Alairex - H.A.L.O. Overdrive  [traced]
Postby Saruman_ » 01 Dec 2012, 17:05
For this message the author Saruman_ has received thanks: 8
atreidesheir (02 Dec 2012, 02:58), Fredenando (01 Dec 2012, 19:40), jonasx26 (01 Dec 2012, 18:29), LaceSensor (01 Dec 2012, 18:12), lohstah (08 Dec 2012, 09:23), modman (08 May 2015, 10:03), morbidalex666 (02 Dec 2012, 21:43), rocklander (02 Dec 2012, 04:14)
Saruman_
Have thanks: 32 times
Re: Alairex H.A.L.O. Overdrive
Postby LaceSensor » 01 Dec 2012, 17:26
Nice pictures
Thought this sounded pretty nice actually, justifying the amount of shit in there!
LaceSensor
Has thanked: 42 times
Have thanks: 246 times
Postby okgb » 01 Dec 2012, 17:34
Allot of diodes , I'd like to see the top outside , curious what controls & switches there are
and Ohhh secret I.C.'s ................
okgb
Has thanked: 206 times
Have thanks: 42 times
Postby deafbutpicky » 01 Dec 2012, 18:27
From looking at the solder side, I'd say the 16pin IC in the middle is a CD4049UB. pins 13 and 16 are free...
Another guess: It's for the saturation mode.
I'm using capacitors to replace my guitar effects and give more clarity to the sound.
deafbutpicky
Has thanked: 27 times
Have thanks: 20 times
Postby Saruman_ » 01 Dec 2012, 21:28
no, it's part of the switching. no CD4049UB
Saruman_
Postby atreidesheir » 02 Dec 2012, 03:10
Big ups Saruman!
Every time you post it is juicy.
Incredible amount going on for an od.
atreidesheir
Has thanked: 452 times
Have thanks: 43 times
Postby Saruman_ » 02 Dec 2012, 07:48
other diodes are used for control switches J113
modman (08 May 2015, 10:04)
Saruman_
Postby atreidesheir » 02 Dec 2012, 16:48
15 transistors
5 integrated circuits (counting the double)
and 6 diode sets (not counting the singles - i am guessing some assymmetrical pairs also)
that is really intricate for what it does.
If it was lovepedal, I would say maybe 5 electra distortions in series with 2 or 3 landgraff tubescreamers with "clipping options"
atreidesheir
Postby Lucifer » 02 Dec 2012, 17:42
And here it is - the LP Cooling system for nuclear fission plants.
For this message the author Lucifer has received thanks:
atreidesheir (11 Dec 2012, 16:42)
Lucifer
Has thanked: 104 times
Have thanks: 95 times
Postby morbidalex666 » 02 Dec 2012, 21:46
Original or not, this one sounds killer in the demos.
Complexity -wise, it does rival mr Tripp's designs IMO.
Pretty expensive too!
Chuck Schuldiner said:
"Let the Metal flow"
morbidalex666
Has thanked: 13 times
Have thanks: 7 times
Postby Ice-9 » 03 Dec 2012, 13:19
He's went to a lot of trouble even grinding of the value of the box caps .
Ice-9
Has thanked: 141 times
Have thanks: 361 times
Postby Saruman_ » 05 Dec 2012, 07:34
For this message the author Saruman_ has received thanks: 6
atreidesheir (11 Dec 2012, 16:42), lohstah (08 Dec 2012, 09:22), modman (08 May 2015, 10:04), roseblood11 (04 Sep 2018, 10:41), Synthi (05 Dec 2012, 07:48), tp801 (11 Dec 2012, 16:49)
Saruman_
Postby Saruman_ » 11 Dec 2012, 06:37
For this message the author Saruman_ has received thanks: 2
modman (08 May 2015, 10:05), tp801 (11 Dec 2012, 16:50)
Saruman_
Postby bajaman » 11 Dec 2012, 09:10
whoa :shock:
Is that a three layer board - looks like yet another tubescreamer rat combo with a speaker simulator and baxandall three band eq :roll:
would be interesting to see the filter values and interesting input buffer stage :lol:
"why use a 12A*7 tube when a dozen op amps will do the job just as well" quote for the day :secret:
Has thanked: 447 times
Have thanks: 1536 times
Re: Alairex H.A.L.O. Overdrive  [traced]
Postby Saruman_ » 14 Dec 2012, 05:38
For this message the author Saruman_ has received thanks: 10
bajaman (14 Dec 2012, 09:40), ik6gpy (14 Dec 2012, 12:15), ilshat (18 Mar 2013, 19:20), Intripped (14 Dec 2012, 16:06), lohstah (19 Dec 2012, 23:08), Manfred (15 Dec 2012, 05:37), modman (08 May 2015, 10:05), morbidalex666 (14 Dec 2012, 15:32), pamaz (14 Dec 2012, 12:40), tp801 (14 Dec 2012, 10:24)
Saruman_
Postby bajaman » 14 Dec 2012, 11:09
Thanks to Saruman for the values :thumbsup - here is the really interesting bit :wink: - the post clipping filter response after the clipping stage and up to the master volume controls.
The graph shows the response as the signal passes through each successive filter / gain stage.
The red curve shows the input (normalized for a flat response)
The next curve (green) shows the response after the broad mid notch and gain recovery stage.
The blue curve shows the response after the first op amp low pass filter stage.
The purple curve shows the response after the second op amp low pass filter stage.
The yellow curve shows the response after the third emitter follower low pass filter stage.
AND the pink curve shows the response after the final broad notch filter and output buffer op amp stage.
For this message the author bajaman has received thanks: 5
deafbutpicky (14 Dec 2012, 14:21), dv8r601 (21 Oct 2017, 00:05), Intripped (14 Dec 2012, 19:23), modman (08 May 2015, 10:05), rcustoms (04 Sep 2018, 14:51)
Postby Saruman_ » 14 Dec 2012, 18:41
True sound of HALO very close. But the feeling when you play nice.
I tried my version. It sounds almost exactly like the original Halo.
For this message the author Saruman_ has received thanks: 5
ilshat (21 Oct 2017, 20:17), Manfred (15 Dec 2012, 05:37), modman (08 May 2015, 10:05), pamaz (17 Dec 2012, 10:27), roseblood11 (04 Sep 2018, 10:45)
Saruman_
Re: Alairex - H.A.L.O. Overdrive
Postby roseblood11 » 04 Sep 2018, 10:49
Did anybody ever try to make a pcb for the original circuit or for Sarumans stripped down version?
Sarumans version should be even small enough for veroboard in a 1590bb
roseblood11
Has thanked: 352 times
Have thanks: 310 times
Users browsing this forum: No registered users and 11 guests
