Arbiter - Treble & Bass Fuzz Face [schematic]
Thanlks but been there, done that...
I have this beast so I don't need the schematic or values; I can just look at my board.
It's the OFF BOARD wiring I'm interested in. I've done a fairly thorough web search & have come up dry. Any one have any other resources to the OFF BOARD WIRING? from the pictures on the web, it looks typically 'British'.
- phatt
- Transistor Tuner
Never seen one in the flesh but I was under the understanding that these unit where *positive ground*?? If so the then the pictures make sense as the red positive goes to ground.
Check the electros for clues as they will also be polar reversed.
Phil.
Phil.
- sinner
- Has thanked: 1031 times
- Been thanked: 909 times
phatt wrote:Never seen one in the flesh but I was under the understanding that these unit where *positive ground*?? If so the then the pictures make sense as the red positive goes to ground.
Phil.
Yeah, that sets me off. I did the wiring layout but stopped at battery connection. The schemo I have is for BC109, all we know thats NPN trannies....
- phibes
- Transistor Tuner
What's confusing about the off-board wiring? It should be pretty straight forward to figure out from the schematic regardless if it's it neg or pos ground.
Ken
Ken
- sinner
Not quite. Schemo screams for NPN silicons, and wiring picts shows positive (red wire) going to ground.phibes wrote:What's confusing about the off-board wiring? It should be pretty straight forward to figure out from the schematic regardless if it's it neg or pos ground.
- phibes
- Transistor Tuner
Ah I see. Well all wire coloring in the OP unit match all the old photos I got of other units so the off board wiring looks right. Two red wires look replaced but they we're hooked back up right, same with color. I never really looked closely at this one but yeah, the jacks are grounding to positive and the battery is being disconnected from the circuit off the positive wire so good catch there! I'm surprised that wasn't noted in the schematic in the other thread.......
Does the unit work?
Does the unit work?
Ken
Ken
- sinner
Want some more confusion?
E-caps on the same picts I was referring to are pointed negative to ground!
I say WTF?
I say WTF?
- DrNomis
- Has thanked: 98 times
- Been thanked: 278 times
Just wondering if anyone's finished building one of these and if so, how much bass/treble boost do you get with it?.....
- phibes
- Transistor Tuner
Yeah I can see the confusion now after eyeballing it. It looks wired for positive ground. It'll work either way as the electros are facing where they gotta go. I wonder why they did it that way? Did they do the same on the silicon Fuzz Faces?sinner wrote:Want some more confusion?
I say WTF?
Ken
Ken
- Electric Warrior
No, they're usually wired up correctly.
- gigelmargel
Hello all,
I want to build an Arbiter Bass/Treble Face, but I didn't find a layout of the parts. I've tried to retrace it using the photos from this topic, but I don't have enough skills to do that.
Can anyone help me?
Best regards,
Radu
Can anyone help me?
Best regards,
Radu
- LucifersTrip
- my favorite amplifier: Companion Psychedelic Machine
- Completed builds: Mosrite Fuzzrite (Si), Mosrite Fuzzrite (Ge)[2], Get Lo-Fi Fuzz, Fuzz Face (Ge) [2], Fuzz Face (Si) [3], Mos-Face, Vox Tone Bender, Kay Tremolo, Os Mutantes Fuzz [2], Psychedelic Fuzz, Smokey Amp, Sunn Buzz, Jen Fuzz, Fancy Fuzzbox, Muff Fuzz (op amp) [2], Buzz Box, Fuzz King, Rangemaster [5], Maestro FZ - 2/3, Ruby Amp, Orpheum Fuzz (Ge) [4], Great Destroyer, Schizo, Carlsbro Suzz, Shin-Ei Companion Fuzz (si), DOD 250 Gray [2], Super Dirt Fuzz, Fuzz Factory, Jordan Boss Tone, Sam Ash Fuzzz Boxx, Heathkit TA-28 Fuzz, Olson New Sound Fuzz, LRE Fuzz Sound, Green Ringer, Vox Super Beatle (Ge), Colorsound One Knob (Ge), Demon Buzzz [2], Demon Wasp v1, Demon Wasp v2, Super Hard-On, Bazz Fuss, Burns Buzzaround [2], Selmer Buzztone, Shin-Ei Companion Fuzz (Ge), Fuzz Face/FY-2 (Ge), Zonk Machine, Univox Squarewave, Demon Fuzzz, Mosrite Fuzzrite BG-500/1000 (Ge), Univox Superfuzz, Marshall Supa Fuzz, Demon Monster, AA Overdrive/ Retro Fuzz, Tone Bender MKII, Psychtar, Jordan Vica Vibe, etc...
- Has thanked: 19 times
- Been thanked: 71 times
- Contact:
- gigelmargel
Thank you LucifersTrip!
I've seen the schematic, but in the photos I saw some capacitors that I couldn't identify. I will try again, using both the schematic and the photos.
Best regards!
- LucifersTrip
- Contact:
Cool...if you find something different, let us know
- modman
- a d m i n
- Has thanked: 4394 times
- Been thanked: 2131 times
Arbiter - Treble'N Bass Face (1966)
- Arbiter - Treble'N Bass Face gut shot 3
- ff01_01.jpg (57.56 KiB) Viewed 2754 times
- The Rotagilla
If anyone saved the schematic could they re-post it? Thanks.
- roseblood11
