Rockett Blue Note OD  [traced]
Re: Rockett Blue Note OD
Postby Greg » 20 Jun 2010, 11:22
Here's the more sensible version..
    0K resistor removed.
    FAT pot jumper removed.
    Addition of 1K resistor to create a proper filter on the input.
    Power Supply resistor value increased.
These few simple changes are the minimum mods it really needs IMO.
I would have made the 2nd opamp stage a buffer, but that would change the effect of the tone control, and probably require some part value changes there, and as I haven't tried it I left it out.
For this message the author Greg has received thanks: 3
Blitz Krieg (10 Feb 2016, 07:49), modman (03 Sep 2011, 23:05), Sept29 (11 Oct 2013, 06:33)
Greg
Has thanked: 77 times
Have thanks: 195 times
Postby IvIark » 20 Jun 2010, 11:56
For this message the author IvIark has received thanks: 3
dakotajfarley (03 Oct 2013, 06:09), pmus (09 Sep 2011, 20:26), rousejeremy (25 Feb 2014, 16:20)
IvIark
Has thanked: 668 times
Have thanks: 682 times
Postby Greg » 20 Jun 2010, 13:10
Good work...
:thumbsup
Greg
Postby Ice-9 » 20 Jun 2010, 16:25
The addition of the "FAT" pot resistor was probabally only included on the pcb etch in case the builder had no 25k pots left allowing him to fit a 50k pot and a resistor to bring the effective value of the pot down to 25k
Ice-9
Has thanked: 143 times
Have thanks: 366 times
Postby Greg » 21 Jun 2010, 00:43
Ice-9 wrote:The addition of the "FAT" pot resistor was probabally only included on the pcb etch in case the builder had no 25k pots left allowing him to fit a 50k pot and a resistor to bring the effective value of the pot down to 25k
No doubt..
it wasn't on the board, it was tacked onto the pot.
Greg_G wrote:Finally, the FAT pot is marked on the board as 25K, but I'm guessing they ran out, so it's a 50K with a 47K resistor across it.
I've drawn that and the 0K resistor before the Vol pot in to be true to the traced unit, but both are unnecessary... i.e. use a 25K pot and omit the resistor.
Greg
Postby indyguitarist » 21 Jun 2010, 15:17
No doubt..
the reason for the resistor was because there was a shortage of pots a while back. Jay had to use a larger pot and parallel a resistor for the correct value.
indyguitarist
Have thanks: 161 times
Postby Quietus » 03 Sep 2011, 05:43
hi, sorry for bumping this old thread. i would like to know if anybody else have tried the above vero layout(w/ mods) and got it to work? im getting a short at row 9v and the other end of 56ohm(basically the whole stretch is shorted; only separated by the trace cuts) while giving it my feeble attempt at troubleshooting lol. :P i checked my vero to the layout given and i'm positive that i got all the positions right. i tried to find if i, by accident, soldered some things together to prolly caused that short but i just couldn't find one. signal could pass through if i touch my input jack to lugs 2 and 3 on volume, all 3 lugs on tone and gain pots. i measured using my multimeter and got 0v going from 9v to 56ohm. not sure if it's supposed to be measured that way lol. sorry for sounding like a noob because i am one hehe :oops: i dont really have that technical or electronics know-how in me but im learning things as i go. im new to all these pedal building. so, any help would be appreciated. thanks!
Quietus
Has thanked: 57 times
Have thanks: 16 times
Postby foo_3001 » 03 Sep 2011, 10:08
I´m interested in the Blue Note / Animal strictly from a musician´s point of view -
opening it up even a total pedal-construction-n00b could see they´re not exactly the most well-wired boutique ODs out there,
but I´m interested in what is the technical detail that allows the transparency / even bass response they have? They´re a bit on the cheapo side of things (and my ears tell me there´s a lot of TS in there) build-wise, but after making an extensive A/B test with 10+ boutique ODs I hate to admit they sound quite good..
foo_3001
Postby foo_3001 » 03 Sep 2011, 10:52
foo_3001 wrote:even a total pedal-construction-n00b could see they´re not exactly the most well-wired boutique ODs out there
(..just had to add : "even a total pedal-construction-n00b LIKE MYSELF could see..")
foo_3001
Postby Quietus » 03 Sep 2011, 16:54
okay i take back what i said above. turned out i've got a faulty supply jack. :slap: the vero is verified working! :horsey:
For this message the author Quietus has received thanks:
IvIark (04 Sep 2011, 01:56)
Quietus
Postby distortion_gfx1 » 15 Sep 2011, 02:28
Anybody got a Pcb layout for this..?
im kinda into lazy-ness right now. :mrgreen:
distortion_gfx1
Has thanked: 33 times
Postby Jonotron » 06 Oct 2013, 22:37
Hi there, built one of these the other day and it sounds quite nice but with a few slight issues. I ran a 47k resistor between lugs 1 and 3 on the fat pot (50k B) and it seems to only do anything at the very end of the pot's travel between say 3 and 5 o clock. Lugs 1 and 2 are jumpered together. Is this correct?
