Sola Sound - Tonebender Mark II Professional  [schematic]
Postby bajaman » 15 Sep 2007, 14:11
Of all the tonebenders, I really do like the MkII version - It nails the Hendrix Voodoo Child sound when you put a well tuned wah pedal in front of it too.
I don't think Hendrix ever used a Fuzz Face - If he did, I don't think he liked it from what I have heard from folks supposedly in the know - forget the other benders - build a MkII - you won't be sorry you did.
For this message the author bajaman has received thanks:
biffa (19 Jan 2011, 14:41)
Has thanked: 461 times
Have thanks: 1591 times
Postby vanessa » 15 Sep 2007, 18:42
bajaman wrote:I don't think Hendrix ever used a Fuzz Face - If he did, I don't think he liked it from what I have heard from folks supposedly in the know - forget the other benders - build a MkII - you won't be sorry you did.
I agree. I've only seen one photo with JH having a FF in front of his wah (photo was from his early days). Every other photo has him with it after the wah. What changed? Was the circuit modified to work with a wah? I would guess the whole thing was gutted and a different circuit put in there. It could be anything in there. I'll take another guess and the FF enclosure was used because it's incredibly road worthy. Maybe he could see the future, wanted to throw off greedy pedal manufacturers and destroy the tone of many a Hendrix impersonator?
Here's the RM Axis schemo that's floating around:
http://www.diystompboxes.com/pedals/axisfuzz.gif
Is this the Jimi tone machine?
vanessa
Have thanks: 10 times
Postby modman » 03 Nov 2007, 15:35
Bajaman,
What schematic are you using for the Mk II. Took a quick look and couldn't believe how many dead links at http://home-wrecker.com/tbmk2.html
Green Fuzz, Franke Clarke's page, a MkII schematic at SmallBear? I think I checked Aron's Schematics links but there are so many dead links there, is kind of frustrating.
Has thanked: 3299 times
Have thanks: 612 times
  [schematic]
Postby modman » 03 Nov 2007, 15:37
Postby bajaman » 03 Nov 2007, 22:13
Yep - that is the one!!
Postby modman » 04 Nov 2007, 11:29
vanessa wrote:
frank.clarke wrote:Thanks Vanessa, mine goes from pleasant overdrive to Foxx Tone Machine depending on the transistors. It sounds exactly unlike something Mick Ronson would have used. I'll give the AC128s that just arrived a shot and that's it, so under the knife it goes.
I would not waste those on this one. You have to step back... This one is not a top shelf project by any means. Buy up some 2n404's cheap, the crappier the better. :wink:
I have heaps of 2n404As with gold legs, but incredible gain for most of them (> 130) Maybe I should try them. Also found a a lot of different version ready for transfer at GGG Tone Bender Mk II Pro.
Should we split off discussion on Mk I vs Mk II? Let me know...
Postby modman » 07 Nov 2007, 16:52
I built the Tonebender Mk II, in fact I etched 3 GGG boards and started off with a PNP negative ground configuration, my finding largely:
    I had to use a 100k trim pot on Q3 collector to be able to dial in the correct bias. 8k2 did nothing
    The very few with <100 hfe from my 2N404A stack didn't work well in Q1, I used an unbranded East German transistor for that position. Experimented with 2N404as in Q2 and Q3 (hfe's 90 and 125 or so) and got very fat fuzz, but a thorough lack of sustain
    The sustain problem improved by putting two East German transistors and what I think is a AC151 for Q3 (hfe 125), Q1 is 70; Q2 is 85 or so
    After biasing the circuit up each time I also check the Vc on Q1, and telling by my ears it likes to sit at 4-5V
    The circuit is a real good saturated fuzztone that sings in a fuzzy way, it only needs more sustain and maybe more volume. Trying out both Strat and LP it like the LP more than the Strat, and sounds much better with neck pickups than with bridge pu's. It at least wants to see two parallel single coils. All this makes me think the sustain is still a serious problem. Never had that problem with a fuzz face.
    By itself it's a singular and useable crazy fuzztone that's worth boxing up. Might do so and try a NPN Ge or Si version. After going through some 100 transistors you yearn for silicon, especially since I came across some low gain ones.
will keep you guys updated.
Postby DougH » 07 Nov 2007, 17:01
You guys need to quit futzing with Ge's in this circuit and try a Si version. :lol:
I built a Si version a few years ago called "Hot Silicon" and it sounds great. It's one of my favorite fuzzes.
No muss, no fuss, no fiddling with biasing, just solder it up and go... 8)
DougH
Have thanks: 23 times
Postby modman » 07 Nov 2007, 17:58
I know, Doug, heating up the iron to do a second version as we speak.
I googled for the schematic and first hit was this
http://www.foxroxelectronics.com/Hot%20Silicon.html
Postby DougH » 07 Nov 2007, 17:59
Nope, that's not it.
Check with AG, I'm sure he has my schematic... :D
DougH
Postby tuemmueh » 07 Nov 2007, 18:10
Could anyone post that schematic? I'm currently messing with fuzzes and still haven't found what I'm looking for.
tuemmueh
Have thanks: 2 times
Postby analogguru » 07 Nov 2007, 18:16
Do you mean that ?:
http://web.archive.org/web/200406091428 ... bender.gif
Have thanks: 117 times
Postby DougH » 07 Nov 2007, 18:24
That's it... :roll: :lol: :lol:
edit: Oh, and don't use a pull-pot for the "fat" switch. I'm always hitting that with my foot...
In fact, I really hate pull-pots or toggle switches on stompboxes. They don't call them stompboxes for nothing... If you need a switch option, i would suggest using another stomp switch.
For this circuit I would suggest wiring it "permanently fat" with the 10u (or pick something you like). .01u is too thin on most of my amps, only sounds good on my SS amp.
DougH
Postby tuemmueh » 07 Nov 2007, 22:43
Thank you, Sir ... ;)
tuemmueh
Postby modman » 19 Nov 2007, 16:25
I built a NPN Ge and an NPN Si version.
NPN GE: went looking through my stash and found some 2SK352,, AC175s and other GEs, but irrespective of the transistor choice I got great fuzz with incredible sustain, but a lot of noise . Didn't take the time to modify the pcb with RF caps or resistors. The transistors are probably too leaky
NPN SI: in this setup as well as in my other configs, I used a 100K pot for the bias so I could always dial in the 'correct gain'. I tried 2N2222, 2N4401, MPSA13, 2N3904 and 2N5088/9. Finally settled for Q1 = 2N2222; Q2 = 2n4401; Q3 = 2N5088. Very low gain silicons didn't work - say hfe < 100
After biasing at 4.5V, it seemed that nothing was lost tone wise raising the bias to 7V - but you win in SNR, treble content and some definition in the sound. This requires only 1k on the collector of Q3 in my setup. When you hit your guitar hard, the bias momentarily drops to 5.8V or something.
Was only trying out the GE's out of curiosity, and because it has a history of being a problematic build.
I was also wondering, is that original Silicon Tonebender by Gus still available?
Postby ultar » 25 Nov 2007, 05:56
are you using the schem from fuzz central with these transistors? i want to mess around with the tonebender circuit but i think silicon transistors would be more my style and much less of a headache to purchase. the fuzz central npn silicon schematic looks like a good starting point.
this is slightly o/t but i've found that a collector reading of ~7v in q2 and q3 of my modified big muff circuit yields the best sound. possibly a secret voltage sweet spot?
ultar
Postby modman » 28 Nov 2007, 15:28
I had etched some GGG boards, so I used those, but the schematic is largely the same.
This I find very interesting, but there must be some mathematic reason for this. Anyway I would start out making SI TB before doing GE versions to avoid frustrations, I learned the hard way. Had a fair selection of transistors that had done well in other builds, but they didn't sing in my Ge Tonebender builds.
With silicon the transistors types don't matter so much, it seems.
Postby jakerandall » 28 Nov 2007, 20:09
mod do you have a schematic along with some instructions for a silicon tonebender? I have tried silicon without any success at all in all fuzzes but high gain fuzzfaces.
jakerandall
Postby modman » 28 Nov 2007, 20:41
GGG project uses the same pcb transfer for all its versions (npn, pnp, ge, si), so it's a bit bigger if you know you want the silicon npn.
Everything you need is also here:
http://fuzzcentral.ssguitar.com/mkII.php
Scroll all the way down for the standard NPN silicon version - schematic + transfer files
DougH take on a silicon tonebender with tone control.
all links from the first page of tis thread,
hope this helps
modm
Postby modman » 10 Jan 2008, 23:16
JimiB wrote:I am trying to create a really accurate MKII and I was looking at the D.A.M. stuff and he is using a trimpot but also the 8.2K resistor. Do you think the trim pot is a 100K in series with that 10K and subbing for the Q2 collector r?
http://www.stompboxes.co.uk/gpage2.html
you cannot tell the value of the trimpot, or do you know more? don't know what's going on underneath. I would really just go by the schematic, but indeed not neglect a (one) trimpot.
Next
