Fulltone - OCD  [traced]
Re: Fulltone - OCD
Postby jymaze » 06 Jan 2012, 14:10
On first intention, just put a jumper instead of the 18k resistor in the first opamp feedback loop (the one in series with the 1Meg pot). The minimum gain will then be merely a slight boost.
jymaze
Has thanked: 87 times
Have thanks: 161 times
Re: Fulltone - OCD
Postby geiristudio » 06 Jan 2012, 19:16
jymaze wrote:On first intention, just put a jumper instead of the 18k resistor in the first opamp feedback loop (the one in series with the 1Meg pot). The minimum gain will then be merely a slight boost.
Alright, I'm gonna try that, thanks!
geiristudio
Have thanks: 21 times
Re: Fulltone - OCD
Postby ebuprofen » 26 Jan 2012, 23:24
hey guys, what would be a good value for pot instead of 22k resistor in HP mode? so I could adjust the amount of boost? 500kB?
ebuprofen
Has thanked: 21 times
Have thanks: 12 times
Re: Fulltone - OCD
Postby yongki » 22 May 2012, 07:20
yongki
Re: Fulltone - OCD
Postby Branimir » 27 Sep 2012, 06:27
Trying to find info...
What type of capacitors are use in OCD V4?
Electrolytics are tantalum? All of them? What about the others?
If you scoop, it sounds like poop!
Branimir
Have thanks: 2 times
Re: Fulltone - OCD
Postby batteryacidtea » 27 Sep 2012, 15:49
Theres just one capacitor (one of the 10uF's) is Tantalum, the others are eletrolytics. The tantalum cap is usualy highlighted in the schematics, I don't remember wich one it is, but is easy to find out
batteryacidtea
Has thanked: 57 times
Have thanks: 15 times
Re: Fulltone - OCD
Postby jymaze » 28 Sep 2012, 02:31
Just a correction to the statement above:
Quote: "There's just one capacitor (one of the 10uF's) is Tantalum, the others are film capacitors."
The big polar capacitors of 10uF or more are electrolytics, except C7 that is tantalum (electrolytic here would be just as good).
Actually tantalum capacitors are the worst thing for signal (huge hysteresis) so even an electrolytic for C7 is better in that respect.
jymaze
Re: Fulltone - OCD
Postby Branimir » 28 Sep 2012, 11:15
Hm, I've never actually payed attention to capacitors, I used polypropylene capacitors, does film capacitor means polyester capacitor in this case, and does it really matter? 8)
Branimir
Re: Fulltone - OCD
Postby jymaze » 28 Sep 2012, 13:57
Polyester are the cheapest of films caps so that is what is used usually (versus polypropylene, polycarbonate or polystyrene). It does not matter that much anyway for guitar application, just take the cheapest. At least, I would avoid tantalum for sure.
jymaze
Re: Fulltone - OCD
Postby batteryacidtea » 28 Sep 2012, 17:20
jymaze wrote:Just a correction to the statement above:
I was refering to the polarized ones, now I see I didn't answered the question properly. The pF values are ceramic, the nF values are greenies and the polarized caps are eletrolytic, just C7 (as jymaze stated above) is tantalum
batteryacidtea
Re: Fulltone - OCD
Postby Branimir » 28 Sep 2012, 17:55
I never really payed attention to the caps, I just bought the ones that are available, okay so it's not critical to use that tantalum after all... Though I'm stupid, I have tried the V4 original and built mine and frankly, they sound the same, I just don't have them next to each other to A/B them properly.
Branimir
Re: Fulltone - OCD
Postby Intripped » 22 Aug 2015, 03:28
Just wanted to put some light on how exactly the clipping transistors and the germ. diode are connected.
I have a V4 here on my bench and I see that Source and Gate are connected together (trannies are 2n7000).
So we have S+G and D, where D corresponds to the striped end of a normal diode.
---->|---[S+G] [D]----
This represents how the germ diode and the 2n7000 are connected in series
For this message the author Intripped has received thanks:
howmuch (22 Aug 2015, 16:42)
Intripped
Has thanked: 584 times
Have thanks: 215 times
Re: Fulltone - OCD
Postby howmuch » 22 Aug 2015, 17:07
Intripped wrote:Just wanted to put some light on how exactly the clipping transistors and the germ. diode are connected.
Thanks for posting some first hand evidence on the connections.
It still seems to be widely (and wrongly IMHO) accepted that the gate is connected to the drain (as in the schematic yongki posted above), even though people have hinted otherwise earlier in this thread.
So does your OCD have the same clipping configuration as the Joyo clone's corrected circuit I posted here - the "Circuit when D2 is in the "correct" orientation"?
You've got ---->|---[S+G] [D]---- and the corrected Joyo is electrically the same with ----[S+G] [D]---->|---
Or put another way, on the schematic yongki posted above, move the gate connections from the drains to the sources?
howmuch
Re: Fulltone - OCD
Postby Intripped » 22 Aug 2015, 19:25
howmuch wrote:So does your OCD have the same clipping configuration as the Joyo clone's corrected circuit I posted here - the "Circuit when D2 is in the "correct" orientation"?
[ Image ]
YES to all
...and to avoid any further confusion, here is the exact clipping section:
For this message the author Intripped has received thanks: 3
Duckman (22 Aug 2015, 20:33), dv8r601 (15 Jun 2017, 23:09), howmuch (22 Aug 2015, 22:35)
Intripped
Re: Fulltone - OCD
Postby SamBloody » 26 Jul 2016, 13:04
Hi guys!
Can you give me verified fulltone ocd pcb layout?
SamBloody
Re: Fulltone - OCD
Postby storyboardist » 26 Jul 2016, 16:59
Here's my layout.
For this message the author storyboardist has received thanks:
Blitz Krieg (27 Jul 2016, 07:00)
storyboardist
Has thanked: 67 times
Have thanks: 187 times
Re: Fulltone - OCD
Postby 287m » 26 Jul 2016, 17:19
Nice layout David :thumbsup
perfect for 1590B
so i present to 1590A Club masochist :mrgreen:
reff sch https://4.bp.blogspot.com/-G_jLNr0ZECI/V5eM7fNInjI/AAAAAAAAALU/-A2SqlvuXIImWgGU-js1ryFJmnahiw1IACLcB/s1600/ocd-sch.png
For this message the author 287m has received thanks:
Blitz Krieg (27 Jul 2016, 07:01)
287m
Has thanked: 311 times
Have thanks: 56 times
Re: Fulltone - OCD
Postby SamBloody » 26 Jul 2016, 18:55
Thank you,guys!
SamBloody
Re: Fulltone - OCD
Postby V1nce69 » 18 Aug 2016, 11:22
Hi all,
I own an OCD #84590 with a pcb revision 1.4. Wanting to know how it works, I traced the complete pcb and made a drawing out of it. Here are a few pics and my drawing.
It might be of some interest.
For this message the author V1nce69 has received thanks: 2
Intripped (18 Aug 2016, 14:33), Stray (15 Jun 2017, 17:30)
V1nce69
Has thanked: 30 times
Have thanks: 65 times
Re: Fulltone - OCD
Postby Intripped » 18 Aug 2016, 14:38
nice work!
just a little note:
in your drawing, 2N7000 pins are named wrong
Intripped
PreviousNext
Users browsing this forum: dade1960, nader, Nikolas, Roanacho and 10 guests
