Ice-9 wrote:
I would have to trace where the pads go then make up a suitable cable for a Pickit2 programmer, (not all 5 connection will need to be used) but like I say I would need to trace the connections out properly. For 5 pin header check my pcb board a few posts up.
EDIT - (oops it's not a few posts up its in a different thread on a different forum about FV-1) http://www.circuitworkshop.com
maybe (in another thread?) you might share what yhou know about this Pickit2 programmer? It's new to me so I'm a little lost.
Interface for programming PIC microcontrollers and Micropchip EEPROM. Take a look at the datasheet for all the info you'd ever need. New version 3 is out now though, so you might want to start there.
The pickt3 cant program the Eeproms, for some reason Microchip removed this capability from Pickit3.
Here is a pcb picture and a 1st draft schematic, No Fv-1 part as it is datasheet stuff and patch selection is via pic chip , I can't post eeprom or pic code as it has to be respected as ip.
Despite english is not my mother tongue, I assume IP stands for Intellectual Propriety (sorry if I am wrong).
I highly respect your decision to not disclose the code, but I just can't understand the rules on FSB on why things can be disclosed "for educationnal purpose or whatever" and some cannot for IP.
Sorry if I bring back an old discussion, and I sure don't mean to be a pain in the butt.
I've wanted to learn about DSP and programming for a while (I've learned basic knowledge during my engineering studies). It may be a nice opportunity to begin as I also have 2 original Echorecs, 1 solidstate PE603 and tube Echorec2, that I'd like to retire. Those things are wearing out!
I also have a question. Where is the tone control, I can't find it on your schematic? Is it within the FV-1 circuitry?
According to the catalinbread manual, it is a "tilt" style ton control.
loylo wrote:I also have a question. Where is the tone control, I can't find it on your schematic? Is it within the FV-1 circuitry?
Yes the tone control is taking care of by the FV-1 chip.
mrkaploca wrote:Not familiar with fv-1 code but isn't it protected?
Programs are loaded to the FV-1 via an external Eeprom, so to develop your own effects all you need is the datasheet and language from the Spin site. There is lots of info there to learn the coding. As for the code in the echorec I have no intention of reading it, I was just more interested in the electronics of the unit.
I know the code is in external EEPROM, but I believe it is protected... The whole magic in this circuitry is in the code.
for contribution!
coldcraft wrote:that preamp looks very similar to whats in the Way Huge Pork Loin, except they're using 2n7000 it looks like.
No, I was wrong. The 2n7000 are used with the EEPROMS, the preamps is transistors, same like the Pork Loin. Not sure what its originally from though.
Yes the 2n7000's are used to switch Eeproms. The buffer transistors are 2n2222a.
@mrkaploca It's not possible to read protect the 24lc32a Eeproms, but reading the code from an Eeprom is of no use for study, only useful if you just want to flash it to another pedal.
Its that easy.
I'm a "professional."
Buy my products and make me rich.
Its that easy.
Indeed Jack, and I would never give out anyone elses eeprom data, I have the datasheets and the spin asm stuff and although it is big learning curve (for me) it is low count the instruction set so should be quite easy to learn. (the basics anyway)
All credit to Kieth Barr on this chip, it is a shame he is not here anymore to bring more of his huge knowledge to the music scene.
coldcraft wrote:Is the sway control a dual gang pot? On the board it looks like its both a regen and a fv-1 pot. Cool idea.
No the sway pot is single gang. The pot position just below it is not used, it goes to the FV-1 and is the modulation pot which is controlled by an internal preset.
