Chandler - Tube Driver (rack version)  [schematic]
DahakaNishoba
Post by DahakaNishoba »
Ok I got a RACK VERSION of a rev1 chandler tube driver...BUT...this has been modified by the previous owner
He's an acoustic guitar master and used this ONLY as a preamp...so asked a tech to modify this to REMOVE any drive or distorte signal
I can provide gutshots of everything inside but its modified so the request is
ANYONE HAS a PCB LAYOUT/PHOTO/ or actually a rack like the one I have...just Open it and give me some info
i cant really see any sign of mod (apart from some "new" resistor or unsoldered holes in the pcb ) but without anything of original ones its really hard to do something
Again i can post pics if anyone is interested...is a rack version with
DRIVE
BIAS
MASTER
CONTOUR
3 EQ
The way electronics work in a stompbox is like the way pixels move in a videogame
it's Magic, in Technology
Has thanked: 232 times
Been thanked: 888 times
Photo's? A few shots on the wiring only.
preps this helps:
http://www.dirk-hendrik.com/temp/Chandl ... r_Rack.pdf
DahakaNishoba
ok that was WAY helpful
now I have something to work with.
anyway I just unmounted/unscrewed the pcb pots and jacks....everything seems at his place...even solder joints....seems "original" but the sound is WAY different than an original one... :hmmm:
anyone has a shot of both sides of pcb ? (or even only component side) at least I wanna kno if a pair of unsoldered ground pads are normally empty or theres something wrong
DahakaNishoba wrote:ok that was WAY helpful
I serviced one of these a few weeks ago. (hence the schem) Shoot some pics and I'll tell you more if I can.
Edit; the owner sent me pics prior to shipping the unit:
and now you have all I have ;)
DahakaNishoba
Hmmmm huge thanks....ok so there are empty pads even in original one...I can't notice nothing major...just a different transformer (mine seems newer or just in better conditions....will shoot some macro of the inside tomorrow mornin...
sadrew
Been thanked: 14 times
Post by sadrew »
Hi everybody,
I am in the process of making a diy project for this little beast!
I am redrawing Dirk's schematic on Eagle and next step will be making a board layout, obviously available for everyone.
I am asking if someone would be so patient to contribute and give a look to my schematic. I am mostly interested in checking potentiometers orientation, jacks normalling and spotting overall mistakes.
Many thanks in advance
sadrew
Post by sadrew »
It seems I can't upload the schematic in the attachments... What's happening?
sadrew
Post by sadrew »
Here it is
sadrew
Post by sadrew »
come on guys! :roll:
sssteeve
Post by sssteeve »
I was wondering if anyone has a schematic for the Chandler rack mount TDR-101 Tube Driver. It is quite different from the original 4 knob pedal- which I bought in 1986/7 but traded in a year later for the rackmount version. :slap: (I should have gotten suspicious when the store was offering me the full price I had paid for it toward the "new and improved" model... in most cases it would have been 50-70% of what I paid originally.)
I thought that the rackmount version was too harsh so I added a cap or two (somewhere!) to mellow things out. I'm glad to have found the schematics for the original 4 knob floor pedal here- I hope to rewire my rackmount POS as the 4 knob floor pedal. (One good thing about the rackmount version was the boost switch- I may try to incorporate that into the good design.)
Thanks for all of the great information on the Tube Driver!
Steve Ahola
P.S. About 15 years ago I got a box of 3 or 4 broken rackmount TDR-101's from Dan Torres for $10 so now that I have the real schematic I will see what I can do with them! (I just need to remember what I did with that damn box!)
Reason: Post moved to Chandler Rack thread : have a little search next time... ;)
The Blue Guitar
www.blueguitar.org
Bernardduur
Has thanked: 94 times
Been thanked: 737 times
Post by Bernardduur »
@ Dirk; I traced a repair here. Only difference with your unit is R17. That resistor here is only 2k2 (22k in your unit).
Vicus
Post by Vicus »
Does some one have the schematic of RT-913? The six knob version.
Has thanked: 1675 times
Been thanked: 1360 times
Post by Manfred »
Vicus wrote:Does some one have the schematic of RT-913? The six knob version.
Sorry, the RT-922 only.
RT 922-924 Switching-FX loop.pdf
(154.11 KiB) Downloaded 306 times
RT 922 preamp.pdf
(178.94 KiB) Downloaded 388 times
stojanos
my favorite amplifier: fender 57 deluxe
Completed builds: Baja Real Tue Driver, Really Cheap Compressor
Post by stojanos »
sadrew wrote:Here it is
Can you send me the eagle schema file that you created ? I would like to build a PCB layout from schema and not from image files that can be found on Baja post. I promise that I will share it here.
Thanks.
