Death by Audio - Apocalypse [traced]
- Glass_Hero
- my favorite amplifier: My Glass Hero Amplification
- Completed builds: 1973 Orange Graphic 120 head
Fender Champ clone head
custom Pentode input single channel 20 watt head
custom "plexi" 5 watt single ended head
custom Pentode input single channel ~2 watt combo (smaller version of my 20watt)
( i build amps and pedals )
pedal clones
Pro Co Rat
Univox SuperFuzz
Sonic Edge J&J Overdrive
Interfax Harmonic Percolator
EHX Electric Mistress
EHX Big Muff PI
EHX Big Muff into a DBA Fuzz War
Green Ringer
Orange Squeeze
Boss Slow Gear
Death By Audio Sound SAW
Death By Audio Armageddon
Death By Audio Fuzz War
MXR Phase 90
EA Tremolo
TS 808
another TS808 modded out for bass
various loop, boost, kill, stutter, feedback and signal pad stompboxes
pedal modds
big muff clipping modds and internal feedback loops w/ LDRs
EHX POG exp pedal modd
VOX 847 wah modds (expression pedals should be expressive)
Cry Baby Modds
BOSS XT-2 modds
this list is tragically outdated.. - Has thanked: 12 times
- Been thanked: 118 times
- Contact:
i have apocalypse gut shots.. i'll give you a taste for now.. a quick explanation is the first function is just a twin t filter..second is the newer fuzz war circuit in the bottom right, third is the tl072 opamp, in between the 5 way rotary switch and the tone knob..the fourth is the octave clang circuit in the corner with the 741, transformer and Ge diodes in the upper corner..and then last one is called gain times 1000.. i have not traced down anything on this yet but i have schems for the fuzz war and octave clang..the input preamp is a 741 set up like it is in the octave clang.. i'll have more pics to post later..
- Emanuele
We want more!Glass_Hero wrote:i have apocalypse gut shots.. i'll give you a taste for now.. a quick explanation is the first function is just a twin t filter..second is the newer fuzz war circuit in the bottom right, third is the tl072 opamp, in between the 5 way rotary switch and the tone knob..the fourth is the octave clang circuit in the corner with the 741, transformer and Ge diodes in the upper corner..and then last one is called gain times 1000.. i have not traced down anything on this yet but i have schems for the fuzz war and octave clang..the input preamp is a 741 set up like it is in the octave clang.. i'll have more pics to post later..
- Glass_Hero
pedal clones
Pro Co Rat
Univox SuperFuzz
EHX Big Muff PI
Green Ringer
Orange Squeeze
Boss Slow Gear
MXR Phase 90
EA Tremolo
TS 808
pedal modds
Cry Baby Modds
BOSS XT-2 modds
- Contact:
most of the pics are large and somewhat fuzzy..i'll post them this weekend, maybe by then i'll have figured out the other two functions..
- culturejam
I split this into a new topic, as it is a different pedal (I think).
- Glass_Hero
pedal clones
Pro Co Rat
Univox SuperFuzz
EHX Big Muff PI
Green Ringer
Orange Squeeze
Boss Slow Gear
MXR Phase 90
EA Tremolo
TS 808
pedal modds
Cry Baby Modds
BOSS XT-2 modds
- Contact:
i think its a progression of a pedal design..the armageddon started an early fuzz war circuit (7 backwards transistors) mixed with a switchable filter section..as time when on he added more functions, the armageddon pedal Oliver (the DBA guy) uses for his band has the multiple fuzz circuit switch and the switchable filter sections.. if we can use these armageddon pics to figure out the two filter sections then putting that into an apocalypse would complete the package..culturejam wrote:I split this into a new topic, as it is a different pedal (I think).
in the movie Fuzz, he said something about the fuzz war being based on his distortion unit..and the quest for an ultimate distortion.. this armageddon pedal is an early step in that quest..
i feel as though the apocalypse and armageddon are the same unit just at different stages of development.. we can see from the pics of this armageddon that it is a 7 transistor fuzz war.. the sub switch opens up more bass frequencies (bigger input & output capacitors).. we have seen in the fuzz war thread how that pedal has changed over the past few years going from a 7 transistor unit to a 4 transistor unit (did i post the partial schem i did on the newer fuzz war yet?).. the apocalypse is a stripped down (missing the second switchable filter section) version of the newer armageddon design.. the fuzz war circuit in the apocalypse is the newer 4 transisor version (actually it only uses 3 of the 4 stages..the output buffer is left out)..
pause the video at about 3 seconds in, its an up-close shot of Oliver's armageddon pedal, it can be seen in the video there are 6 positions on Oliver's pedal.. and the second filter.. what do each of the postions do? not sure but my guess is that its pretty similar to the apocalypse fuzz selection switching..
but on to the real issue, the circuit.. and more pics, which i will be posting soon..
