Keeley Compressor C4 [gut shot]  [traced]
sadrew
Been thanked: 14 times
Post by sadrew »
sevinisthenumber wrote:Were do i place the pre gain knob into the circuit? Use a 100ka pot on the input as a variable resistor?
bump
gkoerselman
Been thanked: 39 times
Post by gkoerselman »
I assume that with the 'pre gain' you actually mean the 'clip' control (which is sometimes called 'clipping' or 'trim' I believe on the actual enclosures)...
This clip control is the 150k shown in my diagram connected by pad P1A-B and P2A-B.
irmcdermott
Has thanked: 18 times
Been thanked: 21 times
Post by irmcdermott »
So the trimmers are still in there? As well as the external pots? I'm just a little confused reading through the thread.
seedseed
Been thanked: 5 times
Post by seedseed »
Any verified schematics on this seems to be lying dormant
bubstance
my favorite amplifier: Lab Series L11
Completed builds: more than a few, less than a ton
Has thanked: 83 times
Been thanked: 116 times
Post by bubstance »
It's a Ross clone, so any Ross layout/schematic will do just fine. Also: viewtopic.php?f=7&t=4860#p64200.
powered by 9front
seedseed
Post by seedseed »
Yeah but for all the hype i've heard about this pedal it can't be exactly the same with all components there has to be some form of variation. I'd like to know what it is.
WhiteKeyHole
Has thanked: 24 times
Been thanked: 220 times
Post by WhiteKeyHole »
So buy one and be sure to tell us your findings.
bubstance
Post by bubstance »
seedseed wrote:Yeah but for all the hype i've heard about this pedal it can't be exactly the same with all components there has to be some form of variation. I'd like to know what it is.
Don't trust hype. Remember the hype about the CJOD? Turns out that wasn't very different. Remember the Saffron Squeeze? That was a Ross too.
Hype =/= different.
powered by 9front
seedseed
Post by seedseed »
Yeah no worries whitekeyhole with your money hahhaha
gormangox
Post by gormangox »
Fast attack (or recovery) is when the resistor is set to "near zero value" or when the resistor is 150K?
gormangox
Post by gormangox »
When that resistor is set to 10K I can hear only a little bit more volume but I can't see differences in the attack of the compression....
Can you explain to me which differences I should hear from a 150K to a 10K?
Which sound test can I make (playing the guitar) to hear better this difference?
WhiteKeyHole
seedseed wrote:Yeah no worries whitekeyhole with your money hahhaha
The Rotagilla
Post by The Rotagilla »
Crimson wrote:Sustain pot: are you sure is reverse log?
Yes.
IvIark
Has thanked: 562 times
Been thanked: 586 times
Post by IvIark »
Currently unverified but I'll let you know when that changes. Instead of using two 1K resistors I left the trimmer used in the Dyna Comp and Ross Comp in place, so if you leave it in its middle setting that would replicate the C4 with the added advantage of being able to fine tune the extremes of the Clip control.
Xavier
Post by Xavier »
Many thanks for this one (and ALL the rest), Ivlark !!!. What a monster job...........
Ang3lus
Post by Ang3lus »
yeah, thanks for this one :D
been wanting to try the keeley for ages.
IvIark
Post by IvIark »
The vero has been verified so it's safe to build :mrgreen:
pedalgrinder
my favorite amplifier: Ampeg SVT
Completed builds: pedals with pots switches and everything
Has thanked: 198 times
Been thanked: 173 times
Post by pedalgrinder »
great vero and thanks for the contribution but it's still not a verified keeley we still have no idea what's in and before someone says there fav comment of go buy it. We should do a tracers fund and contribute $10 bucks each so we all put in. I'll put in $10 anyone else up for it.
IvIark
Post by IvIark »
If we bought one via the tracers fund we'd end up with exactly the same gut shot as you already have on page 1 of this thread. So this is no more and no less verified than any other pic > trace > schematic > layout on the site. In fact the quality of the gut shot with trace and BOM by vietpham, this is likely to be more accurate than some of our other traces.
IvIark
Post by IvIark »
Just as a follow up to that, here's the gutshot with the missing resistor values:
Looks pretty accurate to me so I'm not too sure what else we could be missing.
