two in one out splitter box.
All frequent questions on switching: true or not true bypass, transistor-based or mechanical.
freq67
Post by freq67 »
I'm building a 2 in 1 out splitter for a friend and was wondering if there are any pit falls I should worry about in the design?
He want's this to be able to switch out guitars with out having to unplug them on the spot. Since this is a one out I'm pretty sure I don't need to worry about isolating because it's only going to one amp. Do I need to worry about isolating the input of the two guitars? Also since this is going to be a passive design I'm I going to have to worry about the switches popping Since there is no DC offset.
phatt
Been thanked: 343 times
Post by phatt »
You need buffers on each input.
All passive will mean you turn down the passive volume on one guitar then you kill the signal to both. :slap:
You can overcome that in a passive system but you loose signal strength for both and you then need to boost it back up.
you need a simple HiZ mix circuit run from battery.
Phil.
Nocentelli
Has thanked: 1155 times
Been thanked: 954 times
Post by Nocentelli »
Or a switch?
phatt
Post by phatt »
Your brain obviously working better than mine tonight :slap:
yep,, spot on and far simpler,, and passive
royzic
Post by royzic »
Here :wink:
you can replace the mix knob with two resistors
https://www.freestompboxes.org/viewtopic.php?f=13&t=6103
Good luck!
-Roy
freq67
Post by freq67 »
Ummm....I don't think I was clear....sorry about that. Both inputs will be switchable so there will be separation. :?
Nocentelli
A simple A-B box would do it, and I think it's unlikely to pop. Apologies to Beavis for jacking his picture -
freq67
Post by freq67 »
Nocentelli wrote:A simple A-B box would do it, and I think it's unlikely to pop. Apologies to Beavis for jacking his picture -
That's what I was thinking too but I was also thinking about turning them on/off each independently BUT I'm also worried about both being on accidentally. Haven't figured out how to wired them to be separate but not interact when both are on. My main concern about a switching back and forth scenario is let's say when A is turned off it goes right to B but B isn't ready yet and there is an unplugged chord making a lot of noise. My head hurts. BTW thanks all for the input.
phatt
Post by phatt »
Then purchase those guitar cords with the deadman switch built into the 6.5 plug end.
They ground the hot the moment they are removed from a guitar,, quite a clever trick.
Another possible fix is a floor mounted kill switch which uses a momentary switch to ground while changing leeds.
I personally don't like adding to much complexity to things as it often becomes just more thing to go wrong.
Phil.
freq67
Post by freq67 »
phatt wrote:Then purchase those guitar cords with the deadman switch built into the 6.5 plug end.
Phil.
Ahh........like the cord idea! Thanks!!!
freq67
Post by freq67 »
BTW with a 3P3T how could I wire this up for two LED's to show each input that is on?
rocklander
Has thanked: 1406 times
Been thanked: 231 times
Post by rocklander »
positive goes to the centre pin of the third pole... each of the two other pins feed positive to the LEDs
or reverse that... do same but earth/negative is the centre pin of third pole... LED negative to the outer pins
rocklander
dredge.
so, I'm looking at making a stompbox.. a proper one..
I have a wee looper, and I play acoustic guitar into it. I want to hook up a car speaker to a piece of plywood so I can thump my foot on it to get a 'drum' beat kinda sound.
I am thinking I'll stick an input jack on the thing that the guitar can go into, then the speaker +ve and the guitar+ve together to go out to the looper.
the big question is, will that be okay ? as a passive unit, or am I likely to have some problems? maybe the stomp signal going up to the guitar to cause some weirdery.. dunno.. I'd rather it was passive if possible, but i guess I could put a buffer in there if necessary... will that be necessary?
phatt
Post by phatt »
You won't hear much :blackeye as the speaker is likely 4 Ohm while your pickup (assuming powered preamp) is at line level.
You will need 2 separate circuits a two channel mixer of some sorts.
Phil.
rocklander
sweet.. I was wondering so thank you!
so a buffer on each would sort that out?
phatt
Post by phatt »
A buffer will only Isolate the two sources and you would then at least hear the guitar but the speaker as pickup will need a lot more than just a buffer.
Frankly a piezo transducer with a dedicated preamp will make for a far better setup. (IMO)
There are many types already on the market and most will work better than the old speaker as a mic trick.
Phil.
rocklander
thanks.. I've already ordered a piezo, but until that arrives.. I have a speaker, heh.
