Mad Professor - Snow White Auto Wah  [traced]
Nocentelli
Has thanked: 1155 times
Been thanked: 954 times
Post by Nocentelli »
Yep, I've got 2n5457s in mine and it works fine.
Nocentelli
Nocentelli wrote:Yep, I've got 2n5457s in mine and it works fine.
Sorry, meant to say I've got a 2n5457 nfet: I also subbed BC109cs for the BC550s and it works great.
crguti
Has thanked: 31 times
Post by crguti »
great thread. nice work guys.
Is there any available mod to this pedal?
roseblood11
Has thanked: 366 times
Been thanked: 314 times
Post by roseblood11 »
A reverse sweep would be really useful. I used that very often in my tonepad- version of the MXR envelope filter
sevinisthenumber
Been thanked: 29 times
Post by sevinisthenumber »
DimebuGG wrote:PCB layout...
Hey... I just cant get this to work. I have checked all that is possible. Is there any known issue here?
"The man who says he knows everything will never know the truth"
C.S. Lewis
ckyvick
Post by ckyvick »
Dimebugg's pcb(whatever the latest version was) has been verified working by a few people, I freaking love mine :thumbsup
mysticwhiskey
Has thanked: 42 times
Been thanked: 175 times
Post by mysticwhiskey »
Ditto, I made mine using Dimebugg's layout and have no problems at all.
bigmufffuzzwizz
my favorite amplifier: 1973 Sunn Model T
Post by bigmufffuzzwizz »
Thanks hbo's for your awesome vero layouts!
Magic Pedals Home of The Shrine Fuzz!
seedseed
Been thanked: 5 times
Post by seedseed »
Have any bass players out there tried this on bass to know how it responds i have heard some say its not good and others say its great on bass so iam confused as to wheather it is worth my time to build it or not :hmmm: I know they have released a bass snow white auto wah but as usual there is never any information on the bass one only the guitar one but i would appreciate any information anyone has on it. I don't think its just resistor changes as filters in most things if you know your filter theory need the value of capacitor changed as the reactance changes for different frequency ranges 1/2 pie resistor capacitor. But how to apply that to this circuit has me puzzled. Anyone Who has a bass one and would share some guts shots that would be fantastic. :thumbsup
roseblood11
Can I run this pedal with a 12V DC supply? Would it work properly?
Maybe the 58L05 could get to hot?
marshmellow
Has thanked: 20 times
Been thanked: 127 times
Post by marshmellow »
The 5V section of the circuit draws next to nothing, so no problem at all. :wink:
John3
my favorite amplifier: Musicman 210-65
Completed builds: BYOC 250+
1-Knob Fuzz
Orange Sunshine
Fuzzy Elephant
Master Volume SHO
Post by John3 »
I have a question about the 5 volt section. I had a mislabeled NTE 977 , turns out it was a 950 12 volt. So I sent more than 5 volts to the 13700 and everything else. Replaced the bad regulator with the correct one and the pedal works but does not get he same quack as some people's demos. So I am asking if there is anything in this circuit that would be fried buy this. The 13700 says that the supply voltage is 18 volts but the input voltage is 5 volt and my knowledge here is not that deep so any help would be great.
Thanks,
John
handlefras
Post by handlefras »
Just built this using DimebuGG's pcb. Thanks, great layout and a good sounding circuit. One question, what is the function of the cap labelled 100n on the pcb layout diagram (goes between the output of the 5V reg and ground)? Maybe this was mentioned somewhere in the thread, but I can't find it for the life of me.
Ice-9
Has thanked: 134 times
Been thanked: 359 times
Post by Ice-9 »
John3 wrote:I have a question about the 5 volt section. I had a mislabeled NTE 977 , turns out it was a 950 12 volt. So I sent more than 5 volts to the 13700 and everything else. Replaced the bad regulator with the correct one and the pedal works but does not get he same quack as some people's demos. So I am asking if there is anything in this circuit that would be fried buy this. The 13700 says that the supply voltage is 18 volts but the input voltage is 5 volt and my knowledge here is not that deep so any help would be great.
Thanks,
John
The 5v regulator in this circuit is to set a voltage around the bias control and rectifier stage that is a steady voltage when the battery voltage varies. With the associated circuitry around the this part or the circuit the control voltage send to the LM13700 is about 1.65v which varies slightly with the attack of the guitar being strummed. a 12v regulator would not work as your battery only has 9v anyway but it should not cause any damage at all.
tuck
Has thanked: 103 times
Been thanked: 97 times
Post by tuck »
Thank you Dimebug for the layout! I finished it a few weeks ago and it's just awesome.
Image Image Image
devastator
Been thanked: 22 times
Post by devastator »
ckyvick wrote:
devastator wrote:The signal goes into the filter whitout being changed (like a fixed wah ) .
