Ampeg - Sub Blaster [schematic]
- chicago_mike
CD4013 :
Pins 9,11,4,6 go to ground.
make sure on your layouts / transfers that pin 4 goes to ground. It should not be floating.
So I get it to create the lower octave, but my dry signal is not clean, not full swing. Have to double check some soldering.
Skyline FX 2013
- chicago_mike
SUCCESS!!!!
99% anyways!
Okay I need help here. I have the octve signal, and everything else is great.
I do NOT have a J175.
I DO have though
J201
J111
2N3820
2N3819
I noticed the J201 is used in the Boss Octaver...Could I just use that and see what happens?
99% anyways!
I DO have though
J201
J111
2N3820
2N3819
Skyline FX 2013
- chicago_mike
OKay so swapping in a J201 Almost works.
In the Boss schematic, theres a couple extra parts to do, an extra resistor tying one of the pins back to Vref.
But I do get a pre octve, Octave and post octave signal ( of some sort ).
Skyline FX 2013
- chicago_mike
So in theory, on paper.
Tie the Drain to a 100k to Vref.
Tie 1meg to gnd to the gate After the 100K resistor coming out of the CD4013.
Change the 100K to a 1MEg.
All I did so far was the 100K vref mod.
Going to try the others right quick and see what I can see.
Fuck if this works!!!!
Skyline FX 2013
- chicago_mike
Now, to clean it up and see if theres any way to clean up the tracking. If not thats fine.
But, its working.
But, its working.
Skyline FX 2013
- chicago_mike
Adding a little gain make up stage after the passive Big Muff style tone control.
Changing the 100K resistor coming off the cd4013 to a 330K...this value is in the EBS, the DOD and a couple other octave pedals. All using an N Fet.
Might put in a switch to change out the .22 in the Octave filter and switch between that and a .1 or a .06 as I have a drawer full of .064's.
Octave pedal is still working though. So I can confirm with a couple mods that yes its a verified build.
Skyline FX 2013
- chicago_mike
IM gone for a month on tour and she is going on my pedal board.
Skyline FX 2013
- mictester
MODS!!chicago_mike wrote:LADIES AND GERMS!!!!!!
the previous schematics have some incorrect areas.
I had issues with poor tracking of the sub octave. A huge improvement was achieved by making U4a a clipper (like a TS clipper with a pair of diodes around the output to the inverting input). I then did an active low pass filter (-18 dB/octave) with a bit of gain (to recover the loss due to the clipper) and a turn over point at about 1.4 kHz. It really tracks well now!
- DavidRavenMoon
Please post a schematic!mictester wrote:MODS!!chicago_mike wrote:LADIES AND GERMS!!!!!!
Does it track correct when playing chords? I heard the EBS octaver could do that - looking at the EBS schematic I assume it depends on the filter design in front of the frequency detection.mictester wrote: I then did an active low pass filter (-18 dB/octave) with a bit of gain (to recover the loss due to the clipper) and a turn over point at about 1.4 kHz. It really tracks well now!
- chicago_mike
Food for thought
This is a very popular octave pedal for bass. Its red in color. the schema is the service schematic. So I have nothing else for it.
Perhaps we can add the tone controls to the ampeg unit?
- OCT_07_schematics.pdf
- (23.68 KiB) Downloaded 355 times
Skyline FX 2013
- chicago_mike
The official schematic was published earlier.
It was from Ampeg themselves. In the DIY layout there is a missing connection from the CD4013.
I would trace your signal before the 4103..the gain structure feeding it, just to see of those opamps are working correctly.
For Octave pedals...its a simple circuit.
Skyline FX 2013
