Emma - Reezafratzitz [ goop-alarm ] [traced]
Built this thing last week.
Didn't work in the first place, but later on I spotted a connection between traces due to a bad etch. After the fix it started working. Everything works well, sounds great, however i consistently wired all of the 4 pot meters backwards.
Here are some pics and will post some sound samples later.
Hi guys,
I do it again hehehe... it's my new THN Reeza
Housing it's a box from USB stick, no foot switch bcoz is always standing at top of amplifier( BTW it's my own production, ECL86, 3W for home use)
I found 2 pcs OKI MSN4069RS IC in my old video recorder, its work much better than MCY74049 which I use before, so I change it also in my old Reeza, now is clearly difference in bias potentiometer.
BTW I get question about potentiometer names, so once again schematic with descriptions And my small and simply amplifier Regards!
P.S.
Don't waste you time and build your own THN Reeza, it's great fun with this box
P.S.
PCB image is in mirror, so maybe try to turn up/down your IC 4069,soonerrob wrote:Ive built 2 of these from the THN project... 1 from the THN pcb layout and one of my own from the THN schematic... both circuits are dead.
both audio signal die at pin 1 of IC... not sure what is wrong.
notice also that you need to have UB - unbuffered version of CD4069
- Nicht Bernd
Hi,thn.technik wrote:I found 2 pcs OKI MSN4069RS IC in my old video recorder, its work much better than MCY74049 which I use before, so I change it also in my old Reeza, now is clearly difference in bias potentiometer.
do you know where to buy the OKI?
Hi, I have no idea where you can buy it, I just disassemble my old AKAI tape video recorder.Nicht Bernd wrote:Hi,thn.technik wrote:I found 2 pcs OKI MSN4069RS IC in my old video recorder, its work much better than MCY74049 which I use before, so I change it also in my old Reeza, now is clearly difference in bias potentiometer.
BTW all parts in my second Reeza are from this recorder
I find only one shop with this part:
http://www.accordtech.com/4069RS.html
I have used the 74HCU04 14 pin chip in distortion circuits designed for the 4049ube and they work very well. I'm not sure if the pins match up.
http://pdf1.alldatasheet.com/datasheet- ... CU04N.html
main problem with "classic fender" tone stack is that if you put 10V RMS at input then you get 1V RMS at output, so you need to do x10 amplifier for signal.XoB wrote:thn.technik, why you won't use of classic fender of marshall tonestack. If we'll take kind of fender tonestack we'll get more mids deep & possibility to get some freq distribution
- biliousfrog
- Completed builds: Zen Drive, Fuzz Factory, Really Cheap Compressor, D*A*M 66, Klon Buffer, CryBaby mods, Boss TR2 mods, Various loops and switchers, DOD250, Fulltone Bass Drive, MXR Bluebox mods
- Has thanked: 5 times
- Been thanked: 9 times
- Contact:
I just wanted to gloat a little - bought a mk1 for £40 inc. postage. Sounds great so far, really looking forward to cranking it through a decent tube amp at rehearsal.
It seems very well voiced, the tone control (just one on this) is perfect at 12 o'clock, same with the volume and bias...in fact I'd be happy just running everything at noon.
- IvIark
Forgot to post this:
Modified version with additional Bass and Mids controls:
Nice Job Guys!!!
- asatbluesboy
Loved the "circuit window". Why don't ALL pedals have that? Would save us a lot of trouble...
...collectors together and emitter to base? You're such a darling...
ton.
ton.
The problem is not that components are close to each other, but it has a very problematic ground. PWR GND and SIGNAL GND, there is no "star GND" point.mictester wrote: The original Emma board is MUCH bigger - and now you can see why.
- my favorite amplifier: JCM800
- Completed builds: BIG muff green version
JCM800 tube Preamp in a box
steampunk kitten ("original" recipe tube overdrive pedal)
angry kitten tube amp (5W EL84 evil little gainer)
JCM800 2204 replica amp
wampler triple wreck clone
reezafratzitz clone
Bsiab III
Crunchbox clone - Has thanked: 6 times
- Been thanked: 2 times
here's mine.
my first etched PCB.
and second wrong IC mirroring (its on the back of the board)
did the thn.technic layout.
man it was dark sounding.
changed the low pass filter after the tone control and voila
it sounds great now.
i used 470K pots instead of 500K.
could this make a big difference on the sound?
"JMP it's a good place to be" - Big Bob
