Anyone ever used a Weber WPDLXFMR transformer?
Frequently asked questions regarding powering your pedal.
Postby bruin2k3 » 24 Jul 2011, 04:04
I understand that it has 8 isolated 11V AC outputs and a 9V AC out. Have any of you used it before? Good results with it? Does it come with 20 leads and is each pair individually labeled?
-Bruin2k3
bruin2k3
Has thanked: 26 times
Re: Anyone ever used a Weber WPDLXFMR transformer?
Postby mysticwhiskey » 24 Jul 2011, 04:36
I've used the 240V version (WPDLXFMR-2), which seems to work fine. 300mA per AC output is plenty of power for most pedals. Each pair of secondary output wires have a unique colour, so they're easily identified.
bruin2k3 wrote:I understand that it has 8 isolated 11V AC outputs and a 9V AC out. Have any of you used it before? Good results with it? Does it come with 20 leads and is each pair individually labeled?
-Bruin2k3
For this message the author mysticwhiskey has received thanks:
bruin2k3 (24 Jul 2011, 17:18)
mysticwhiskey
Has thanked: 49 times
Have thanks: 180 times
Postby MGW » 09 Nov 2012, 16:24
The 120v version works great, but they aren't individually labelled. However, the pairs are all side by side coming out of the xformer. The 9VAC tap is green, the others are brown. Used one for about 18 months and went back to a rack recently. Worked great.
MGW
Postby soulsonic » 13 Jan 2013, 07:03
I built a supply with one and it works fine. Only beef I had with it is the pairs not being easily identified and that it's so large, it won't fit into any sort of compact box.
Has thanked: 56 times
Have thanks: 275 times
Postby chicago_mike » 26 Jun 2014, 22:22
Reviving an old thread!!!! :horsey: :horsey:
I just got one in the mail.
The thing i need is a large enough enclosure... :scratch:
Went with the 120/240 model since the cruise ships have both.
Skyline FX 2013
chicago_mike
Has thanked: 23 times
Have thanks: 283 times
Postby PokeyPete » 26 Jun 2014, 22:35
As I stated elsewhere in a similar topic, I used this for my power supply. However, as I recall the 240V version is a little too large for this box.
I mounted the xfmr in the center and had room on each side for 4 circuits. It's not a pretty box, but quite functional.
http://www.smallbearelec.com/servlet/Detail?no=698
“No man is so foolish but he may sometimes give another
good counsel, and no man so wise that he may not easily err
if he takes no other counsel than his own. He that is taught
only by himself has a fool for a master.”
–Hunter S. Thompson
PokeyPete
Have thanks: 64 times
Return to Power
