Stick on copper traces...
Wanted to say hello and thanks. I've lurked around here for a year and finally joined. I've learned a lot from you fine folks and hopefully this little tid-bit will be found useful by someone else.
I made the traces with copper tape normally used in making stained glass. You can take a hobby knife and slice it into strips small enough to just cover one set of holes in your perfboard, or if the circuit is small enough, you can just use it as is, but it will double the size of the board. That wasnt a problem for this project. I hate doing point to point because of the time, and I dont have any vero around, so I got creative.
It's $5.99 for 36 yards!!!! Thats enough to do about a trillion Bazz Fuss pedals.
I've thoroughly tested it and it seems to work. Voltages stay whee they are supposed to and its easier than point to point. Just takes a few minutes up front to apply the strips.
- phatt
- Transistor Tuner
Good on You,
I love it when people are forced to be inventive ,, some great ideas come from that.
One Q, How does the heat from soldering effect the glue?
Phil.
Phil.
- Hides-His-Eyes
Nice technique! And you can use it for shielding guitars too.
It'd be amazing if someone made this stuff in 0.08" width; then you really could just make your own PCBs by hand fairly easily.
It held up really well. No problem actually. I thought about putting a squiggly line of hot glue across the bottom when i was done just to make sure it stayed down, but so far so good.phatt wrote:Good on You,
Phil.
- DaveKerr
- my favorite amplifier: Ampeg M-15
Dynacord Preference 500 - Completed builds: Fuzz Face (2)
Tonebender MKII (3)
ROG Tri-Vibe
PAiA Ring Mod kit
Ring Mod based on Tim E schematic (2)
Rangemaster
CNO
ROG Splitter-Blender
Clari (Not) cubed deluxe - Location: Boston MA area
- Has thanked: 53 times
- Been thanked: 10 times
How thick is the adhesive on this stuff? Is it conductive?
... multiple LFO waveforms (saw up, saw down, triangle, square); a more flexible envelope with attack/release controls as well as inverted envelope. I am afraid it will have more knobs than the TGP annual convention - frequencycentral
Its super thin stuff, and the adhesive is clear to the point that you can see the copper through it so well, you can barely tell you're looking at the sticky side. So far my voltages are all what they should be at all points, and the adhesive is only on the copper. you dont have to spray the board or manually glue it down. Its like a big roll of pin-striping material. Just copper instead of vinyl.DaveKerr wrote:How thick is the adhesive on this stuff? Is it conductive?
Its made to solder/heat on anyway I think. I believe its what the stained glass folks do their patterns then heat and do their "lead" lines or whatever they are called.
- deltafred
- Opamp Operator
IIRC you wrap it over the edge of each piece of glass then get a bigass soldering iron and solder all the pieces together using plumbers solder. (Not that I have ever had the urge to make stained glass windows or lamp shades you understand)rwebbart wrote: Its made to solder/heat on anyway I think. I believe its what the stained glass folks do their patterns then heat and do their "lead" lines or whatever they are called.
That makes more sense. Either way, I guess its designed to handle heat.deltafred wrote:rwebbart wrote: IIRC you wrap it over the edge of each piece of glass then get a bigass soldering iron and solder all the pieces together using plumbers solder.
- phatt
- Transistor Tuner
rwebbart wrote:It held up really well. No problem actually. I thought about putting a squiggly line of hot glue across the bottom when i was done just to make sure it stayed down, but so far so good.phatt wrote:Good on You,
Phil.
Brilliant,, Do we have a medal for best invention of the month?
If we did you would get a vote from me.
Phil.
- SpencerPedals
Indeed the coolest new DIY pedal idea in a while. Congrats! Heading out to my workshop in a bit, where over the summer I have been saving some thin slivers of various woods: spalted maple, birches, swamp cedar, etc. I'm thinking some of that combined with this technique could yield a very cool looking "pcb". Similar to what Boris did with blind copper rivets. Perhaps a mixture would be even better.
- DaveKerr
Tonebender MKII (3)
ROG Tri-Vibe
PAiA Ring Mod kit
Rangemaster
CNO
The question about conductivity was relative to the idea of using this stuff for shielding - overlapping rows of this to shield a cavity might need to have some bare wire soldered across the layers if there's no continuity. This is a really neat repurposing of material - what was the source?rwebbart wrote:Its super thin stuff, and the adhesive is clear to the point that you can see the copper through it so well, you can barely tell you're looking at the sticky side. So far my voltages are all what they should be at all points, and the adhesive is only on the copper. you dont have to spray the board or manually glue it down. Its like a big roll of pin-striping material. Just copper instead of vinyl.DaveKerr wrote:How thick is the adhesive on this stuff? Is it conductive?
Thanks guys. Ive always made my living as an artist/photographer/animation and sourcing alternative materials for projects has always been a part of my life.
Now I understand you conductivity question. The answer is, I dont know, but ill test it tonight. If you look at the places in the pic where my "traces" overlap (at the T shapes) you will see where I just put a dab of solder to make sure the juice had a path to flow. But when I get home tonight ill check.
- mictester
This looks brilliant!rwebbart wrote:Wanted to say hello and thanks. I've lurked around here for a year and finally joined. I've learned a lot from you fine folks and hopefully this little tid-bit will be found useful by someone else.
Where can you buy it? Is it available in Europe? Is there anyone in the USA that will send me some in exchange for BBD or something?
- deltafred
- Opamp Operator
- mictester
I've just bought a big reel of the stuff. It also looks great for RF prototypes that I have to build from time to time.
- earthtonesaudio
- Transistor Tuner
This is a great discovery/idea. Thanks for sharing!
I didnt get around to testing it last night, but from what I've read this morning, the adhesive IS conductive on most brands AND they sell it in thinner sizes than what I have.
I think my next project, im just going to split it down the middle and use it on a blank (un-drilled) board material and drill out my own holes. I dont have a local source for blank un-drilled PCB material, so can I use a small plastic sheet or is there a better material out there that is non-cunductive, rigid, and thin?
- culturejam
- deltafred
- Opamp Operator
I wouldn't rely on the adhesive being conductive but a dab of solder at junctions, as you have already done, would be all that was required.rwebbart wrote:... but from what I've read this morning, the adhesive IS conductive on most brands AND they sell it in thinner sizes than what I have.
... so can I use a small plastic sheet ...
It would depend on the melting temperature of the plastic sheet and how long you held the soldering iron on.
