DIPTRACE 3D example design I have done
Re: DIPTRACE 3D example design I have done
Postby GodSaveMetal » 03 Oct 2012, 20:56
Ice-9 wrote:Nice 3d design, did you make the 3d jack sockets and psu jack socket. any chance of sharing them here for the rest of us. :applause:
I wan´a thanks all in this excelent forun, I made much of the designs IMPUT stereo, OUTPUT mono jacks and modified the DC IN jack BOSS type; also the pots ranurated axis; why I found the best layouts I take from this FORUM; Here is my aportation for all of you:
The LEDs are with hosing; the IMPUT jack stereo is close to real, the output is mono close to real too, the stomp switches are with nut and washed is for elaborate this:
Interior of my clone METAL MUFF:
All have details, the resistors with color code, the condensers; IC too; ICs and tranies with sockets and codes!!! all at full details!!!
THANKS!! you are my inspiration!!!!!!!!!!! :applause: :applause: :applause:
GodSaveMetal
Has thanked: 141 times
Have thanks: 52 times
Postby Mbas974 » 03 Oct 2012, 21:07
x GodSaveMetal, is it a DIY switch type ? meaning last snapshot on page 1. Is it working ??
Mbas974
Has thanked: 40 times
Have thanks: 41 times
Postby GodSaveMetal » 04 Oct 2012, 00:37
Mbas974 wrote:x GodSaveMetal, is it a DIY switch type ? meaning last snapshot on page 1. Is it working ??
You refer this????
The 3pdt switch is the symbol on the DIP module SWITCHES code 7301C; the 2pdt switch is the code 7201C in DIP module SWITCHES too; have fun!!! :mrgreen: :mrgreen:
GodSaveMetal
Postby GodSaveMetal » 04 Oct 2012, 01:48
Mr ICE9 your fantastic layout it´s great; but I note you have a silver mica yellow body, this will help you?
In DIP TRACE program go to CAP modules the symbol code CA-10.16/11.5x3.6 is for this 3D model of a yellow silver mica!!!
I attach the 3D DIP file!!!
Enjoy!!!!!!
For this message the author GodSaveMetal has received thanks: 2
287m (11 Nov 2014, 23:59), Ice-9 (28 Dec 2012, 21:16)
GodSaveMetal
Postby Ice-9 » 05 Oct 2012, 23:45
Thanks godsavemetal, your 3d components are excellent and the silva mica cap is wonderful. :applause:
Ice-9
Have thanks: 361 times
Postby GodSaveMetal » 06 Oct 2012, 00:33
Ice-9 wrote:Thanks godsavemetal, your 3d components are excellent and the silva mica cap is wonderful. :applause:
Yes Mr ICE9 now you would complete your 3D layout images without no more restrictions?? any 3D you wan´a??? let me know; if I can made I post here!!!! THANKS for your work it´s amazing!!!!!!!!!!!
Here is my last made:
I made a transparent case 1590BB for my layout of the METAL MUFF I have cloned, to see were go what!!!
And my invention cuze in PERÚ we don´t have a footswitch; my 3pdt MADE IN PERÚ!!
I have to made all my pedals with this switch!!
Here is one of a 100´s pedal I made:
My amazing DEV/NULL II the most HIGH gain DISTORTION/FUZZ pedal!
GodSaveMetal
Postby Ice-9 » 11 Oct 2012, 10:14
I like your home made 3pdt footswitch, ingenius. :applause:
Ice-9
Postby GodSaveMetal » 12 Oct 2012, 00:12
Ice-9 wrote:I like your home made 3pdt footswitch, ingenius. :applause:
Yeah!!! thanks ice-9 I like yours layout too!!! thanks!!!!!!!! :D
in my country nobody knows about the 3pdt footswitch; I have to go with a picture on hand with it, store by store make a tour with the photo of a 3pdt and convence then to bougt the 3pdt or import it and sold it!!! :roll:
Wll I have to waith another year for the import of the 3pdt by the imported stores in my country!!! If not; well continued to make the 3pdt made in PERÚ in 5th or 6th GENERATION!!! :mrgreen: :mrgreen:
GodSaveMetal
Postby 287m » 12 Nov 2014, 00:04
Hello, n00b here :D
GodSaveMetal, can you share your handmade 3pdt Sir?
its so hard to found here. so sad
sorry for bump old thread. just arrived from search engine
sorry again for my bad grammar
287m
Has thanked: 313 times
Have thanks: 56 times
Postby Rennedy » 04 May 2015, 04:02
Ice-9 wrote:I've been messing around with Diptrace again and have made up an example of one of my pedals from schematic to 3D PCBlayout. Some of the footprints I have converted from Guassmarkov Eagle library's, Diptraces 3D library's and the 3PDT switch and caps from a member on this forum ( I think it was Waltk which I will check later and give proper credit to the library maker) Thanks for making them available.
OK this pedal is my Bluesman fet based drive pedal and I have put everything on the PCB to see how the 3D view of Diptrace looks also I added a copper pour to the bottom of the PCB as a ground plane.
[ Image ]
[ Image ]
As an idea of how easy it is to learn Diptrace and get from start to finish it took me about 2 to 3 hours to complete this example and this was done on the FREE version, that goes to make an excellent program for free.
My friend, Ive been trying to find the component for this jack in dip trace with no success. Can you tell me the name? Thanks. And great board, btw
Rennedy
Postby soulsonic » 05 May 2015, 17:57
It's from the GaussMarkov Eagle library. http://www.gaussmarkov.net
Has thanked: 56 times
Have thanks: 275 times
Postby Ice-9 » 09 May 2015, 10:54
soulsonic wrote:It's from the GaussMarkov Eagle library. http://www.gaussmarkov.net
Yes that is correct Soulsonic the footprint is from the Gaussmarkov library, the 3d mode for the jack was from godsavemetals' 3d parts.
Ice-9
Postby POTL » 16 Mar 2017, 21:27
How to make such adapters for potentiometers?
Are there any ideas?
POTL
Has thanked: 65 times
Have thanks: 60 times
Postby Ice-9 » 24 Mar 2017, 00:06
POTL wrote:[ Image ]
It's just a bit of pcb mounted vertically, it will have a few pads at the bottom to mount a 90 degree pin connector, you could use a bit of vero board to do the same thing.
Ice-9
Return to Software Room
