Carlboro - AD1 Echo / Analog Delay
- Dirk_Hendrik
- LaceSensor
my friends has one if its the big alu green box. maybe he can take some guts i can ask if you confirmpknuits wrote:Faulting the unit and find C11 has been removed - No idea of uf value, anyone out there in the ether any ideas or do you even have a schematic of it :=D
- Dirk_Hendrik
That's why I was askingLaceSensor wrote:my friends has one if its the big alu green box. maybe he can take some guts i can ask if you confirmpknuits wrote:Faulting the unit and find C11 has been removed - No idea of uf value, anyone out there in the ether any ideas or do you even have a schematic of it :=D
viewtopic.php?f=19&t=16304&p=182623&hil ... ho#p182623
- tube-exorcist
I think that he was asking about a unit like this:
- Carlsbro_AD1_Echo.jpg (12.68 KiB) Viewed 1313 times
- Dirk_Hendrik
OK, one nail hit.
Next step would be for you to post some pics of the innards of your AD1. This way it might be possible to determine if your AD1 might have some similarities to other Carlsbro effects. This in turn might a) solve your cap mystery or b) help you to find a way to fault-find your unit if that cap is not the problem.
or, in essence,
asking questions and showing up 2 days later without providing as much info as you can will not help you to speed up your repair Start shooting!
or, in essence,
Sorry about not being able to reply instantly, but with other things going on around me things are taken in an orderly fashion. Iwill post the innards as suggested just as soon as my current workload ends, which should be in the next day or so. Keep the faith. I will post.
