MXR - M-108 Ten Band EQ new version [schematic]
- apollomusicservice
All of them 1n is correct.
gtr2, it's simple RC-filter )
f = 1/(2*pi*R*C)
f - cutoff frequency
f = 1/(2*pi*R*C)
- drewl
I found the sliders at Mouser.SFTFN wrote:I just troubleshot one m-108 eq that had a problem with half of the EQ LEDS being off and rest of the LEDs on. It turned out that an LED socket had gone bad on one of the sliders.
Fortunately only one socket was bad so I rearranged the sliders so that all EQ frequencies have their LEDs lighted up, but the gain and volume slider LEDs are off... At least it looks symmetrical now.
Anyway, does anyone know are these sliders possible to get anywhere? They're 20k miniature type with center detent.
They've been stocking alot of oddball pots used in newer amps and FX.
hey guys...sorry to dig this up -new guy here. Does anyone have a schematic layout for this, by any chance? I tried it a billion times but I'm getting REALLY confused with grounding and voltage connections on IC's, so...any help would be extremely welcome!
thanks for that! so, if I got this right...
1.every pin 4 from those ICs must be connected to the VCC arrow from IC4A
2.every arrow facing downwards must be connected to the bias (through a common plane or something like that)
more questions...:
Does every pin 11 need to be connected to the ground plane?
Do the Bias connections also need vias to the ground?
What is the arrow coming from R43..? Another connection to Bias?
I'm really sorry guys, this is all new to me..! Thanks in advance.
more questions...:
Yes JimmyDS you right, all pins "4" are connected together with arrow "up" on R43 and point R1- R4 to VCC.
Point from pin 1 of IC4A ,named BIAS, connect with all the same arrow symbols (it does not matter whether
they are/not oriented in the same direction) and do not connect this point to ground . All pins "11" are connected
to ground. Also if you use base for IC's you can use TL074 which can be easier to find but with reduced performance
even after replaced with original. Good luck in building this unit.
I am having a very similar problem to this. Can I ask how you tested to know which slider's socket was bad??SFTFN wrote:I just troubleshot one m-108 eq that had a problem with half of the EQ LEDS being off and rest of the LEDs on. It turned out that an LED socket had gone bad on one of the sliders.
ok guys...this is not fun anymore! reacreating the schematic and finding the parts was super, even testing PCB making techniques and services but this one is way over my head..! if anyone could help with the PCB layout I would owe him my life!! pls help
- matt239
What does this mean?apollomusicservice wrote: .... Also if you use base for IC's you can use TL074 which can be easier to find but with reduced performance
even after replaced with original...
My 62.5 Hz is broken.
There are a bunch of sliders made by Bourns that seem to look the same.
http://www.mouser.com/Passive-Component ... ?P=1yzekj2
- alexradium
hello everybody,
i have an MXR 6 band,the interesting problem is i have 8V on the last output opamp,and after some measurements i came to the conclusion that its not faulty,but that voltage comes from the 9V rail that powers the leds and goes to those pins and in consequence to all the slider pots by means of an 8,5kohms resistance,which obviously is not there, i could imagine that some conductivity is in play somewhere between the 9V rail and the Vbias rails.
I tried to clean the surface with isoprop alcohol and all the pots with proper cleaner,but nothing new happened.
Has anyone experienced anything similar with smd boards?
i'd like to know before i start removing all the sliders and jacks.
thanks in advance.
thanks in advance.
- x-tn
There is a 'newer' version called M108S.
It says "...it's been upgraded with noise-reduction circuitry, true bypass switching, a lightweight aluminum housing, brighter LEDs, and a second output."
https://www.jimdunlop.com/product/m108s ... 09564-9.do
- m108s.jpg (37.86 KiB) Viewed 22131 times
- floris
I think the sliders in the black M108 Ten Band EQ are:
RA2545F-20 RED LED
See:
http://www.taiwanalpha.com.tw/english2014/p_e_086.htm
Looking at Mouser the Manufacturer Part Nr should be:
RA2545F-20R-15LC-B20k-C
Slide Potentiometers 25mm Travel LINEAR 20K RED LED PC MOUNT
(although Mouser only has RA2045F, RA3045F and RA4545F)
Series: RA2545F
Termination Style: Through Hole
Travel: 25 mm
Resistance: 20 kOhms
Power Rating: 100 mW
Voltage Rating: 200 V
Tolerance: 20 %
Taper: Linear
Length: 40 mm
Width: 9 mm
Height: 7 mm
Anyone knows a place where one can buy the Alpha RA2545F RED LED 20k?
RA2545F-20 RED LED
See:
Series: RA2545F
Travel: 25 mm
Tolerance: 20 %
Taper: Linear
Length: 40 mm
Width: 9 mm
Height: 7 mm
- floris
Reply from Dunlop regarding, replacing a slider pot in in the black M108:
The part number for the replacement slider pot is #ECB046.
For pricing and ordering you can contact (for the Netherlands):
AB Music
Stephane Verbeurgt
stef@algambenelux.be
+32 (0) 15 33 80 00
AB Music
Stephane Verbeurgt
+32 (0) 15 33 80 00
