Good buffer to place at the beginning of pedalboard
Postby Roast7 » 15 Oct 2012, 15:09
I would put a good buffer to the beginning of the sequence of pedals
I thought the "Amz JFET transistor BUFFER" but wanted to build on stripboard.
've Looked schemes stripboard but found none so with good feedback ...
What do you advise??
best regards
Daniel
Roast7
Have thanks: 8 times
Re: Good buffer to place at the beginning of pedalboard
Postby Roast7 » 16 Oct 2012, 21:35
Someone to help?
Roast7
Postby biliousfrog » 16 Oct 2012, 21:43
I'm using a Klon buffer, built from a kit that this guy sells: http://shop.pedalparts.co.uk/Klown_Buff ... 46591.aspx
I had a Boss tuner at the start of my chain but swapped it for a TC Polytune Mini which is true bypass....the buffer works well, actually colours the sound a little bit but in a nice way.
biliousfrog
Have thanks: 10 times
Postby sinner » 16 Oct 2012, 22:15
Has thanked: 1240 times
Have thanks: 1100 times
Postby rocklander » 16 Oct 2012, 22:26
I just use the black toast buffer at the start of my board.
rocklander
Has thanked: 1580 times
Have thanks: 290 times
Postby Roast7 » 17 Oct 2012, 19:07
Because I wanted was the most appropriate to start the chain of pedals.
opamp vs jfet
opamp version is capable of giving lower output impedance (Z) and unity gain (gain = 1), Whereas the jfet's output impedance will be higher and slightly less than unity
which to choose? many people advises the jfet.
Roast7
Postby biliousfrog » 19 Oct 2012, 10:37
Gain is fairly irrelevant unless it's a massive drop because it will always be on.
biliousfrog
Postby IvIark » 19 Oct 2012, 12:34
This is one of the JFET buffers shown on the AMZ site, the one with the 1/2 supply voltage divider:
IvIark
Has thanked: 668 times
Have thanks: 682 times
Postby Roast7 » 19 Oct 2012, 14:36
IvIark You think it's a good buffer transparent to the beginning of the chain of pedals?
What I want is something to put the correct impedance and does not color the sound.
Roast7
Postby IvIark » 19 Oct 2012, 15:05
I haven't experimented with different types for quite a while, but if transparency is most important to you I'd probably recommend a generic opamp buffer. I thought the JFET buffers did colour the sound more.
IvIark
Postby Roast7 » 19 Oct 2012, 18:57
Already try this vero layout? if yes what kind of color it gives?
Roast7
Postby FiveseveN » 19 Oct 2012, 19:48
Purple.
For this message the author FiveseveN has received thanks: 4
Duckman (19 Oct 2012, 20:19), Nocentelli (19 Oct 2012, 21:42), rocklander (19 Oct 2012, 20:06), sinner (19 Oct 2012, 22:24)
FiveseveN
Has thanked: 133 times
Have thanks: 55 times
Postby rocklander » 19 Oct 2012, 20:17
I did what you are doing with this layout (not vero sorry, but shouldn't be hard for you to make one?)
viewtopic.php?t=2752&p=174536#p174536
rocklander
Postby Roast7 » 19 Oct 2012, 20:37
FiveseveN wrote:Purple.
Very funny :P
Well someone was making Veroboard jfet scheme, this pcb here:
http://www.muzique.com/tech/buffer.htm
Or even Veroboard this PCB
rocklander wrote:I did what you are doing with this layout (not vero sorry, but shouldn't be hard for you to make one?)
http://www.freestompboxes.org/viewtopic ... 36#p174536
This baja is like Amz?
I do not understand, but nobody uses buffers at the beginning of the chain of pedals??
Roast7
Postby FiveseveN » 19 Oct 2012, 20:52
Roast7 wrote:I do not understand, but nobody uses buffers at the beginning of the chain of pedals??
Plenty do, in one way or another. I have onboard buffers in my guitars (JFET, like the one above). If you want to explore the kind of differences people think they hear just build a bunch of options (BJT, JFET, op amp) and compare them. It's $2 in parts.
If you're interested in best performance and not "color", whatever that means, build an op amp buffer with the biggest supply voltage you can muster (e.g. ±15 V, though 9 V is probably plenty for usual pickups).
FiveseveN
Postby rocklander » 19 Oct 2012, 21:05
never built the AMZ.. the pure sound of the black toast was good so I just used it
yes.. many, as did I .. as posted in that link.
rocklander
Postby ppluis0 » 20 Oct 2012, 00:00
Roast7 wrote:Because I wanted was the most appropriate to start the chain of pedals.
opamp vs jfet
Personally I would employ a tube buffer like this, but running with less high voltage:
I think this diagram is similar to VHT/Fryette valvulator or Coopersonic tube cleaner.
ppluis0
Has thanked: 44 times
Have thanks: 89 times
Postby FiveseveN » 20 Oct 2012, 00:09
Why? That has absolutely none of the advantages of a 50 cent modern buffer.
FiveseveN
Postby sinner » 20 Oct 2012, 00:15
opamp vs jfet
I would love one myself :)
12v tubes are still possible to buy. 12U7 (dual triode) seems to be perfect candidate to become a base for battery powered friendly tube buffer
Postby Roast7 » 20 Oct 2012, 00:36
I wanted something simple just to maintain the equal sign and good and transparent because the pedals are all in True Bypass.
That's why I thought the AMZ, because they say it all.
but I wanted to build myself and preferably in Veroboard.
Maybe I'll do it, like build a IvIark put here (jfet), and another with opamp, then choose.
Advice for other projects in stripboard, in addition to the layout IvIark posted???
Roast7
Next
Return to Circuit Blocks
