- DEMETER TREMULATOR trace artwork.gif (6.25 KiB) Viewed 3745 times
Demeter - Tremulator [traced]
- monkeyxx
sorry, it was a good layout, it just lacked a few labels to tell what certain solder pads went to, which way to put in the vactrol, and the blend pot was wired in wrong resulting in no tremolo sound. I went nuts though and put all kinds of labeling all over it, I guess I like to do that. thanks for the layout by the way, I used yours over two other options I had
- monkeyxx
yeah it was a very straightforward modification... just omit one capacitor (no trace modifications) and go through and trace the rest of the circuit and put in the Demeter values part by part. I was surprised at how many differences there were in part values, given that the sound ends up being quite similar between the two. I like having the volume trim pot from the Fulltone, even though I just leave it on full anyway.
- Barcode
The only thing wrong with the blend pot wiring on the layout is that I didn't note that blend lug 2 also connects as effect output. Otherwise, I've built that layout as is, so I can guarantee you aside from that note that it works as indicated.monkeyxx wrote:sorry, it was a good layout, it just lacked a few labels to tell what certain solder pads went to, which way to put in the vactrol, and the blend pot was wired in wrong resulting in no tremolo sound. I went nuts though and put all kinds of labeling all over it, I guess I like to do that. thanks for the layout by the way, I used yours over two other options I had
- monkeyxx
really? I thought 1 and 3 and 2 of that pot at least two were going to the wrong place. maybe it was something else in my build that caused the hiccup when I was also changing that part of the build. if you built it and it worked i guess that speaks for itselfBarcode wrote:The only thing wrong with the blend pot wiring on the layout is that I didn't note that blend lug 2 also connects as effect output. Otherwise, I've built that layout as is, so I can guarantee you aside from that note that it works as indicated.monkeyxx wrote:sorry, it was a good layout, it just lacked a few labels to tell what certain solder pads went to, which way to put in the vactrol, and the blend pot was wired in wrong resulting in no tremolo sound. I went nuts though and put all kinds of labeling all over it, I guess I like to do that. thanks for the layout by the way, I used yours over two other options I had
- monkeyxx
here's my build... the guts aren't worth seeing. I added the hard/soft switch from the Fulltone, it's pretty subtle, but there is a difference. It's a little smoother than other hard chop tremolo sounds I've heard
- roseblood11
There's a new version with some useful additions:
http://www.demeteramps.com/index.php?ro ... duct_id=99
I'd really like to see the schematic.
- modman
- a d m i n
- Has thanked: 4394 times
- Been thanked: 2131 times
This is a different pedal than the V1, it should get its own thread -- if there is any inforoseblood11 wrote:There's a new version with some useful additions:
