Schumann PLL  [traced]
Schumann PLL
Postby digi2t » 07 Apr 2013, 06:03
Hi everyone,
I have the great honor of being entrusted with a Schumann PLL for repair. I've also taken the time to trace it. Despite the goop, and rats nest wiring which prevented me from using my camera to trace, I present my hand drawn papers of this piece of vaporware.
Keep in mind that the board drawings are of the trace side, so the IC pin numbers have to be mirrored.
I didn't mention on the board 1 page that the 240R, 120R, 110R, the cut 10K, 1M, 200K, and 150K are metal film. All the others are carbon comp.
I don't get the cut 10K resistor. I triple checked it, and it's as drawn. I suppose that maybe 10K here, and a jumper where the 200K is wasn't cutting it, so he filled it in with solder, and cut the resistor lead. It is what it is.
There's also an Appegiator jack, and a Drone jack, though neither is wired inside. I don't know how the Appegiator would work/connect, and maybe that's what the SIP sockets on board 2 are for. A drone signal could be easily injected though. I've been looking at the Drone Lab II project. Easy build, tunable, and would perform the tasks of the Schumann drone quite well. Not really a blip on the radar right now.
Unless someone beats me to it, I'll be transfering this to TinyCAD soon, and after breadboard verification, to vero thereafter.
This box is something else. :D
No matter how many times I cut it, it`s STILL too short!
For this message the author digi2t has received thanks: 16
chile (22 Jul 2013, 16:25), Dan N (02 Apr 2015, 07:40), Intripped (31 May 2013, 21:23), jonasx26 (07 Apr 2013, 06:31), jrod (08 Apr 2013, 14:28), krome_magnon (15 Apr 2013, 21:13), lohstah (14 Apr 2013, 08:37), modman (02 Jun 2013, 21:08), Nocentelli (07 Apr 2013, 09:44), tp801 (07 Apr 2013, 14:50) and 6 more users
digi2t
Has thanked: 54 times
Have thanks: 347 times
Re: Schumann PLL
Postby jonasx26 » 07 Apr 2013, 06:33
Awesome work! Interesting. Looks like Slacker was correct about the 4017s.
jonasx26
Has thanked: 83 times
Have thanks: 53 times
Re: Schumann PLL
Postby greigoroth » 07 Apr 2013, 19:55
Holy Santa Claus shit!
:applause: :applause: :applause:
greigoroth
Have thanks: 12 times
Re: Schumann PLL
Postby tube-exorcist » 07 Apr 2013, 21:16
I doubt that this is a 74HC14. Running on 12V this chip will not last very long.
Probably it is a 74C14 (which is identical to a CD40106, and which can be replaced by a CD4584).
tube-exorcist
Has thanked: 210 times
Have thanks: 77 times
Re: Schumann PLL
Postby mmolteratx » 07 Apr 2013, 22:40
tube-exorcist wrote:I doubt that this is a 74HC14. Running on 12V this chip will not last very long.
I've seen at least one other Schumann PLL schem where it's a 74HC14. :hmmm: The voltages measured in that were +/-10.3, though that's still well over the 7V max operating voltages.
mmolteratx
Has thanked: 103 times
Have thanks: 627 times
Re: Schumann PLL
Postby digi2t » 08 Apr 2013, 00:16
I've rechecked, with a magnifing glass as well, and it does indeed say "SN74HC14N". I do have 11.47vdc on the Vcc pin as well.
Seems to be a tough chip, to be running at almost double the recommended voltage. :scratch:
digi2t
Re: Schumann PLL
Postby flood » 08 Apr 2013, 07:21
I earlier suspected this unit was based off the never-seen electrax synthax (PDF attached). looks different though...
flood
Have thanks: 17 times
Re: Schumann PLL
Postby jonasx26 » 08 Apr 2013, 13:37
Schematic drawn from digi2t's diagrams. Also looked over by him. Should be reasonably accurate.
