EVH 5150 amp schematics, real ones
Free online ressources on guitars, amps, effects, guitar technique and more. Dedicated to the fond memory of its founder SPeter Davidoff.
Postby Ice-9 » 03 Feb 2013, 13:48
Here are the real Fender amp schematics for EVH5150 amps and footswitch in case there any use to anyone.
They can be found on the evh/fender website, but for easy download and reference I put them here.
100w and 50w versions.
For this message the author Ice-9 has received thanks: 26
-X- (29 Sep 2014, 03:52), Bernardduur (10 Sep 2013, 13:00), Broadcaster (03 Feb 2013, 18:28), FiveseveN (03 Feb 2013, 18:27), jrod (10 Aug 2013, 04:04), lietuvis (03 Feb 2013, 15:28), Manfred (24 Mar 2013, 23:27), pamaz (16 Nov 2015, 17:20), rads (25 Dec 2013, 04:24), SFTFN (03 Feb 2013, 20:37) and 16 more users
Ice-9
Has thanked: 141 times
Have thanks: 361 times
Re: EVH 5150 amp schematics, real ones
Postby okgb » 03 Feb 2013, 16:59
the thank you button is not working for me today , so Thanks
okgb
Has thanked: 197 times
Have thanks: 41 times
Postby tarnow74 » 08 Aug 2013, 20:06
Those TL072 opamps in the 50w version probably sucks some tone when using the effects loop. I have the Hot Rod Deluxe which also comes with TL072 opamps in the effects loop and just jumping the effects loop with a patch cable made a lot of negative difference to the tone. I then bypassed the opamps in the circuit which worked fine. This will increase the effects send level and might be bad for some pedals. A more elegant fix would be to change the opamps to some newer high quality ones.
tarnow74
Postby deltafred » 09 Aug 2013, 08:31
Hi and welcome to FSB.
tarnow74 wrote:Those TL072 opamps in the 50w version probably sucks some tone when using the effects loop.
You obviously don't understand how opamps work and have been drawn in by the "cheap opamps suck tone, expensive ones don't" hype.
The frequency response is purely dependant upon the feedback components around an opamp (as long as you stay within the design limits).
.... A more elegant fix would be to change the opamps to some newer high quality ones.
See above. Higher quality opamps will have better specs for noise, offset, CMMR, etc but will not affect the FR (in an audio circuit) one bit. Whether you notice any difference in these other parameters is doubtful.
You may however feel better and think it sounds better by throwing money at it.
It may be that the capacitance of your cables is causing high frequency roll-off of your signal when using the effects loop but no amount of opamp rolling will alter that.
For this message the author deltafred has received thanks: 2
Dirk_Hendrik (09 Aug 2013, 16:44), FiveseveN (09 Aug 2013, 14:29)
deltafred
Has thanked: 381 times
Have thanks: 259 times
Postby Dirk_Hendrik » 09 Aug 2013, 16:48
Rather amazed by the "discrete" switching logic design which exceeds the amps audio circuitry in component count. Seems a task that can be done easily by a small CPU at a fraction of the price.
At the other hand, a device is as good as it's power supply. And therefore it's nice to see the power supply on the first page.
Has thanked: 253 times
Have thanks: 1014 times
Postby Ice-9 » 09 Aug 2013, 21:03
Dirk_Hendrik wrote:Rather amazed by the "discrete" switching logic design which exceeds the amps audio circuitry in component count. Seems a task that can be done easily by a small CPU at a fraction of the price.
It does look rather complex, the two 50watt circuits are using a CY8C27433 micro to help with switching but the 100watt head isn't. Looking at the footswitch though there is a micro in there but I haven't had a good look over the schematics to see what is working what.
Ice-9
Return to Davidoff Library