Are you sure its not how you have it set? because it does a fixed wah too. if not it sounds like your wiring
Just a little back on that , actually I found the layout and see that a diode was wrongly placed. Works good now.
But seems a bit hard to set properly the circuit like mad proffessor says on his website. You have to be soft on pots . Really different than the Doctor Q I built .
Nocentelli
devastator wrote: But seems a bit hard to set properly the circuit like mad proffessor says on his website. You have to be soft on pots . Really different than the Doctor Q I built .
I've found this - There's a simple mod to improve the sensitivity posted at guitarpcb.com - I'll have a look for it - You just reduce a resistor value...
my7of9
Been thanked: 12 times
Post by my7of9 »
Here are a couple Mods with an explanation from our site (GuitarPCB.com) which some really seem to favor.
Install a 1N34 germanium diode in D6 and a 1uf electrolytic cap for C8 and the thing really came alive.Sounds much funkier clean and before a light overdrive it cops a great Garcia-Like tone.
In Regards to adjusting R18 as well as much more here is the explanation.
R18 mod - short answer - increasing R18 will allow you to set the Sensitivity more towards the 12 o'clock position. I'd go with a 47kΩ resistor here. The only advantage is being able to turn the signal down a bit further (50% to 0% is better than 20% to 0%) at the expense of turning the signal up (20% to 100% is better than 50% to 100%)
I hope the following will give people a general idea of what is happening in the circuit:
The circuit can be broken down into five main blocks:
Input buffer stage (blue) a high impedance input to get as much guitar signal as possible going into the circuit and a low impedance output to drive the next two stages.
State variable filter (yellow). Without getting too techie, this is the part that goes "Wah". If you are interested, look at the application notes (Google NE5517 or LM13700 data sheet) - warning !! this can be rather boring for normal sane people.
While we need to keep the signal going into the State Variable Filter (yellow) quite low, a slightly higher level signal might be needed for the envelope follower stages (green, pink and lilac).
The "green" stage boosts the signal, the "pink" stage converts the signal into a DC voltage, the DC voltage is proportional to the signal coming from the "green" stage - higher signal level, higher DC voltage level.
The DC voltage output of the "pink" stage drives the transistors in the "lilac" stage into producing a control current (more DC voltage at the base of Q2 means more current), the control current, which is connected to pins 1 and 16, tells the State Variable Filter (yellow) how much it should "Wah".
Since the question is about R18, a quick look at the "green" stage might be in order.
Nothing more than a gain stage. The gain is determined by whatever the Sensitivity pot is set at divided by the value of R18.
If the pot is set to 50% rotation, the resistance value of the pot (for a 100kΩ linear pot) is 50kΩ. Divide 50kΩ by 20kΩ - the value of R18 - and you have a gain of 2.5. If the input signal is 100mV, the output signal is 250mV.
So how did I arrive at a value of 47kΩ in the short answer ?
It would appear from many posts that setting the Sensitivity pot at the 9 o'clock position gives good results.
Since "9 oclock" is about 20% rotation, the value of the Sensitivity pot will be about 20kΩ.
The gain is therefore pot value divided by R18 which is 20kΩ / 20kΩ giving a gain of 1.
If I set the pot to 50% rotation, the pot value is now 50kΩ and if I change R18 to 50kΩ (47kΩ nearest standard value), the gain is 50kΩ / 50kΩ which is also a gain of 1.
It is possible to leave the value of R18 as it is (20kΩ;) and change the pot to a 47kΩ pot and still achieve the same results.
There is one other mod possible - called "side chain" which allows you to place effects such as fuzz and distortion before the auto wah and achieve good results. The only disadvantages are that you will require a simple buffer / splitter circuit (if you have got a Tonmann ParaMix available from GuitarPCB.com you won't need the extra circuit) plus you will need enough space on the enclosure to install another jack socket.
Nocentelli
Many thanks for that breakdown, i love my swaw and built the guitarpcb board as a paint-by-numbers exercise - Worked first time, which was brilliant considering this was my first go with anything more complex than a bigmuff. i've gazed uncomprehendingly at the schematic many times, so your explanation is much appreciated.
i'm planning another build, with a switchable fx loop pre-filter: if i want to use the pedals in the loop independently of the filter, do i have to wire it so the input buffer/splitter stage is permanently engaged? I don't mind doing this, btw, i wouldn't mind a decent buffer near the start of my pedal chain anyway.
John3
1-Knob Fuzz
Orange Sunshine
Fuzzy Elephant
Master Volume SHO
Post by John3 »
I just did the R18 and Cap mods, didn't do the diode, and it is a amazing change. I always liked the pedal, but this makes it breath so much more. It gets a better quack and the knobs seem to be much more responsive overall. Thanks for the tip. :applause:
