Wampler - Triple Wreck [traced]
- caspercody
Mullisman,
I am interested in your Eagle files for the layout.
Rob
Rob
- MullisMan
- my favorite amplifier: Dr. Z Maz 18 Jr.
- Completed builds: Timmy, Klon, Zendrive, King of Tone, Rat, BSIAB2, Riot!, Fuzz Factory, Coloursound Overdriver, Divided by 13 Joyride, 70 Fuzz, BBE Sonic Stomp, Big Muff PI, Xotic EP Booster, Lovepedal Eternity, Jack Orman Minibooster, Dynacomp/Ross/Keeley Compressor, SHO
- Has thanked: 4 times
- Been thanked: 55 times
I'll PM you caspercody.
I want to build it all.
- MullisMan
Here are my eagle .brd and .sch files. There's also a partslist for ordering. This hasn't been verified yet but it should work no problem. I don't know about squealing from the high gain circuit, and some things can get kinda tight in the layout.
- TripleWreckEAGLE.zip
- (44.69 KiB) Downloaded 1064 times
- jstbrowsin
- Grease Monkey
Just so everyone knows I wasn't commenting on the triple-wreck my comment was on the spam that was posted before my post and has since been deleted. Maybe one of the mods could delete my post please? Save some confusion
- MullisMan
Yes, the smaller board is for the boost section, and I used a Va pad to provide power from the larger board's power section.
- MullisMan
Looks good emman_t, did you use my layout and modify it a little bit? That looks a little smaller than my board.emman_t wrote:
That's funny dude. No, I didn't use your layout, of course. . Does it looked like "modified a little bit" to you?MullisMan wrote:Looks good emman_t, did you use my layout and modify it a little bit? That looks a little smaller than my board.emman_t wrote:
- batteryacidtea
WTF! "That's the spirit"
- MullisMan
Audioguy I should be boxing mine up soon once I get the remaining parts in the mail, I can let you know when I've verified it.emman_t wrote:..not for you, dude..audioguy wrote: Any chance you can share your verified layout?
- audioguy
Awesome, thanks!MullisMan wrote:emman_t wrote:..not for you, dude..audioguy wrote: Any chance you can share your verified layout?
What means ? the boost switch add a 1UF condenser?Eisy wrote:EDIT 2: in boost mode C5 is 220NF || 1UF = 1.22UF...
I made one but :
-in the "cream" circuit if I don't use a lower resistor insted of 47K in the transistor the circuit don't work.
-the mid control have subtle effect, I realy don't understand how it works.
Any other have the same problems?
Yes, the boost adds 1UF (connected in parallel to 220NF).andreaps72 wrote:What means ? the boost switch add a 1UF condenser?Eisy wrote:EDIT 2: in boost mode C5 is 220NF || 1UF = 1.22UF...
I made one but :
My cream circuit works very well.
So I need a 4 deviator switch or a mil. bypass to light up the boost led.
With the 47K resistor on the collector of the 5089 I have only 0,4V and obviusly don't work, with a 22K I have the standard 4,5V with a 9V fresh battery and works well.
But the problem remains in the middle control, checked several times but don't work like in the videos of the original.