Also what is the deal with the LED out on the board? - I normally use a true bypass switch so I connected it to ground for the moment, is this needed?
Many thanks for the layouts etc!
Jonotron
Postby jbgron » 06 Oct 2013, 23:38
Has anyone got a copy of Güero's layout? uploaddearquivos.com.br times out for me.
Many thanks.
jbgron
Has thanked: 18 times
Have thanks: 5 times
Postby MoonWatcher » 07 Oct 2013, 04:57
foo_3001 wrote:but I´m interested in what is the technical detail that allows the transparency / even bass response they have?
Well, quite a few people consider the Timmy to have a transparent sound. This pedal is similar in that the bass is cut in the same way - just different amount of cut and at a different frequency. The tone circuit is also similar to a Timmy - simple low pass filter. The quad of silicon diodes is also similar to a Timmy - they will give you a greater range before you notice their effect on clipping than something like just a single silicon pair in a Tubescreamer will.
The quad of diodes isn't unique to the Timmy. You'll find them in the Barber LTD and the old Marshall Bluesbreaker, just to give two fairly familiar examples.
The tone circuit isn't unique to the Timmy either - it's most well-known use in a similar configuration is likely to be considered the ProCo Rat.
There's a few ways that it can seem like you've lost the transparency, especially with the example of something like a Tubescreamer. Its fixed bass cut removes frequencies at around 700 hz and below, and there's no way to adjust the bass cut like with this pedal. It has a fixed treble cut that removes at roughly the same frequency. The tone circuit can then either cut more treble or try to offset what has been removed by the fixed cut that comes before it. So removal of the Tubescreamer-type tone circuit replaced with just a simple adjustable single pass filter will open things up quite a bit.
The Blue Note has a very small gain range, so it's not going to get very distorted or compressed sounding. You can think of it as having a portion of a Tubescreamer's sweep through the drive knob - about 60% of it, as a really rough non-technical estimation.
It's the simplicity of the filters that allow for what you hear: input / bass cut / gain and overdrive stage / treble cut / output. There's nothing else to really color things - the simplicity is good for users who like this.
MoonWatcher
Has thanked: 43 times
Have thanks: 65 times
Postby xbobbytherookiex » 23 Jan 2016, 01:30
Hi guys. Could anyone tell me how could I mod this pedal to have a liltle more gain? If I change all diodes to 1n914 will that do it or increase value of gain pot?
xbobbytherookiex
Postby Nocentelli » 23 Jan 2016, 08:12
Increasing the gain pot to 100k is probably easiest, or you could lower R4 (resistor off the inverting input of the opamp) to 470r. If you swap the double pair of diodes for a single antiparallel pair, it will sound more distorted as the "clipping threshold" will be lowered.
xbobbytherookiex (23 Jan 2016, 10:26)
Nocentelli
Has thanked: 893 times
Have thanks: 855 times
Postby xbobbytherookiex » 23 Jan 2016, 10:28
Thank you very much Nocentelli for a quick reply. I will change gain pot to 100 k.
xbobbytherookiex
Postby storyboardist » 03 Feb 2016, 16:20
distortion_gfx1 wrote:Anybody got a Pcb layout for this..?
Almost 5 years late, but here's one. :lol:
For this message the author storyboardist has received thanks: 4
287m (04 Feb 2016, 14:28), blackbunny (18 Dec 2018, 02:16), Blitz Krieg (01 Mar 2016, 08:30), greenskull (01 Mar 2016, 06:19)
storyboardist
Has thanked: 71 times
Have thanks: 193 times
Postby 287m » 04 Feb 2016, 14:31
[ Image ]
wow David, awesome layout, but why jumper :P
i know you not jumperman guy type :mrgreen:
blue note board can built rocket animal too :D
287m
Has thanked: 322 times
Have thanks: 57 times
Postby storyboardist » 04 Feb 2016, 15:37
287m wrote:wow David, awesome layout, but why jumper :P
Haha yeah... :oops: I figure if I get all 4 pots board mounted having 1 jumper isn't that big a deal. Maybe I'm just getting soft on jumpers in my old age. :mrgreen:
storyboardist
Users browsing this forum: marvilla, storyboardist, wells and 11 guests
