Amptweaker - Tight Metal [traced]
- jymaze
Yep, did not detail the PSU too much. Basically it is like I represented, except it happens multiple times around the board, sometimes with decoupling, sometimes not, sometimes with a resistor to the opamp non-inverting input, sometimes not. It is very random as I see it. I would make one solidly decoupled Vref and use it for all needs. The main 9v is also decoupled with a big 100u cap and a smaller 100n poly cap, it feeds the opamps directly. Then there is a low pass filter (6.8k and 22u) that leads to the voltage point used for all the Vref points. It is a very oversized PSU, but whatever... I can draw it if you really want...
Also, I retraced and found an error around the tight control, so here it is again, correct for now at least: The diodes between the inputs are a little mysterious to me... from the output to the input, fine, but across the inputs... Whatever... Not sure they ever rectify anything, but who knows...
I guess they are just for protection?jymaze wrote:The diodes between the inputs are a little mysterious to me... from the output to the input, fine, but across the inputs... Whatever... Not sure they ever rectify anything, but who knows...
Anyway, thanks for tracing!
- J0K3RX
- Degoop Doctor
I will try to go over it tonight against the board... May make a layout in Sprint if I get ambitious?jymaze wrote:Repost, the bottom of the schematic got cut-out by my scanner. This one is fine:
- J0K3RX
- Degoop Doctor
jymaze wrote:If someone could plug it in a schematic software, it would be nice. I just don't like to do it and I think it is nice to give people the option to participate .
I don't have any simulation software so it's gonna be freestyle for me...
- euronymous0001
http://www.filedropper.com/tightmetal
- J0K3RX
- Degoop Doctor
won't open for me?
- bajaman
- Has thanked: 595 times
- Been thanked: 2058 times
what program opens this .sch file ?
Altium designer just shows a blank page
- bajaman
tried EAGLE - got load error 292 etc.
- euronymous0001
- bajaman
using Eagle 6.40 light
downloaded new file
still getting the same error
downloaded new file
- euronymous0001
- euronymous0001
can't decipher the component connected to lug 3 of the tone pot. can't read if its 33k or 33n
also, the pots might be reversed wired on my eagle file
and not sure diode types
- bajaman
it would be interesting to know what the diodes are - schottky, zeners, ultrafast, general purpose
- coldcraft
I tried a noise gate like that once and was disappointed in its performance. I guess I didn't have enough gain before it.
- coldcraft
as drawn in the eagle schematic, the Gate pot is backwards. The resistance should increase as the gain is turned up.
