and now for something completely different...
i etch PCBs using hydrochloric acid and hydrogen peroxide. this process is quick, efficient and seems to leave no horrible stains all over the place like FeCl3 does. it does leave me with a major problem, namely safe disposal of the CuCl2 solution left behind.
now, the simple solution would be to let the water evaporate until only the crystals are left behind and hand those over to the correct authorities, right? problem - i live in INDIA. we have nothing in the way of collection of hazardous goods or anything of the sorts. effluents, garbage, chemicals, you name it are dumped into the closest water body.
i don't like the idea at all though. so i need help...
this is what i did -
a. first batch - i took the used etchant and dumped baking soda (backpulver) into it until it would no longer effervesce. then i let it sediment and poured off the clearish liquid (an aggressive base) on the top into a beaker. using a pH meter i added HCl till it was around pH 7, diluted it with water and poured it down the drain. i think that should be quite safe. i still have the copper sediment - no idea what that is now, my chemistry lessons are failing me here. how do i get rid of it safely?
b. second batch - my current batch of etchant is still going strong, have done a few PCBs with it already - HCl, H2O2. it is going quite blue now, and i would like to think of a better method than method a. is it possible to electrolyse the copper out? does anyone know of any simple rig that could achieve this?
thanks to all on this great forum for any suggestions - i want to do my bit for the environment, status quo and lackadaisical attitude in this country be damned.
