How do you transfer a schematic to bread board?
I'm kind of new at this and I was wondering, how to you guys look at the schematic and then come up with the layout? I've always had trouble following the schematic, and I can't see how you would be able to transfer the two. Any help would be great. Thanks.
- IvIark
Beavis Audio have a great guide From Schematic to Reality, check it out.
Wow, that's really helpful. The only thing I don't understand is what is the deal with the jumpering? Why are some of the spots on the breadboard jumpered?
Thanks for the schematic Madbean, it looks great. What do you have the two switches doing? I also think its cool how you put the trimmer for the treble on the top. Also, does any one have a breadboard layout for this by any chance?
- Greg
Breadboarding is generally an 'ad lib' sort of thing.. no-one is going to have or post a Breadboard Layout I don't think.. you would generally put it together stright from the schematic, then mess with it to try different things.PedalPlayer wrote:Thanks for the schematic Madbean, it looks great. What do you have the two switches doing? I also think its cool how you put the trimmer for the treble on the top. Also, does any one have a breadboard layout for this by any chance?
When done it all comes off the board for the next project.
If you have no experience with breadboarding and want to learn how to do it, you might want to consider something like one these:
http://www.indy-guitarist.com/inc/sdetail/100
http://www.beavisaudio.com/bboard/
Have fun.
Ok, thanks. Like I said, I'm really new at this stuff and I don't have a ton of experience with how it works. I didn't realize that was a stupid question Thanks for posting those links.
- Greg
No problem Pedalplayer.. I can see you're keen and that's great.
Ask away.. the board from Beavis would be a great learning tool I think, as well as something you'll continue to use.
You can also build something similar if you can't afford it or want to change something... Beavis has kindly included everything you need to duplicate it.
Yeah, I saw a link from the beavis site posted on here that explained how to convert a schematic to a breadboard and it really helped my understanding of it. There's still a bit more I need to learn about it, but it really helped my understanding.
Because of the way breadboards are laid out, you only have so many continuous rows. You need to run a jumper to connect the different strips to other parts of the board. Think of jumpers as traces on a circuit board - they are just conduits for electrons to flow to normally unconnected pathways.
-chris
-chris
"I've traveled the world and never seen a statue of a critic." -L.B.
-chris
-chris
Thanks for the response about the jumpers. That makes sense and that was what I thought they were for, I just wasn't sure.
Thanks for the links i just decided to give effects building a try and there is a wealth of information in these forums.
- bigmufffuzzwizz
- DrNomis
- Has thanked: 98 times
- Been thanked: 279 times
PedalPlayer wrote:Ok, thanks. Like I said, I'm really new at this stuff and I don't have a ton of experience with how it works. I didn't realize that was a stupid question Thanks for posting those links.
Personally, I think there's no such thing as a "stupid question", all questions are valid in my book, that's how human beings learn about things.....
- bigmufffuzzwizz
The man is correct! Accepting your newbie-ism is the first step to moving forward.DrNomis wrote:PedalPlayer wrote:Ok, thanks. Like I said, I'm really new at this stuff and I don't have a ton of experience with how it works. I didn't realize that was a stupid question Thanks for posting those links.
Magic Pedals Home of The Shrine Fuzz!
- geiristudio
Thanks for the link. I've been reading a lot and collecting information on pedals I would like to give a try building. I have the confidence to start building various pedals but lack the knowledge so this helped me very much! I'm a very fast learner because I give it all to the projects I work on, being playing guitar, recording music or something else. I always give 110% and try to learn as much as I can about the objective.
I really like the idea of veroboards and using them. I find that I should be able to learn how to read schematics quickly by using hero and reading through until I get it right. I'll start with the super simple pedal in the link and work my way forward.
Thanks again!
Thanks again!
Breadboarding can be a little tricky at the start, but once you understand the principles of how the connections are made under the surface, it gets a bit easier. This is an image I did up in photoshop to help me remember/better understand the connections on a breadboard:
Notice that the top two rows are connected horizontally. Anything plugged into one of the holes in one of these rows will be connected to anything else plugged into one of the holes in the same row. Note that the two top rows are not connected.
Now notice how the vertical rows are connected in a similar way, but there is a break in the middle of the breadboard.
The bottom half of the breadboard works just the same as the top half.
This is a picture of what the same size breadboard physically looks like:
The gap in the middles is for placing Integrated Circuits (ICs) onto the breadboard without their legs being connected (each leg has it's own purpose) -
If you want to connect different components together, you simply plug them into the same row on the breadboard. If you run out of space in a particular row, you can use a jumper wire to connect to another row. It will be electrically identical to the row it just came from, and can be seen as an extension of that row.
Here is an image of a breadboard with an integrated circuit (IC), components and jumper wires.
Note that the top horizontal row is the +V (positive voltage terminal from the battery) and the very bottom row is -V (negative voltage terminal (known as ground) from the battery). Note that there are three black wires going to ground, joining the bottom row in three positions.
