ToadWorks Mr Squishy Compressor [traced]
Nice shots. Do you know what the two 3-pin (transistors probably) TO-92's are on the board? I see one as 2N5457, but can't really see the other. I see the IC is 4558. Also do you know what that white-ish thing is next to the op amp? It kind of looks like a cap, but not sure.
- aegert
1) yes both Jfets are 2n5457's.
2) The white thing is a capacitor 560p
3) all al electro caps are 4.7u
4) greenie's are .1uf
I might not have time t take apart again and photo the switch and input but should be obvious
- phibes
- Transistor Tuner
Input control looks like a voltage divider on the input of the circuit with a treble bleed cap across lug 3 and 2. Rest looks pretty straight forward.
Ken
Ken
- pedalgrinder
your a legend aegert i've been hanging to see some guts shots of this. Any more pics would be greatly welcomed thanks
- aegert
Errr.. Thanks... LOL Its in my office I will pull it apart on Monday. Please post what shots you want. I will try to pull a complete parts list as well...pedalgrinder wrote:your a legend aegert i've been hanging to see some guts shots of this. Any more pics would be greatly welcomed thanks
A
- pedalgrinder
just a question from the pics have you modded this compressor or did the two resistors joined standing up come like that from the factory. Never seen a factory put them out like that. Although anything is possible. heres a interesting link on it http://www.ovnilab.com/reviews/squishy.shtml
- aegert
Hey got this on ebay used so it came to me that way... I just put it back up on ebay. Its a pretty transparent compressor. I got the Pigtronix Philosophers tone Gold. this is a bit heavier but the blend knob and tone feature make it more versatile. THe grit is usable with mod effects on its own its a bit fizzy. Should I take down the mr squishy from ebay and keep it!?!?!?pedalgrinder wrote:just a question from the pics have you modded this compressor or did the two resistors joined standing up come like that from the factory. Never seen a factory put them out like that. Although anything is possible.
- pedalgrinder
hey if it can be cloned you can have your cake and eat it too. just make a vero board version of it and sell the original once your clone is up and running. Thats what i would do personally.
- phibes
- Transistor Tuner
More pics would be good, specially round the greenies. The trace routing is a bit goofy so it's hard to make guesstimates.
Ken
Ken
- aegert
I took some more pictures and will try to post later but here are my notes from the board:
There were 1 or 2 that the color bands were really hard to read and the one cap un-noted on the bottom right was unreadable..
- phibes
- Transistor Tuner
I traced it out. Few differences, but nothing major. I'll draw it up in a bit.
Ken
Ken
- phibes
- Transistor Tuner
Not much is different besides the compression control. Cap on gain pot is unverified, it's prolly 220p.
- toadworks-mr-squishy.pdf
- (13.88 KiB) Downloaded 535 times
Ken
Ken
- pedalgrinder
fantastic job phibes i take my hat of to you. What program do you use to create your schematics they look great. Thanks in advance
- phibes
- Transistor Tuner
Good ol free Express Schematic. I modify a lot of the symbols to be easier on the eyes. I hate it when schematics are a mind fuck to look at with these bad eyes. Vector PDF ensures easy printing across all printers and computers. My widescreen monitor barks at a lot image files if the resolution isn't set right.
That PCB gave me a headache. Very very 2 layer autoroute and every possible connection was made and routed through the board. I can understand that when using board mounted parts but don't see the point when everything is external, if your gonna run a wire, why not just run it where it's gotta go.
Ken
Ken
- pedalgrinder
This one at least has a bit more control than the orange squeezer i'd build this before the squeezer bit more versatile.
Hi I build but no change for sound with squish/bias. OS have 2.4k feed to 10k gnd. toadwork seem like to many resistance. 6.2k feed to 10k with 22k strap make pot ~6.8 at max and 20k again parallel. even set to maximum resistance it seem still so much high over original os bias. I try change 6.2k with 2.4 original but no change. also so much bass lost with this. if you have build can you post reply so I can try to make correct?
