Lumpy's Tone Shop - Lemon Drop  [traced]
drewl
Been thanked: 11 times
Post by drewl »
Did a search but didn't find any info on it here.
Anyone ever see one, open it up?
Supposedly it's similiar to the Jellyroll but uses a silicon transistor to drive a FET?
just looking for something different to build.
thanks.
Nocentelli
Has thanked: 1155 times
Been thanked: 954 times
Post by Nocentelli »
drewl wrote:Did a search but didn't find any info on it here.
thanks.
Weird :scratch:
I remember this well, I could have sworn there was a thread - Maybe it was a request that was never fulfilled so got deleted.
Anyway, I really liked the demo and was interested in building a workalike, but never got very far. However, I saved a description of the circuit from Lumpy himself:
Lumpy wrote:The Lemon Drop uses a similar idea as the Peppermill to push a JFET into overdrive,
but it does it differently and I didn't get the idea from the Peppermill either.
If the idea of overdriving a JFET is unique to ROG, then I guess I'm guilty.
The input stage on the Lemon Drop is a BJT, not a MOSFET.
It's practically the same as the 7 Series input stage simply biased for 9V.
Transistor is a BC108B rather than BC107s used in the amp.
As simple as that sounds, it's what makes the pedal sound the way it does.
The JFET is a 2N5457, similar stage setup as the Peppermill,
but that is so basic anyone could come up with that...
The tone control is set up like a range control on a Rangemaster copy.
There were 2 custom versions that were built with the 7 series tone stack.
The original prototype was a little more complex utilizing more features
of the 7 series preamp but it never quite got the sounds of the amp.
I've attached some relevant schems that I used as a starting point.
Nocentelli
[edit]removed ROG peppermill schem - you can get that from ROG website easily[/edit]
Nocentelli
Aha, the thread is over at DIYSB, that's why I can't find it here:
https://www.diystompboxes.com/smfforum/ ... 249.0;wap2
Nocentelli
drewl
Post by drewl »
Thanks.
If I ever get the time I want to build a 7 series preamp to go with some tube power amps I have that are similiar to the 7 series output section.
Someday, before I die :D
I've run Thomas Vox preamps into the power amps and they sound pretty good.
Thanks again.
Nocentelli
No problem: I think the upshot is that the Lemon drop is just a single BC108c stage taken from the 7 series input and adapted for 9v bias, driving a single 2N5457. I couldn't get anything but farty fuzz, but I know nothing about biasing transitors. I'd love it if someone could suggest a suitable bias arrangement for the first BJT stage.
sciencefriction
Post by sciencefriction »
Necro Bump. With Lumpy awol, has anyone thought about giving this circuit another look? Would be fun to build and tweak.
Nocentelli
sciencefriction wrote:....has anyone thought about giving this circuit another look?
If anyone could post gutshots, that would be great.
sciencefriction
I don't own one anymore, but here are some images I found online. Looks to be some variations between them.
MoonWatcher
Has thanked: 40 times
Been thanked: 52 times
Post by MoonWatcher »
sciencefriction wrote:Necro Bump. With Lumpy awol, has anyone thought about giving this circuit another look? Would be fun to build and tweak.
How about starting with a Peppermill, substituting a bjt for q1, and changing component values as needed?
You could always get into the particulars with the tone circuit and biasing a 2n5457 instead of j201 as the tweaking progresses.
While I'm probably wrong, I don't think that q1 plays as big of a sonic role as q2 does. That said, a mosfet will have different gains, and a different input impedance, than a bjt will, so I think those will probably be the most significant differences.
So - depending on how much overdrive comes from the jbt/q1 itself, you could probably just start with any semi-standard configuration. Maybe something like a LPB-1 for the first round of tweaks? Or maybe the booster stage from a Big Muff? Or a silicon Rangemaster variation?
Even though it differs from the Peppermill, it seems like the same basic idea is the same - q1 is driving q2. Most of the "magic" should be happening at q2, I'd think.
Nocentelli
Thanks for the pictures!
It makes sense if we assume it's vero, but I can't figure how the gain pot works:
That assumes the filter is between the two stages, and is a cap blend between the orange cap straight from the collector (under the drawn-on brown wire, presumably > 100n) and the ceramic cap below the BJT (small, 4n7 or something, direct from the large orange cap to the FET gate). That would imply the gain pot involves the far-left electrolytic. That works ok, but I can't then understand why the gain pot would use two separate wires on lugs 2 and 3 AND a "stopper resistor" from lug 1 to ground. I also don't see a resistor from FET gate to ground (would normally be 1M or so, no sign of one).
Schematic in the works
sciencefriction
If they hadn't recently become so hard to get, I would get another. I want to build one and see if I can get it to sound a little looser. There were a couple with a pre-gain knob added, but I've never seen guts for that version. It's a cool build, but yeah, I'm not sure what's going on there either. If one turns up for a good price I'll grab it again.
randalp3000
Been thanked: 14 times
Post by randalp3000 »
New guy here, been lurking/learning for awhile. I've built 20+ tube amps and a dozen or more pedals.
Picked up a ZII last week to try and help this thread along.
Here are a couple picks to help get this moving. I did trace it to the best of my abilities. Could only read one of the electrolytics but measured the rest in circuit with a cap meter. Ceramics are marked 471 and 10J, blue cap is WIMA 3300 100-U, orange cap 4700k, red caps .022uF.
randalp3000
Schematic I came up with. Feel free to double check resistor color codes
ZII Lemon Drop.pdf
(24.67 KiB) Downloaded 815 times
Nocentelli
randalp3000 wrote:Schematic I came up with. Feel free to double check resistor color codes
Excellent work, many thanks! Could you measure the voltage on the drain of the JFET?
randalp3000
Q1
1 4.58vdc
2 .79
3 .2
Q2 JFET
1 4.84
2 .61
3
drewl
Post by drewl »
Very nice, I'll have try it.
ch ra
Post by ch ra »
Hello, I saw there is a newer version of this circuit with a pre-gain, and separate treble and bass pots. Does anyone know how those fit into the posted schematic?
HamishR
Been thanked: 46 times
Post by HamishR »
I have drawn vero layouts for both versions - FWIW I think the 3-knob version sounds better. I added a bias trimmer too. Easy enough to leave out.
