Strat with Super Switch and Push/Pull - 9 Sound Strat
trjones1
Been thanked: 5 times
Post by trjones1 »
I posted a chromacaster workalike using a six position rotary switch on here a couple years ago which I installed in a couple of my guitars. I never really got used to it. I could never remember the different settings and only really used a few of them anyway. I decided to simplify things by just having a push/pull with the pickup selector to get the series and parallel sounds I wanted. I couldn't find a schematic for what I wanted out there, so I put this together. It uses a Super Switch and push/pull. You get the normal Strat sounds with the pot down, and get four new sounds with the pot up. I haven't actually installed it yet, so if you see any problems please let me know. Should work though.
GuitarlCarl
my favorite amplifier: anything tube
Completed builds: Ds-1 mods, SD-1 mods, Small Clone mods, Muff build, Axis build, various other transistor booster builds... I can build a badaxe harmonic perc, but I can't get a fuzzface to sound worth a crap!
Has thanked: 54 times
Been thanked: 29 times
Post by GuitarlCarl »
Looks good to me.... :blackeye
I want it to sound like bees buzzing around in a 55 gallon drum...
phatt
Been thanked: 343 times
Post by phatt »
I have stock setup, except for one tiny switch which gives me series in bridge position.
That effectively gives me 6 positions to cover humbucker type sounds without the stuffing around trying to find a wizz bang HB that matches my SC's.
Guarantees the pups are well matched and the guitar looks stock.
Any more I'd get confused. :block:
Ed; Oh forgot to add,,,, I hate those push pull switches on control knobs they are to clumsy for fast changes. :evil: :blackeye
trjones1
Post by trjones1 »
I installed the switching from my first post in my Strat and it works as designed. One of the problems I have with that setup is that only one of the positions is hum-canceling, and I wanted to see if I could up that number.
This is my new design. It has two hum-canceling positions and each position gives you a different sound compared to a stock Strat. I'm going to install this next time I open up my guitar and try it out.
This one's a little more complicated and doesn't make as much sense to me intuitively, but I've looked over it a bunch and I think it should work. As always, comments and corrections are welcome.
trjones1
Post by trjones1 »
I finally got around to installing this second version and it's works great. The middle position tone is especially nice. The bridge and middle in series gives a really nice humbucker-ish tone, but the neck and middle in series is way too muddy to use. My next move may be to change position 4 to make it neck+middle in series, parallel with the bridge. All you have to do is connect the unused tab in the Bridge + section to the green wire. This should help with the mud and if it sounds anywhere as nice as the middle position, I think I'll be happy and can stop tweaking.
phatt
Post by phatt »
Ha guitar players are never satisfied,, :lol:
Here is all I did,, Mounted a small toggle switch between Volume and 5 way.
FWIW,, If you have guitar switching too far from obvious then it makes life so much harder to remember the combinations if you have many guitars. :shock:
Phil.
Simple but effective
trjones1
Post by trjones1 »
Aww, why go simple when you can be so much harder on yourself?
