Bearfoot - Baby Pink Booster [traced]
- mmolteratx
- Degoop Doctor
- BBP.png (7.44 KiB) Viewed 4103 times
- IvIark
Love the quickies
- mmolteratx
- Degoop Doctor
And here's a PCB. Parts match the schem, and I don't think I need to say no commercial use, but no commercial use. Print at 300dpi.
- Baby Pink Transfer.png (3.92 KiB) Viewed 3946 times
- Baby Pink Parts.png (3.6 KiB) Viewed 3946 times
- mmolteratx
- Degoop Doctor
And here's one with larger pad sizes. Figured I'd make it a bit easier for less experienced etchers.
- BBP Trans.png (3.98 KiB) Viewed 3938 times
- marshmellow
Would you please stop spamming the DIY electronics forums? Thank you.real-pcb wrote:Would above PCB be processed?
- phibes
- Transistor Tuner
No it needs to be coagulated.real-pcb wrote:Would above PCB be processed?
Ken
Ken
- mmolteratx
- Degoop Doctor
Yup. If you want to wire it as true bypass, dump the 150k resistor at the cold lug of the boost pot and leave the wiper connected to ground.Seiche wrote:so switch is wired so that the thing is still a buffer when it's off. For regular operation regular switch wiring, right?
- Seiche
looking at the pcb again, this looks like it could be the same pcb used on the candy apple fuzz (as usual for the Bearfoots). This might be a good opportunity to trace out the pcb connections, as the traces are easily visible to facilitate tracing of the CAF once it's released.
- phibes
- Transistor Tuner
Seiche has been waiting to unload that Reese photo!
Ken
Ken
- mmolteratx
- Degoop Doctor
It's used in the CAF and EGD. Was gonna buy an EGD, but I've kinda lost interest.Seiche wrote:looking at the pcb again, this looks like it could be the same pcb used on the candy apple fuzz (as usual for the Bearfoots). This might be a good opportunity to trace out the pcb connections, as the traces are easily visible to facilitate tracing of the CAF once it's released.
- Seiche
Can someone explain what is happening here? I just left the 150k in the circuit and wired the bypass as usual. What's the difference? When turned all the way down, the signal is at unity gain.mmolteratx wrote:If you want to wire it as true bypass, dump the 150k resistor at the cold lug of the boost pot and leave the wiper connected to ground.
No, D2 is a zener for LED protection, D3 is an LED. I left D2, D3 off my build as I did not use the buffered bypass.laoliang wrote:Excuse me:D1,D2,D3 is 1n4002?
As far away as China
