Eagle Tips, Tricks, Help and other Useful Information
Re: Eagle Tips, Tricks, Help and other Useful Information
Postby Bside2234 » 10 Mar 2012, 16:41
Well it looks like you have "vb" coming off the supply filtering and "-vb" on the main circuit. If you mean for them to be connected, change the -vb to vb. If you don't mean for them to be connected there is nothing connected to vb or -vb.
Bside2234
Have thanks: 69 times
Postby Chugs » 10 Mar 2012, 17:03
Ah, I see. I have used differently labelled pads. Thanks.
Chugs
Has thanked: 59 times
Have thanks: 49 times
Postby Chugs » 10 Mar 2012, 21:12
What is the difference between using the LINE tool and the NET tool to connect components? I have watched a couple of Eagle video tutorials where the Line tool is used to connect components but I have also that using the Net tool is recommended to connect components.
Chugs
Postby marshmellow » 11 Mar 2012, 00:44
From the official tutorial: "Do not use the WIRE command to draw net or bus lines in the schematic. Use NET or BUS instead!"
Definitely recommended to read instead of watching videos by experts :wink:.
marshmellow
Have thanks: 124 times
Postby Chugs » 11 Mar 2012, 12:16
I agree. I should have read the official documentation first. :slap:
Chugs
Postby Bside2234 » 11 Mar 2012, 18:08
Crap! So I should have been using the Net tool and not the wire tool all these years!!!! :oops:
Bside2234
Postby ~arph » 11 Mar 2012, 19:38
Yes..
This will help you ensure everything in your schematic is connected properly in your PCB too.
~arph
Has thanked: 65 times
Have thanks: 170 times
Postby darthoverdrive » 21 May 2015, 16:59
If this is in the wrong area please let me know.
I have a design I want to share in the Ready To Build Projects if I can ever get the PCB portion done.
I’m using an opamp to create my ½ voltage reference. When I check for errors on my schematic I get the following errors;
OUTPUT and SUPPLY pins mixed on net VR. Also the POWER going to my opamps show a warning. Is it ok to approve these or is there something that I’m missing in the layout?
darthoverdrive
Has thanked: 118 times
Have thanks: 83 times
Postby grrrunge » 21 May 2015, 21:49
darthoverdrive wrote:If this is in the wrong area please let me know.
As long as "the error makes sense", it's okay to approve ;) I've had quite a few PCB's fabbed, with the two errors you've just mentioned. Those are more like "Are you sure this is how you'd like stuff done?" messages 8)
The reason the power pins throw an error is that they will automatically connect to certain nets (V+ and V- i think). The one with output pins to supply nets - no idea...
For this message the author grrrunge has received thanks:
darthoverdrive (22 May 2015, 12:14)
grrrunge
Have thanks: 207 times
Return to Software Room
