Mad Professor Sky Blue Overdrive [traced]
- Grendahl
I haven't forgotten about it yet... that PCB is on my to-do list. We've had some illness around our house over the last two weeks so I haven't really had time to play with it yet.
Resistance is futile...
( if < 1 ohm )
( if < 1 ohm )
I just had the same idea and changed the Z Pot to 1M and decreased C3 to 0.1uF. So far so good, at the moment I think it works much better for me. It's still not too bright. Thank's a lot ibodog2!!!
- Grendahl
Before I start on the PCB, can you guys take a look at this to see if I've butchered it up please?
( if < 1 ohm )
( if < 1 ohm )
- Grendahl
Doh! You're right. I'll get that revised straight away.ibodog2 wrote:Check back in the thread for Mictester's modification for the single pot. You've got it hooked up wrong in the one you posted. Thanks!
In the meanwhile, I've pulled the prior image so as to not confuse anyone.
( if < 1 ohm )
( if < 1 ohm )
- Grendahl
I haven't set this up on a breadboard yet, can anyone verify that the tone control mod works at the specified values?vot wrote:Simple tone control: instead of R12(1,8K) - B2K5 pot in series with 620R.
As a side note, had to go back and re-do the schematic again... Eagle died on me and the project file got corrupted. Grrr!
( if < 1 ohm )
( if < 1 ohm )
- mictester
I've never really seen the point in loading down a pickup like this thing does - if you want top cut before the distortion stage, there are much better ways of doing it. This approach in this pedal also prevents you usefully putting anything before it - I sometimes like a clean booster, or a top end boost, or a compressor before I distort things.
The thing to like about this pedal is the distortion stage and the way the Texture control works (in the single pot version).
I've played around with this sort of approach before, and it's very controllable... It's also interesting to mix in some clean signal too, and be able to "cross-fade" between clean and distorted (a bit like the Sparkle Drive). Again, it can be done with a single pot, and if you dimension the output of the dirt stage to match the clean buffer, you can get a very smooth transition from one to the other. I have built one or two pedals into wah shells to do this - clean in the "heel" position to really distorted with the "toe" down. This allowed some really interesting effects...
- Grendahl
That's great feedback, Mictester. Thank you!
I'm still pretty new to the DIY pedal scene, and while I can mix and match snippets, I'm not always able to anticipate the effect on the signal very well.
Per your suggestion, I think I'll pull the treble cut for now. Perhaps a dual box with a clean boost and tone controls would be a good pairing to this pedal as a second-in-line stompbox. What do you think?
( if < 1 ohm )
( if < 1 ohm )
- Lonkero
Gotta build this
How big box is needed for that veroboard ?
- Lonkero
That looks like Hammond 1590 box but slightly bigger. How you have secured that veroboard into the box?
- Lonkero
What kind of red leds to use in diodes? Should they be 3mm, 5mm, extra bright or what?
- Lonkero
Okay it seems normal 3mm red leds will do just fineibodog2 wrote:Dude, go to the first page of this thread and read everything through and look at the photos...Lonkero wrote:What kind of red leds to use in diodes? Should they be 3mm, 5mm, extra bright or what?
- Lonkero
I want to build this but not yet sure if some info info comes regarding getting the Z control like in original.Frank wrote:I haven't been able to track it down exactly yet (and the original is due to go to a new owner soon). With the Z all the way down the original and copy have the same high frequency response to my ears. But the copy's Z at max is about the same response as the original at a little past noon. Maybe try a A1M pot for the Z instead of the A500K pot. I sent the Eagle schematic to another member here who was going to try do create a PCB. Maybe they'll be able to post that when it is finished. I'm still going on the theory that the difference in high frequency response is either a build issue on my part or a layout issue on my part. Or possibly a slight parts tolerance difference.burstcracksplit wrote:Thanks a lot for the tracing and the vero layout! I just build it and I like it, but I definitley think it needs more presence or a little bit more treble... hmm, decreasing C3 would be too simple, or what do you think?
The difference could well be caused by tolerance in pots. I tried with mine 250 projects 500k gain pots (20% tolerance) which one measured 510k, had definetely brighter sound than a pot which measured 480k. Did you measured the pot actual resistor values for the Z control both in clone and original?
- RnFR
why does this thing need a pulldown resistor? the Z pot does that!
- roseblood11
Sure, but is it just a top cut or does the Z-control influence the resonance frequency of the guitar?mictester wrote:I've never really seen the point in loading down a pickup like this thing does - if you want top cut before the distortion stage, there are much better ways of doing it. This approach in this pedal also prevents you usefully putting anything before it - I sometimes like a clean booster, or a top end boost, or a compressor before I distort things.
@method: Great layout! Could you please post the *.diy file? Would be easier to draw some modifications then...
Hello. Maybe someone have layout for this schematic? Please upload this layout. thanks)))
