Kingsley - Minstrel [traced]
- mmolteratx
- Degoop Doctor
That looks better. Basically you just need them to be parallel for the majority of the run to cancel as much of the radiating magnetic field as possible. Really you could ignore the 8.1 resistor and halve the current and decrease the field strength as a result.
- jwpartain1
What kind of supply is this little guy running off of?
- mmolteratx
- Degoop Doctor
12VAC. Then the transformer steps it up to around 240V.
- mmolteratx
- Degoop Doctor
- Frabbio
Ok, i had confirm of what i said before by looking at the gutshot, the primaries are wired in series, the secondaries are wired in parallel, applying 12 volt on a 7 volt transformer gives higher anodic tension.
- Liquids
I've been using a chassis not a stomp box tube pedal I'm working on from the ground up (and will be able to switch it remotely via a small box on my pedal board from wherever).
I don't like that the Kingsley products use a passive & primal 3-band EQ, which is invariably mid-scooped and then will go into a typically mid-scooped amp = harsh sound, from my experiences.
A baxandall can at least be set flat and has much better control over restoring bass lost in the gain stages trying to keep things from being mushy.
Those in the US - Allied has multiple very cheap chassis-mount transformers that would be perfect for tube preamps if you arent' trying to squeeze everything into a stompbox. If you are there are still choices albeit restricted in voltage etc...the classis fender standalone reverb unit and champ power transformers should be more than adequate as well if they meet your voltage requirements...tubesandmore.com and allen amplification also sell tube preamp power transformers.
I'm liking mine alot, and avoiding the lame step-down wallwart for 12v heaters---> step up transformer for plates by simply wiring a power cord to a regular transformer is nice.
Heck, EHX used mains power and a internal transformer for quite a few of their classic pedals. And I suspect that if one could get a hold of one of their classic over-sized flimsy enclosures it would be plenty of room for a transformer, 2 preamp tubes, turretboard and stompswitch if you MUST have your preamp on the pedalboard.
- jwpartain1
Frabbio could you post a file with just the traces? I'm interested in etching this one
- mmolteratx
- Degoop Doctor
Mine sounded great but I ran it into a THD with a James tone stack.Liquids wrote:I've been using a chassis not a stomp box tube pedal I'm working on from the ground up (and will be able to switch it remotely via a small box on my pedal board from wherever).
- Intripped
Can someone reuploaded the schem and board layout. Thank you.
Hello everybody,
Could someone propose a suitable bridge rectifier (component part number) for this project? (According to the schematic, there are two.) Also, some examples of this pedal version were made with a "sizzle knob" at the rear. (See picture)
According to a website, "turning the knob all the way down takes it out of the circuit giving you a stock Minstrel V1. Turning it up adds extra top end sizzle."
Does anybody know exactly how to wire this knob and what value and type it should be?
Thank you all and happy new year 2023!
- ppluis0
Hi rantony,
Found in the web a gutshot of a Kingsley Jester that looks to be same power supply topology depicted in the previous schematic:
The board that includes the fuse holder have a 1 Amp diode bridge for the high voltage. The commercial denomination of that bridge is "W10"
Also four discrete 1N4001 diodes to feed the heaters of the tubes can be seen at the right of the fuse.
Happy new year !!!
EDIT:
There is a picture at the very beginning of this thread that shows the internals of a Kingsley Minstrel where a couple of diode bridges are installed at each side of fuse holder:
Hi Jose,
Hi ppluis0 !
Thank you for your answers! I knew those bridge rectifiers were a standard thing but wasn't sure about the specs needed. I'll look for some W10 for a clean work.
Now, another question I forgot to ask in order to have all the correct information prior to start building the project:
On the schematic, we can see two voltages from the power supply: V1 and V2. Are these voltages identical??? Also, where exactly do we connect these voltages? My assumption is that R4 must be connected to R7 and that R11 must be connected to R15. I suppose that one voltage goes to R4-R7 and the other one goes to R11-R15. In other words: one voltage for each valve. If so, how am I supposed to know which voltage (V1 or V2) must be connected to which valve?
PS: Regarding the sizzle knob mentioned in my previous post, I'm very curious to see if someone will be able to provide some "secret" information...
Hi ppluis0 !
- ppluis0
Hi Tony,
The tradition in tube power supply is that the most sensitive stages need Vcc more filtering.
So, the point taken from C6 is to feed the first tube (the two triodes at left of the diagram) and the node comprising C15 is connected to the second tube that has the tonestack and drive the output jack.
I'm also intrigued about the sizzle potentiometer...
