MXR - M-108 Ten Band EQ new version  [schematic]
Postby apollomusicservice » 13 Jul 2012, 18:29
this is schematic for new 10 band EQ m-108 and some gutshots
For this message the author apollomusicservice has received thanks: 39
Broadcaster (25 Sep 2012, 17:17), floris (06 Dec 2017, 18:29), IvIark (13 Jul 2012, 18:31), lietuvis (14 Jul 2012, 10:03), lolbou (27 Sep 2012, 14:41), modman (09 Feb 2013, 16:09), rs (14 Jul 2012, 16:00), Silent Fly (14 Jul 2012, 10:47), sinner (13 Jul 2012, 19:28), toneman (19 Feb 2013, 17:53) and 29 more users
apollomusicservice
Has thanked: 65 times
Have thanks: 776 times
Re: MXR Ten Band EQ M-108 new version schematic
Postby IvIark » 13 Jul 2012, 18:32
Excellent post, thanks for that :thumbsup
IvIark
Has thanked: 668 times
Have thanks: 682 times
Postby Dirk_Hendrik » 14 Jul 2012, 09:13
Thanks indeed!
Has thanked: 255 times
Have thanks: 1025 times
Postby drewl » 06 Aug 2012, 16:48
Any idea where to get those lighted sliders?
Got one here with a couple broken, and none of the frequency sliders light up, only the gain and volume.
Thanks for the schem, it will be a big help!
drewl
Have thanks: 4 times
Postby night-butterfly » 25 Sep 2012, 17:08
Do somebody know wich type are these SMD zeners?
night-butterfly
Has thanked: 10 times
Have thanks: 11 times
Postby xeroxdc12 » 27 Sep 2012, 13:15
Thanks to the shematic.
One question.
Which diode is D1, D2, D3, on shematic is not presented notation.
Symbol is Zenner diode, but which voltage end etc.
xeroxdc12
Postby apollomusicservice » 27 Sep 2012, 17:50
D1=D2=D3=BAS40
General-purpose Schottky diodes in small Surface-Mounted Device (SMD) plastic packages. BAS40
apollomusicservice
Postby Duckman » 27 Sep 2012, 21:39
The dumb question of the day: There is a technical basis to use all these fixed 470 resistors and vary only the remaining components in each gyrator or just a designer choice? I mean, you could also set one value for all the bias resistors and so the other being those to be adjusted to the needs of each gyrator, so... is there any difference?
Duckman
Has thanked: 368 times
Have thanks: 131 times
Postby Duckman » 27 Sep 2012, 23:13
The dumb question of the day II: That´s not exactly True Bypass, right?... or yes it is?
Duckman
Postby night-butterfly » 01 Oct 2012, 07:49
Yes that's not a true bypass but it can be modified to be that way easily
For this message the author night-butterfly has received thanks:
Duckman (01 Oct 2012, 18:37)
night-butterfly
Postby dorothegreat » 01 Oct 2012, 11:34
noob question:
1) can I eliminate certain frequencies (e.g. 4kHz to 16kHz); and
2) can I eliminate certain frequencies in between two frequencies? (e.g. 8kHz only)
thanks in advance. :hug:
dorothegreat
Has thanked: 16 times
Postby Sweetalk » 01 Oct 2012, 12:46
Duckman wrote:The dumb question of the day: There is a technical basis to use all these fixed 470 resistors and vary only the remaining components in each gyrator or just a designer choice? I mean, you could also set one value for all the bias resistors and so the other being those to be adjusted to the needs of each gyrator, so... is there any difference?
The 470 resistor sets the Q and gain of the gyrator, so, in order to have a similar Q on each band uses the same resistor. The GGG eq uses the same negative loop resistor and the same pull up to bias resistor and only changes the caps...
For this message the author Sweetalk has received thanks:
Duckman (01 Oct 2012, 18:38)
Sweetalk
Has thanked: 23 times
Have thanks: 17 times
Postby Duckman » 01 Oct 2012, 18:50
Yeah, I was checking that in every gyrator based EQ that I found in the net and seems like none of them are very picky about Q, so values can be very approximate, but nothing perfect. In fact, most of them uses a 1M pot in series with the bias resistor to vary the frequency, but that means a change in Q from 1 or 2 (up freq) to 4 or 7 (low freq) :!: in some cases (depends on the arrangement of the gyrator)
Duckman
Postby Duckman » 01 Oct 2012, 18:53
dorothegreat wrote:noob question:
1) yes, you can
2) yes, you can, but... check this
EQ INFO.pdf
For this message the author Duckman has received thanks: 3
DuctTapeRiot (07 Feb 2014, 23:22), GodSaveMetal (03 Oct 2012, 01:52), Wiseblood (21 Dec 2017, 04:08)
Duckman
Postby SFTFN » 22 Jan 2013, 23:37
I just troubleshot one m-108 eq that had a problem with half of the EQ LEDS being off and rest of the LEDs on. It turned out that an LED socket had gone bad on one of the sliders.
Fortunately only one socket was bad so I rearranged the sliders so that all EQ frequencies have their LEDs lighted up, but the gain and volume slider LEDs are off... At least it looks symmetrical now.
Anyway, does anyone know are these sliders possible to get anywhere? They're 20k miniature type with center detent.
For this message the author SFTFN has received thanks:
DuctTapeRiot (23 Jan 2014, 23:57)
SFTFN
Postby SFTFN » 07 Feb 2013, 13:45
Well, I contacted MXR/Dunlop about the broken slider and they promptly sent me a replacement slider!! :horsey: My pedal wasn't even under warranty anymore, so they sure seem to care about customer satisfaction.
SFTFN
Postby artaommahe » 08 Feb 2013, 16:01
Is R48 place correct? I have a simulation at LTSpice and when connect gyrators in/out there is -10db pit. If R48 removed and gyrator's out conected to ICD4 13th leg - all is fine.
artaommahe
Has thanked: 18 times
Have thanks: 2 times
Postby apollomusicservice » 08 Feb 2013, 20:09
Thanks artaommahe, I checked again and found mistake.
For this message the author apollomusicservice has received thanks: 2
floris (06 Dec 2017, 18:31), underwood (31 Mar 2015, 07:59)
apollomusicservice
Postby artaommahe » 08 Feb 2013, 23:41
apollomusicservice wrote:Thanks artaommahe, I checked again and found mistake.
thx ) just now did so in the simulator and came to write =)
artaommahe
Postby artaommahe » 08 Feb 2013, 23:48
apollomusicservice, at first schematic we have 12n at IC4C, 15n at IC4D and 2.2n at IC2C. At last - all of them 1n. Last one is correct?)
artaommahe
Next
Users browsing this forum: Edibertuz, marmaliser, vtguedes and 4 guests
