Inspired by Dirk Hendrik's Real Tube Screamer pedal project elsewhere in this section, and after reverse engineering the B K Butler Tube Driver, and noting some similarities, i have designed a brand new design for a REAL tube drive pedal, housed in a Hammond (or equivalent NSC) 1590BB case. There are three circuit boards - a mother board that holds the footswitch, input, output and AC power supply sockets; a small board to hold the 12AX7 tube and it's passive components, and a board to accomodate the driver dual op amp and three control knobs.
The three boards are solder pinned togaether and form a very strong structure to hold the tube and controls etc. There is only one wire to connect the board to the chassis earth.
I gave my finished prototype a run, last night at practice, and was complimented on my great guitar sound (not playing ability mind you
I will be building these on a one by one basis as time permits, and the price will be US$330.00 plus postage etc. (power supply not included)
However, you can build your own if you would like to, because I shall be placing the complete design layout, PCB, chassis, and artwork details exclusively for all registered members of the freestompboxes forum.
I may be able to supply board kits on request, but have not worked out prices as yet, because this is a very new project.
The only other piece of equipment you will need is a suitable 16vAC power supply - there are many 16vAC 1.5A types available as burglar alarm supplies - just buy one of these and solder a 2.1mm dc socket on the wires -
I will be posting full details in the next few days - stay tuned
I'm not worthy....
![vibes [smilie=vibes.gif]](./images/smilies/vibes.gif)
