Emma - Reezafratzitz [ goop-alarm ]  [traced]
spiffy chap
Post by spiffy chap »
miwanone wrote:I can post eagle files on request, I've got some sound samples here! It's clean, clone, original.
http://www.gitaar.net/forum/index.php/f ... eeza_1.mp3
http://www.gitaar.net/forum/index.php/f ... eeza_2.mp3
http://www.gitaar.net/forum/index.php/f ... eeza_3.mp3
No volume problems at all, works like a charm. Here's my build, next to an original:
*edit* just so you know, all of the samples were recorded using a fender strat, into a hotrod deluxe. 8)
Can you post these? Great!
voland83
Post by voland83 »
Another reeza done, sound is nice. I still dont know what is the diffirence beetween 4069 and 75hct04, i suppose that second ic provides harder clipping as 74hc04 is hi speed cmos inverter. I use analog key and flip flop as a bypass rather than dpdt switch, as opposed to DPDT analog key has resistance about 100 Ohm which in my opinion is meaningless. excuse my english. :)
my reeza inside
my reeza inside
miwanone
Post by miwanone »
Nice build!
I attached my eagle files, for anyone interested. Not the best pcb I've done, but it works.
reeza.zip
(849.88 KiB) Downloaded 1057 times
botti1988
Post by botti1988 »
thank you for your work!
anyone has tried to insert an output buffer and make the pedal true bypass?
results?
thanks and sorry for my english :mrgreen:
voland83
Post by voland83 »
actualy a real true bypass depend on a non buffered signal, which means you have a direct connection beetwen guitar and amp, when you insert buffer it becomes a no true bypassed effect. besides this effect has buffered bypass and in my opinion it is better because this kind of solution eliminates a bad influence of capacity of shielded cable ( if its too long ), and sound is more crystal than moody.
Xide88
Post by Xide88 »
Need help!!! i have built one, it works, but in some ways:
- when tone control is set to more or equal than 55-60 percents
- when bias control is set to 40-45 percents
It is produce buzzing hum, something like sound of bees, and problem is not in adapter :(
When it buzzes, i changed controls of drive and volume, but hum is becoming more silent :x
What the reason of this? :scratch:
I use this layout to built pedal, i am not newbie in making pedals :D
mictester
Has thanked: 32 times
Been thanked: 845 times
Post by mictester »
Xide88 wrote:Need help!!! i have built one, it works, but in some ways:
That's a pretty layout, but it's very poor electronically. :cry: It's too crammed. You've got several high gain stages, and there will be interaction between them because the components are so close. :idea: Take all the parts off the board, throw the board away, and design a new, bigger one, with more spaces between the stages. The original Emma board is MUCH bigger - and now you can see why.
Xide88
Post by Xide88 »
Oooooohhhhhhhhh :( i am depressed((((
Thanks a lot for the answer!!!! :D I will make another one!))
distortion_gfx1
Has thanked: 26 times
Post by distortion_gfx1 »
I used the same layout.. it works just fine!
I only got Humming sound when i set the drive pot max.. (well i guess it is normal coz its a dirt pedal) and the thing that bothers me is the Bias knob.. it hums when i set it to zero! (dont know why.. :scratch: )
extremist
Post by extremist »
Hello! I've got a question regarding the schematic: are LEVEL and BIAS pots connected correctly there? Looks like they are flipped by 180 degrees (comapred to guts shots on the first page). Am i right or it's just doesn't matter for B pots?
chi_boy
Been thanked: 13 times
Post by chi_boy »
mictester wrote: That's a pretty layout, but it's very poor electronically. :cry: It's too crammed. You've got several high gain stages, and there will be interaction between them because the components are so close. :idea: Take all the parts off the board, throw the board away, and design a new, bigger one, with more spaces between the stages. The original Emma board is MUCH bigger - and now you can see why.
Sorry for bringing back such an old thread.
I'm trying to learn Eagle and thought I would try the Reeza just for kicks. I saw this post and I'm concerned my board may be too cramped, as was suggested about the other layout. Anyone care to offer any comments?
For the record, this is based on miwanone's schematic work.
This isn't verified yet either.
Thanks,
G
thn.technik
my favorite amplifier: Laney
Completed builds: Shred master, Tube screamer, Reezafratzitz, SansAmp GT2, RAT, Okko Diablo, Metal Simplex...
Been thanked: 44 times
Post by thn.technik »
some tone mod for Reeza, bass and mid control
distortion_gfx1
Thanks,
G
Great! this would fit a regular BB size Taiwanese enclosure..
thn.technik
small improve for tone modification, BASS and MID control,
in middle positions original tone characteristic, enjoy :D
Barcode
Been thanked: 32 times
Post by Barcode »
Thanks,
G
I would just build your layout and see if you notice any noise issues. Mictester is a bit deranged when it comes to layout. There are very few cases where layout makes significant impact in the realm of 9V stompboxes (though it does happen, for example in super high gain circuits like the dr. boogie). Build it first, if it works and there isn't any excessive noise, you are golden.
thn.technik
This is my final version of Reeza, with tone modification, middle and bass control added, it's working perfect :D
REEZA_THN_PCB.pdf
PDF export for printout
(23.74 KiB) Downloaded 375 times
thn.technik
sorry for "post by post" but: Where is "EDIT" button ??? I can't find it :D
here was small not correct route (to close):
This was to close, sorry
better one
better one
REEZA_THN_PCB.pdf
(23.45 KiB) Downloaded 350 times
thn.technik
My Reeza ;-)
ballfire
Has thanked: 38 times
Post by ballfire »
hello
is there an existing schematic of Emma - Reezafratzitz II ?
Grendahl
Been thanked: 7 times
Post by Grendahl »
ballfire wrote:hello
Go back a page?
https://www.freestompboxes.org/viewtopic ... 20#p131323
Resistance is futile...
( if < 1 ohm )
