Well they couldn't very well brag about a grounded-emitter amplifier, could they? Gotta have them NOS PIO OMGWTFBBQ!harmaes wrote:But I'd love to hear your opinions about them.
Emerson Custom Guitars E-M Drive. [traced]
- FiveseveN
- caspercody
I am testing this through a all tube amp.
I can't read the pot values... anyone know what they are?
- IvIark
I think this right. Someone already built it on my blog and said it's a nice boost
Mojo version if you've got the Russian caps:
Compact version:
Compact version:
Thanks, IvIark! Just threw this together, and I like it! Just used Mylar caps, as I didn't have any "old school paper in oil" on hand, but still, it sounds decent. Also, it's a confidence booster, as I slaved over tagboard versions of the Deep Blue Delay and Eternity pedals with absolutely no success. Maybe I just needed something EXTREMELY simple and straightforward to ease me into pedal building.
- IvIark
That's a pretty good idea. Once your confidence is up then you'll knock anything out comfortably I'm sure
- nooneknows
+1Nocentelli wrote:Maybe, but I'm inclined to think this is mainly aimed at driving the input of a nice tube amp rather than primarily producing the clipping from within the transistor itself.
I breadboarded it and it doesn't sound interesting itself, but if I use it to drive my amp or even my OCD input then it sings really well. Anyway I still prefer my electra distortion derived woodrow clone to do this.
- caspercody
If you used the schematic on page 1 from IvIark I think it is wrong. R1 (I think) should be going to V+ and not to R2 and C2??
- IvIark
Yes that was the mistake in my guessed scheme. This is the correct one apparently
http://www.extremecircuits.net/2010/05/ ... istor.html
Edited:
I've updated my schematic to add it to the thread.
Edited:
- Emerson Custom Guitars E-M Drive.GIF (4.41 KiB) Viewed 2942 times
IvIark -
Are you going to update the vero layout on your blog to match the new schematic? (I have not checked to see if you have or not, juts curious).
- my favorite amplifier: Rivera knucklehead 100
- Completed builds: Easy drive, ts808, rat, big muff, bazz fuss, echobase, rebote 2.5, tribune, harmonic energizer, one knob fuzz, controfuzz, tone machine, fuzz face, harmonic percolator, pwm, blue box, tremulu,s lune, hot cake, fuzz factory, blues driver, ocd, peppermill, thor, ds1, klon, machine, wolly mammoth, tube sound fuzz, les luis, box of rock, kay tremolo, ea tremolo, small stone, scrambler, green ringer,
- Has thanked: 3 times
- Been thanked: 1 time
looks like both resistors go to V+ on the vero
Mike S.
- IvIark
Yes the vero is correct, it was my original gues-timate scheme from October that was wrong
- sonicmojo
+2 on the breadboard results here but it might be a interesting in the chain of a bigger circuit.nooneknows wrote:Nocentelli wrote:Maybe, but I'm inclined to think this is mainly aimed at driving the input of a nice tube amp rather than primarily producing the clipping from within the transistor itself.
+1
- nooneknows
Uh, I didn't understand.sonicmojo wrote: +2 on the breadboard results here but it might be a interesting in the chain of a bigger circuit.
I tried it (in breadboard version) alone in front of my tube peavey amp, after my pedalboard setup (lovepedal woodrow, digitech main squeeze compressor > crybay wah > Phase 45 > OCD > MiniBooster > digitch chorus factory > hardwire delay > Boss Tuner) and before my pedalboard, the best results were using it before the pedalboard, driving the OCD engaged.
- nooneknows
Anyway this circuit seems to be drawn having in mind the audiophile rules: minimum number of components, hi-quality caps, ecc.
Since I was in audiophile tunnel and addiction for some years and it took a long time before I finally came out, let me say that I think a great part of the mojo around is... crap.
If in hi fi world it 'could' work (but not always) in guitar land is almost useless: guitar is definetely not hi-fi, and much more 'often' than 'sometimes', audiophile rules become a synonime of 'shrillness' or stiff sound.
But that's just my humble opinion.
I've breadboarded this, because why not...I had an extra 3 minutes today. I tried 2n5088s, 2n5089, 2n2222, 2n3094, and 2n3096. The lower gain options sounded better but boring. The higher gain options just got farty and blown out with the gain cranked. That's always been my experience with single transistor circuits. So, what's the secret, how does this not get "farty"?
- sonicmojo
For a circuit this minimalistic, I think you can only get so far, especially with cranked turns of the gain pot. I've had better luck with single transistor circuits like the COT50 which is very similar but puts something between emitter and ground which I think makes things more more controllable.aaronmcoleman wrote:I've breadboarded this, because why not...I had an extra 3 minutes today. I tried 2n5088s, 2n5089, 2n2222, 2n3094, and 2n3096. The lower gain options sounded better but boring. The higher gain options just got farty and blown out with the gain cranked. That's always been my experience with single transistor circuits. So, what's the secret, how does this not get "farty"?
