eruarou wrote:Thanks for your replies...
but then the question how to supress the interference? just by having a grounded case?! ...
i cant understand that... why that happens...
The case forms a Faraday Cage as long as it is grounded (see extract from wikipeadia below for how it works).
*When it is not grounded It will act as an aerial and pick up any radiated signals (interference) and will retransmit them to the circuitry inside the box.
(*This is the bit I am unsure of so if anyone has a better explanation please feel free to post it. I am sure this is a very simplistic explanation and there is no doubt lots of maths involved in the proper one.)
Wikipedia wrote:A Faraday cage or Faraday shield is an enclosure formed by conducting material or by a mesh of such material. Such an enclosure blocks out external static and non-static electric fields. Faraday cages are named after the English scientist Michael Faraday, who invented them in 1836.[1]
A Faraday cage's operation depends on the fact that an external static electrical field will cause the electrical charges within the cage's conducting material to redistribute themselves so as to cancel the field's effects in the cage's interior. This phenomenon is used, for example, to protect electronic equipment from lightning strikes and electrostatic discharges.
Faraday cages cannot block static and slowly varying magnetic fields, such as the Earth's magnetic field (a compass will still work inside). To a large degree though, they shield the interior from external electromagnetic radiation if the conductor is thick enough and any holes are significantly smaller than the wavelength of the radiation. For example, certain computer forensic test procedures of electronic systems that require an environment free of electromagnetic interference can be carried out within a screen room. These rooms are spaces that are completely enclosed by one or more layers of a fine metal mesh or perforated sheet metal. The metal layers are grounded in order to dissipate any electric currents generated from external or internal electromagnetic fields, and thus they block a large amount of the electromagnetic interference. See also electromagnetic shielding.
The reception or transmission of radio waves, a form of electromagnetic radiation, to or from an antenna within a Faraday cage are heavily attenuated or blocked by a Faraday cage.