- Glass_Hero
pedal clones
Pro Co Rat
Univox SuperFuzz
EHX Big Muff PI
Green Ringer
Orange Squeeze
Boss Slow Gear
MXR Phase 90
EA Tremolo
TS 808
pedal modds
Cry Baby Modds
BOSS XT-2 modds
- Contact:
i have a schem.. and yes this is an updated, yet slightly stripped down ( no filter stomp w/ second filter, and fuzz circuit #6) version of an armageddon..
i wonder how pissed off the DBA guys would be if i were to post this schem??
- bubstance
If they sell a pedal the information inside is available to whoever opens it. Does it really matter if they get pissed off? I would vote share.Glass_Hero wrote:i have a schem.. and yes this is an updated, yet slightly stripped down ( no filter stomp w/ second filter, and fuzz circuit #6) version of an armageddon..
powered by 9front
- Glass_Hero
pedal clones
Pro Co Rat
Univox SuperFuzz
EHX Big Muff PI
Green Ringer
Orange Squeeze
Boss Slow Gear
MXR Phase 90
EA Tremolo
TS 808
pedal modds
Cry Baby Modds
BOSS XT-2 modds
- Contact:
37 resistors
27 caps
3 ICs
1 Transformer
5 transistors
4 Ge Diodes
3 pots
1 rot_switch
1 stomp
1 LED
this is in no way a beginners circuit to build.. i have about 8 pages of schems from this pedal.. this will not fit well on vero-board..
27 caps
3 ICs
1 Transformer
5 transistors
4 Ge Diodes
3 pots
1 rot_switch
1 stomp
1 LED
- ieatyouforbreakfast
I'm interested to see the schematic for this. Still have it?
this, many times over. i don't know if i'll have the ability or the patience to build a clone, but i'd like to know what is going on in there. just to know and understand a bit more about what is required to make a great noise.bubstance wrote:If they sell a pedal the information inside is available to whoever opens it. Does it really matter if they get pissed off? I would vote share.Glass_Hero wrote:i have a schem.. and yes this is an updated, yet slightly stripped down ( no filter stomp w/ second filter, and fuzz circuit #6) version of an armageddon..
i would also be extremely surprised to discover that oliver has never used this site at some point for his own design research.
as the great steve zissou would say, we're not stealing anything, it's a scientific community.
It looks like this thread has been bumped several times over the last few years but the schematic never made it into any of the replies. Does anyone have it?
i'm here too...asking for this schem...!!!anyone??
- modman
- a d m i n
- Has thanked: 4411 times
- Been thanked: 2139 times
Who cares? It's your drawing and your copyright.Glass_Hero wrote:i have a schem.. and yes this is an updated, yet slightly stripped down ( no filter stomp w/ second filter, and fuzz circuit #6) version of an armageddon.. i wonder how pissed off the DBA guys would be if i were to post this schem??
turdadactyl wrote:It looks like this thread has been bumped several times over the last few years but the schematic never made it into any of the replies. Does anyone have it?
tsume67 wrote:Someone has the schematic? I am very interested in this great pedal.Please
ieatyouforbreakfast wrote:I'm interested to see the schematic for this. Still have it?
Guys, this isn't helping. Buy, borrow or steal the pedal and trace it yourself.ksenanekro wrote:i'm here too...asking for this schem...!!!anyone??
He's really only a glass hero
- Cannibal
Done and tested, I'd say verified.
That's my take on the DBA Apocalypse, reversed from an original a friend owns.
Hope it helps.
Enjoy.
Updated files are here
Hope it helps.
Enjoy.
Seiche wrote:there's a difference between being drugged (I don't think it was only booze) and retarded.
