Bartolini - NTMB Bass Preamp [schematic]
- quaternotetriplet
i'm interested on how you modded it.
will you please post the schem man. thanks
- chicago_mike
viewtopic.php?f=10&t=7139&start=60
I cant find the schema I did with the vari-mid already in the bartolini circuit, but here is at least the circuit.
Skyline FX 2013
- lietuvis
Hey this is my tryout to create nmtb preamp pcb,its not that big.the inductors that I can see on net found on mouser is 150mH are quite big 12mm diameter and 16mm lenght.I use few jumpers(they not marked but can be easy spotted), all wiring goes thru holes on pcb and connects in closest posible points according schematic.pcb is done on diptrace free software.
- bartolini nmtb.dip.zip
- (5.05 KiB) Downloaded 374 times
- lietuvis
Is there anybody who successfully built ntmb preamp? I have, but not completely satisfied, the midrange control+range switch is very much interacting with bass control, it seems that midrange is not actually hump or dip at the given frequency corner selection, ether the Q is very low so it effect the bass range.on schematic at the very bottom it says OFF resistance of push pul MID pot is 47K (two R soldered to the pot), anybody knows what it means and what resistors have to be connected to pot.any suggestions?
the pic shows the second board I am building but without inductors and pots attached to it, identical to one I've built (was thinking to put on both of my basses)
p.s that picture was taken with laptop camera and it is reversed
- my second board without inductors and pots.jpg (53.33 KiB) Viewed 2158 times
- Jarno
- my favorite amplifier: Something nice
- Completed builds: Alembic-like state-variable and sallen-key filter preamps
Lovepedal Eternity
Phase 100
Brown source
Fuzz Face
Flipster
Alembic F2B (tube preamp)
Opamp and FET buffers
Tables
Bookshelves
Basses
So many things! :D - Location: Rosmalen, NL
- Has thanked: 27 times
- Been thanked: 81 times
Don't recall the schematic. But I can imagine the Q of the mid-section, which uses the inductors, being dependent on the resistance of the inductors, the lower the resistors the sharper the Q will be.
- my favorite amplifier: marshall jcm 900
- Completed builds: - rebote 2.5
- fuzz face.. fuzz factory with 2n404 transistor's
- electric misstress flanger
- balck cat hot cat
- big joam
- tremulus lune
and many more..
because im still learn more for it..
:) - Location: Bandung,Indonesia
- Has thanked: 2 times
- Contact:
sorry.. can i ask? does it project use for guitar or for bass?
