz!
- joeboo88
Biggmuffwiz, Shiner_man said he used
But your right about him shaving the teeth of those solder teeth
by shiner_man » 02 Apr 2011, 21:03
I used all 2n584.
- joeboo88
I forgot to mention i used 2 2n5484's and 2 j201's and my build sounds like its supposed to, but maybe he should use 4 2n5457's like you suggest.
Which leads do you speak of? The ones on the bottom of the vero or the ones connected to the spdt switch?bigmufffuzzwizz wrote: Also looking at your posted picture, I would trim the leads on the bottom down more if you can. I use a pair of flush cutters and I'm able to get all the excess lead off. Helps to prevent any kind of shorting.