For this message the author jonasx26 has received thanks: 11
candidate (30 Oct 2013, 09:04), digi2t (08 Apr 2013, 17:08), FiveseveN (08 Apr 2013, 14:24), flood (14 Apr 2013, 17:53), Intripped (31 May 2013, 21:24), KindaFuzzy (10 Apr 2013, 15:28), krome_magnon (15 Apr 2013, 21:13), mmolteratx (08 Apr 2013, 18:12), modman (02 Jun 2013, 21:10), tp801 (08 Apr 2013, 18:19) and one more user
jonasx26
Re: Schumann PLL
Postby jonasx26 » 08 Apr 2013, 14:17
Correction: Pin 13 of IC7 needs to be grounded for the thing to work.
jonasx26
Re: Schumann PLL
Postby flood » 13 Apr 2013, 11:05
nice work! coincidentally, i was going through this yesterday: http://hammer.ampage.org/files/Marston' ... rcuits.PDF
looks like a straightforward application, except for the fuzz on the front end and the later stages.
flood
Re: Schumann PLL
Postby uncleboko » 13 Apr 2013, 12:34
No compression of input signal which is rather puzzling.
http://www.youtube.com/watch?v=2WdwapX59K8
It sounds dreadful in this demo!
uncleboko
Has thanked: 55 times
Have thanks: 19 times
Re: Schumann PLL
Postby uncleboko » 13 Apr 2013, 13:10
uncleboko wrote:No compression of input signal which is rather puzzling.
I can't edit previous post - I forgot to say that an excellent job has been done.
uncleboko
Re: Schumann PLL
Postby AmpBastler » 13 Apr 2013, 13:19
Hi jonasx26,
nice work :)
I think you missed the "Lag Time Pot" at Pin 11 of cd4046 :wink:
Where did you get the pot values?
AmpBastler
Have thanks: 5 times
Re: Schumann PLL
Postby digi2t » 14 Apr 2013, 03:23
I've taken the liberty of updating the schematic, but I left it at work. :roll:
I have a vero drawn up, doing the back trace tomorrow. I'll post it tomorrow as well.
For this message the author digi2t has received thanks: 2
AmpBastler (14 Apr 2013, 12:26), lohstah (14 Apr 2013, 08:39)
digi2t
Re: Schumann PLL
Postby TubeOrgasmer » 14 Apr 2013, 13:09
Reaaaaaally looking forward to this :popcorn:
TubeOrgasmer
Have thanks: 2 times
Re: Schumann PLL
Postby jonasx26 » 14 Apr 2013, 19:53
All credit goes to digi2t for the trace. I've done nothing but redrawn his diagrams.
Will post a updated schematic. Thought I'd wait for a successful build first though.
Or at least check with digi2t first.
jonasx26
Re: Schumann PLL
Postby digi2t » 15 Apr 2013, 02:36
Updated schematic, and corrected vero are available here;
http://www.aronnelson.com/gallery/main.php/v/digi2t/veros/Schumann+PLL/?g2_GALLERYSID=06f36ea4e1be5531cb0be7d272e49561
Everything is back traced to the original unit.
For this message the author digi2t has received thanks: 3
AmpBastler (15 Apr 2013, 14:01), jonasx26 (15 Apr 2013, 08:57), lohstah (15 Apr 2013, 14:39)
digi2t
Re: Schumann PLL
Postby KindaFuzzy » 15 Apr 2013, 03:26
Well, since the cat's out of the bag I might as well share my trace that I did from a friends unit a little while ago. Was waiting to do a proper digital schematic, but the one here looks the same as mine with a few different resistor and cap values. My buddies unit had no goop, but was the biggest pain in the ass to trace ever. I made a boo boo on the first schematic, the correction is the next pic.
For this message the author KindaFuzzy has received thanks: 4
chile (23 Jul 2013, 01:06), digi2t (16 Apr 2013, 17:55), krome_magnon (15 Apr 2013, 21:14), modman (02 Jun 2013, 21:10)
KindaFuzzy
Has thanked: 106 times
Have thanks: 296 times
Re: Schumann PLL
Postby Greenmachine » 15 Apr 2013, 03:43
Oh-hooo lawdy. Methinks there's gonna be some PLL clones kickin' around sound. Super excited! Thanks guys! :applause:
"[Y]ou want sketchy, dude? I breadboard on a door." -- RnFR, 2011
"This amp is freakin loud, like crazy, I'm going to kill pets loud." -- mich, 2011
Greenmachine
Has thanked: 102 times
Re: Schumann PLL
Postby LaceSensor » 15 Apr 2013, 14:56
Will anyone be working on replacing the 12AC supply for standard 9vDC and charge pump setup?
For this message the author LaceSensor has received thanks:
chankgeez (31 Aug 2013, 15:09)
LaceSensor
Has thanked: 42 times
Have thanks: 246 times
Next
Users browsing this forum: assche, Cigano23, KazTsuno, vanfletg and 16 guests
