JHS - Little Black Buffer  [traced]
kev1n
Post by kev1n »
I had the chance to check out a little black buffer the other day. Started to trace it, it looks like its based off jack ormans mosfet buffer. Has the same ic and 10 uf/ .1 uf cap.
Been thanked: 909 times
Cool, thanks for the info. Any picts incoming shortly? :thumbsup
Seven64
Been thanked: 7 times
Post by Seven64 »
on their website there is a small pic which shows its an IC buffer.
Jack Deville
Completed builds: too many. too many.
Been thanked: 86 times
Post by Jack Deville »
So many high value resistors!!
Why!? WHY!? WHY!?
Opamp followers are EE101 material.
Hopefully, the excessive use of excessively high value resistors are being used as simple pulldowns, and one of the 0.1uF caps is being used as a power supply decoupling cap, but I suspect this is not the case. We'll never know without a trace side shot.
I'm a "professional."
Buy my products and make me rich.
www.jackdeville.com
Neeno
Post by Neeno »
Hey guys !
Has anyone a gut-shot of this buffer ?
Is it based around a BS170 or a TL07x ?
Thank you in advance !
POTL
Has thanked: 58 times
Been thanked: 67 times
Post by POTL »
Schematic is here 8)
