Wampler - Plexi-Drive  [traced]
indyguitarist
Been thanked: 161 times
Post by indyguitarist »
HEAD wrote:Yeah of course we've got a detailed shot of the component side. What we need ist a detailed gutshot of the trace side which you could kindly provide so that we can draw the schematic and then might be able to help you. A detailed shot of the trace side alone isn't always that helpfull, you know? ;)
Doesn't seem like a whole lot to reverse... as I already said, start with the cranked AC and change the values a bit to be a bit more beefy at the front end. It's very simple - just a couple of jfet gain stages with a dual low pass filter on the end (like ROG, BSIAB, etc). Tone control is in the same place - just a pot between a larger cap on the end.
azrael
Has thanked: 35 times
Been thanked: 88 times
Post by azrael »
Thanks Brian! Your insights and openness are greatly appreciated.
Guys, I'm sure mimicing the bypass capacitor and cathode resistor scheme of a JCM800 or plexi will get you reasonably close. This is what breadboards are for! :D
culturejam
Has thanked: 433 times
Been thanked: 563 times
Post by culturejam »
This schematic was donated anonymously. :thumbsup
quaternotetriplet
Has thanked: 10 times
Post by quaternotetriplet »
culturejam wrote:This schematic was donated anonymously. :thumbsup
this is nice.. plexitortion would be next?
ecc83
Post by ecc83 »
whats means C7 105? or C2 222?
mrkaploca
Has thanked: 15 times
Been thanked: 12 times
Post by mrkaploca »
Those are the value codes printed on capacitors. For example 105 = 1mF , 222 = 2.2 nF
check this out: http://www.electronics2000.co.uk/calc/c ... ulator.php :wink:
lmkv15
my favorite amplifier: JTM45
Completed builds: Too many
Post by lmkv15 »
Change the 15K Drain resistors to 100K trimmer and it adjusts after hearing.
regards Uwe
andreaps72
Post by andreaps72 »
C3 47pF is obviusly wrong, 470pF (must be write 471) is right.
Used the Cranked AC Vero layout with little mod , works well.
andregarcia57
Has thanked: 73 times
Been thanked: 109 times
Post by andregarcia57 »
it's verified ?
hbo
Has thanked: 28 times
Been thanked: 196 times
Post by hbo »
Threw this vero together yesterday. It has been verified and reportedly sounds just like in the videos.
Ghandi
Been thanked: 28 times
Post by Ghandi »
the plexi-drive sounds very promising,
although I could see that if you use it with a blackface or with some kind of a jensen speaker it could miss some of the plexi/greenback mid punch.
maybe the bsiab2 aka box of rock tone control could solve this problem, I'll need to try that!
Anybody done that before? Brian have you experimented with different tone stacks?
I think the next one on my build list will be the run off groove thor.
So far I have build the BOR, Rust Driver, Purple Plexi...
ghandi
Herec
Post by Herec »
Anybody thoughts on using mustard-type capacitors for the larger values in the circuit?
Ghandi
Post by Ghandi »
I do that often with marshall inspired overdrives...
I did a box of rock with them and compared it with the regular unit, that was like night and day.
The mustard caps really bring the marshall mids to the front and also retain clarity like no other cap!
ghandi
grrrunge
Completed builds: Loads!
Has thanked: 50 times
Been thanked: 206 times
Post by grrrunge »
Consider this one "verofied" once more :D It's certainly going to cover that Hendrix/Clapton territory pretty vell...
whosyourdaddy
Been thanked: 7 times
Post by whosyourdaddy »
hey guys, I'm almost there, I'm getting faint signal on output, I think it's faulty tranny...
anyway is there someone willing to post voltages on trannies?
thx
grrrunge
Post by grrrunge »
whosyourdaddy wrote:hey guys, I'm almost there, I'm getting faint signal on output, I think it's faulty tranny...
thx
I'll hook my build up later, when i get off work. Meanwhile you could post pictures of your build, so the rest of us can check it out as well... ;)
whosyourdaddy
well there's nothing special about it, I think it's clean build...
Image Image Image :hmmm:
grrrunge
Post by grrrunge »
thx
I just got a lot of extra work on my hands, so i won't be able to do any fun stuff tonight. Sorry! It might be as late as wednesday or thursday before i get around to do some measuring... :(
whosyourdaddy
no worries I've solved the problem, I overlooked C6, thought it has one strip space between terminals. :slap:
now it sounds great, plexi sound it is. :applause:
here are voltages if anyone needs them: (supply 9.02V)
Q1: (DSG) 3.65V 0.36V 0V
Q2: (DSG) 5.37V 0.24V 0V
Q3: (DSG) 3.76V 0.35V 0V
grrrunge
Post by grrrunge »
whosyourdaddy wrote:no worries I've solved the problem, I overlooked C6, thought it has one strip space between terminals. :slap:
Good to hear ;) I like mine pretty damn good as well!
