Rockett Blue Note OD  [traced]
Greg
Completed builds: LOTS..
Has thanked: 65 times
Been thanked: 164 times
Post by Greg »
Seljetnoma kindly sent me some detailed photos of his Rockett Blue Note OD (thanks Frank), and I traced it with his help.
Looks like it's the same board and circuit as the Rockett Animal, with different component values, so someone might like to work out those values from the pic in the other thread and we can solve that one also.
If someone does it and wants to send me the values I can easily update this schemo to the new values, and post it in the other thread.
Firstly.. here's a couple of pics:
Greg
Post by Greg »
And here's the schematic.
If anyone spots a mistake, let me know and I'll update it..
The reason only some of the parts have part numbers is these are the ones I could see in the photos I had.
The connections on the un-used opamp stage were added by me. It's un-connected on the actual pedal, but this can cause some problems.. so I thought it best to add them.
Enjoy.. this seems to sound pretty good from the clips - in a TS'ish way... although there's a couple of things that could be better...
I'm sure the 220pf on the Input would work a lot better as a filter with a resistor before it.. :D
..and I'd say the volume would affect the tone control. Might be nice to turn that 2nd opamp stage into a buffer.
Finally, the FAT pot is marked on the board as 25K, but I'm guessing they ran out, so it's a 50K with a 47K resistor across it.
I've drawn that and the 0K resistor before the Vol pot in to be true to the traced unit, but both are unnecessary... i.e. use a 25K pot and omit the resistor.
mictester
Has thanked: 32 times
Been thanked: 845 times
Post by mictester »
Greg_G wrote:And here's the schematic.
I think the mistake was building something like this! It's crude as the word f**k! Why did they waste the second half of the op-amp? The "tone" control won't do much at all except roll the top end off a bit, the "hot" switch is silly - why didn't they just scale the resistors around the op-amp more sensibly? The input "filter" cap won't do much that's useful, and the op-amp is (effectively) unprotected from the input socket, and will easily get zapped. What a horrible "design".
Greg
Post by Greg »
:mrgreen:
I had the feeling that anyone who knows what they're looking at wouldn't be too impressed with this one.
It is a little crude isn't it.. the result of trial and error design I think.
madbean
Post by madbean »
:slap:
Thanks for the trace, Greg. Have to agree....nothing much to see here.
Jack Deville
Completed builds: too many. too many.
Been thanked: 86 times
Post by Jack Deville »
Is there any strain relief on the battery leads?
I'm a "professional."
Buy my products and make me rich.
www.jackdeville.com
Seljetnoma
Post by Seljetnoma »
Jack Deville wrote:Is there any strain relief on the battery leads?
No, it's free floating, no strain relief at all.
Frank
Jack Deville
Bummer.
At least its easy to access! :D
www.jackdeville.com
Greg
Post by Greg »
According to the TGP crowd this and the Animal are the best ODs ever built:
http://www.thegearpage.net/board/search ... d=20945063
I guess we have to acknowledge that something that's not a correct Electronic Design can actually still sound good... and if that's the case the answer is to fix the shortcomings.
With that in mind I think I have to build one of these and see if I do like it, and if so.. apply the needed fixes.
Crazy I know.. but I love low gain ODs, and the clips sound good to me.
:slap:
bucksears
Has thanked: 16 times
Been thanked: 41 times
Post by bucksears »
The Blue Note, Animal and FlexDrive were designed by Brian Wampler......
I had the Animal briefly and thought that it sounded GOOD, but was not 'open' enough for me and my amp. I like my modded BSIAB II better for a classic rock sound (albeit a little less bassy) with the gain dialed back and the volume up.
madbean
Post by madbean »
bucksears wrote:The Blue Note, Animal and FlexDrive were designed by Brian Wampler......
Wow, no kidding! Well, he certainly has plenty of great designs.
indyguitarist
Been thanked: 161 times
Post by indyguitarist »
schem looks fairly correct I think (though part values were different originally).
My "design" (and i use that term loosely) was the topology roughly. Jay and Chris changed part values quite a bit.
As far as the other concerns, build the thing and see if you like it, if not, tweak it. it's obviously a pretty simple circuit. that's what was wanted.
IvIark
Has thanked: 562 times
Been thanked: 586 times
Post by IvIark »
Here's a vero layout for those who want it. It's currently unverified.
I've used part dimensions in the layout exactly based on those bits that I've got in, so if you may have to jig it about if your part sizes don't match up. It's probably only the thin 4u7 that may need an extra column adding if yours are fatter.
Greg
Post by Greg »
indyguitarist wrote:schem looks fairly correct I think (though part values were different originally).
Thanks Brian
Thanks IvIark
Greg
Post by Greg »
IvIark wrote:Here's a vero layout for those who want it. It's currently unverified.
I just had a quick look at the layout..
The 10R on the power supply is to aid filtering, so it should go before the 1st 47uf cap, and also before power to the circuit.
It's not critical really, and 10R is an unusual choice of value... but if it's not before the cap and the rest of the circuit it serves no purpose.
IvIark
Post by IvIark »
Doh!
Re-jigged version. I also got rid of the axial elecros, it makes more sense to use radials in a layout like this and makes it a column narrower:
Güero 2.0
Been thanked: 24 times
Post by Güero 2.0 »
Thanks Greg_G for trace and post the schematic.
Here's my layout for Blue Note OD. The layout fits well in a hammond 1590b.
I suggest that you use Neutrick jacks for this one.
http://uploaddearquivos.com.br/download ... ero_EN.pdf
enjoy!
"Come squeeze and suck the day.Come Carpe Diem baby!"
binog15
Post by binog15 »
Güero 2.0 wrote:Hi,
enjoy!
grande Güero
The best brazilian effects designer.
Güero 2.0
Post by Güero 2.0 »
binog15 wrote:
Güero 2.0 wrote:Hi,
enjoy!
grande Güero
Oh come on...!?
junior_01
Post by junior_01 »
Grande Güero com tremas !!!! Sem palavras.
Congratulations and thank you!!! :applause:
