Tycobrahe - Parapedal  [schematic]
spookybonus
Post by spookybonus »
yeah i would love to get the RG files as well if anyone has them saved.
spookybonus
i made up a parapedal from the schematic, but i used two 22uf caps because i didnt have any 33uf caps on hand...do you think that might be why the effect seems to not quite sound as "full" as the demos i have heard online?
i wish i would have bread boarded this before i made it on a pcb, to would have been much easier to swap the parts in and out. :slap:
i have a bunch of 47 uf caps i could try out, if that would increase the effect.
phibes
my favorite amplifier: HIWATT motherfucker!
Has thanked: 75 times
Been thanked: 189 times
Post by phibes »
47uF will be a-ok!
Image Ken
Dan N
Has thanked: 58 times
Been thanked: 21 times
Post by Dan N »
spookybonus wrote:yeah i would love to get the RG files as well if anyone has them saved.
They're still on his site. Go to http://www.geofex.com/ and scroll down to 8/25/06 and you'll find:
http://www.geofex.com/FX_images/parapedal.gif
and
http://www.geofex.com/FX_images/newparapedal.pdf
Dick joke has expired.
giannyx
Post by giannyx »
Sorry guys, is there a components list anywere?
There are no informatio about U1 and U2...
Also no information about the Pots.
Is there anybody knows it?
Thanks a lot!
:horsey:
Has thanked: 232 times
Been thanked: 888 times
giannyx wrote:Sorry guys, is there a components list anywere?
Thanks a lot!
:horsey:
The pots say 10k.
The opamps are standard pinout dual opamps. This means that if you put in a standard dual (TL072, 4558, LM833, 1458, NE5532, etc etc) opamp.... it's going to work!
giannyx
Post by giannyx »
Thanks a lot Dirk!
Both pots are 10K?
I'm trying to find the second one! :hmmm:
:oops:
:D
phibes
Post by phibes »
There's only one pot. It's a dual-gang.
Image Ken
giannyx
Post by giannyx »
phibes wrote:There's only one pot. It's a dual-gang.
:oops: :oops: :oops:
Right! Sorry.
But C3 hasn't a value...what value do you suggest to use?
Thanks a lot!
:D
phibes
Post by phibes »
It was .001uF on the original schematic. I think that value was verified.
Image Ken
cortezthekiller
my favorite amplifier: A large highway overpass
Has thanked: 20 times
Been thanked: 52 times
Post by cortezthekiller »
As an update I've built the parapedal from the layout/schematic available here and can say that this pedal needs an AUDIO taper for the dual pot. Otherwise the sweep is way too bunched up at the toe end of the range. Other than that it works perfectly. Just keep in mind that the Hot connections mentioned on the layout are the counter clockwise connections on the pot (usually pin one). This confused me somewhat though it specifies on the schematic.
Nocentelli
Has thanked: 1155 times
Been thanked: 954 times
Post by Nocentelli »
I'm going to have a go at this, but i'd like to use an expression pedal to control the sweep. It seems like a fair bit of exrtra circuitry, but I'm going to have a go at using the tonegod's "Rock N'Control" (three pole - fig 5) circuit, but doubled-up to replicate the dualgang pot: Image
My main concern is tuning the six trimmers required for a dual circuit whilst trying to measure the reciprocal increasing and decreasing resistance across two ganged simulated potentiometers. Sounds like a painful process.
Can anyone suggest an simpler method (of using a single expression pot to control a simulated dualgang pot)? I'm going to get it working hopefully with a dual 100k pot (I've read elsewhere the value of the pot isn't necessarily critical), and one other idea i had was just to use a fixed resistor for the "lower half" of each gang of the pot, and use two single LDRs for the top halves. I could then just use the passive two pole version.
Nocentelli
link to tonegod's circuit didn't work, try this:
http://tech.thetonegod.com/rockncontrol/rock.html
kymar
Been thanked: 13 times
Post by kymar »
corrected schematics
layout
layout
Parapedal lay.jpg (71.43 KiB) Viewed 4562 times
Fender3D
Has thanked: 121 times
Been thanked: 153 times
Post by Fender3D »
kymar wrote:corrected schematics
Why D2?
kymar
Post by kymar »
Fender3D
Post by Fender3D »
oh ok,
I did guess it was your layout...
...then D2 shouldn't be 1N4001, rather a zener...
check its name, please.
kymar
Post by kymar »
Fender3D wrote: ...then D2 shouldn't be 1N4001, rather a zener...
My fault, of course zener, otherwise opamp can`t operate.
It is 1N5231 instead of 1N4001, marked D2 on schema, please correct it.
fatboy757
Post by fatboy757 »
Im terribly new to this but can anyone make a veroboard or tag board layout with the values listed. I dont know how to do that. I understand symbols in schematics and values but dont have a full grasp on everything.
JimSalabim
Post by JimSalabim »
Hi! Maybe some can help:
I would like to build a Parapedal clone in a Dunlop style Wah enclosure and use the schematics and layout from geofx.com:
I would like to use the third layout of the PDF (the smallest one) and I have a few little questions (I am new to all that stuff):
  • The parts I need are the ones listed in the gif-file with the schematics?
  • There is no value for the C3 capacitor. Someone wrote it has to be a 1nF capacitor. Is that correct?
  • Do I use two TL072 opamps for U1 and U2?
  • Which diode do I have to use for D1? I read something about a Germanium diode: 1N270. Is this the right one? Or do I use a silicon rectifier diode 1N4001? Or something else? :-)
  • What does J1, J2 and J3 in the layout mean?
  • Which dual pot would you recommend? Does it need a long shaft to fit in a Dunlop style enclosure?
  • Can I use the normal Dunlop wah switch to turn the pedal on? How do I wire it?
And if I decide to use the second layout of the PDF, are the values the same? Which values are R14 and R15 and which diode is D2?
