Maestro - The Sustainer [schematic]
- analogguru
Up for sale on evilbay:
https://cgi.ebay.com/vintage-MAESTRO-TH ... 240%3A1318
Looks like EH-made..... somebody has more infos or even guts ?
- DiscoFreq
I asked to bid, but I received the sellers reply too late to use the Buy It Now button...
I hope he removes the restrictions because I tried to bid (it was ok for him) but I couldn't...
EffectsDatabase: http://www.effectsdatabase.com
22000 pedals, 4000 brands, 350 brand interviews
NAMM 2016: http://fxdb.org/namm
- modman
- a d m i n
- Has thanked: 4411 times
- Been thanked: 2139 times
Still nothing on this one?
- Greenmachine
- my favorite amplifier: Fender Blackface Deluxe Reverb
- Completed builds: Electra Distortion
Roger Mayer Octavia
Klon Centaur (Bajaman/Soulsonic)
DOD 440 Envelope Filter
MXR Phase 90
DOD FET Preamp
Dallas Arbiter Fuzz Face
Soulsonic Hunny Bunny Overdrive
BYOC Analog Delay
Craig Anderton Headphone Amp
Anderton Mini Amp
Bajaman Real Tube Overdrive
Fender Deluxe 5E3 with Tone Stack Mod.
Fender Princeton 5F2-a
Keen Neovibe
Aquapuss Delay
Anderton AMS-100 Guitar Synth (abandoned)
DOD 280 Compressor
Weird Sound Generator
Beavis Audio Noisy Cricket
80's Rat
ROG Thor
Big Muff
Green Ringer
Shin-Ei Fuzz
MXR Dynacomp
COT50
Really Cheap Compressor - Location: Jersey City, NJ
- Has thanked: 87 times
- Been thanked: 17 times
- Contact:
That board is swimming in goop.
"[Y]ou want sketchy, dude? I breadboard on a door." -- RnFR, 2011
"This amp is freakin loud, like crazy, I'm going to kill pets loud." -- mich, 2011
- theehman
In the process of de-gooping one of these today. So, far I can see the bottom of the PCB and it has (2) transistors and (2) 14-pin ICs.
Ron Neely II
fx schematics and repairs
- toneman
- my favorite amplifier: anything that works
- Completed builds: meatolation, wobolation, ringolation clones, PAiA synths/modulars, dipthonizer clone, MOTM modules, pedal mods and repairs
- Has thanked: 183 times
- Been thanked: 45 times
EHman,
did you get any numbers off the transistors or the ic's yet??
an earlier post of the layout shows 4 transistors(?)
the power connections to the IC's look strange (4139?)
there's another one on ebay now--
https://www.ebay.com/itm/360599747082?s ... 1423.l2649
there's this version of the box and a "big muff" box style, without the slide switch.
which version are you de-gooping?
afn
T
afn
T
Tone-to-the-Bone
- theehman
That's the one I'm degooping.
toneman wrote:EHman,
afn
T
Ron Neely II
- theehman
Not much more to go. The ICs are Fairchild U6A7757393. Couldn't find any info on the interwebs on those. The transistors are 2N5133 and 2N3565.
Ron Neely II
- Dirk_Hendrik
and these are opamps. Dil-"how much"? After which my first impression would be a (LM)393. Tracing the circuit while attempting to draw in a basic opamp stage would verify wether the assumed pinout would lead to a circuit that makes sense.
- theehman
Sounds reasonable. They're 14 pin DIL.Dirk_Hendrik wrote:and these are opamps. Dil-"how much"? After which my first impression would be a (LM)393. Tracing the circuit while attempting to draw in a basic opamp stage would verify wether the assumed pinout would lead to a circuit that makes sense.
Ron Neely II
- grizzlytone
This was my attempt at making sense of the PCB layout presented here: viewtopic.php?f=16&t=3552&hilit=maestro+sustainer.
Without having actually seen the component side I guessed on the use of FET's. This is the SS-3 version though -is this the version you're working on Ron?
So. For what it's worth...
- Maestro SS-3 Sustainer schematic -small and lo-res.bmp (492.05 KiB) Viewed 3205 times
- analogguru
Hows about some pictures ?theehman wrote:Not much more to go. The ICs are Fairchild U6A7757393. Couldn't find any info on the interwebs on those. The transistors are 2N5133 and 2N3565.
- theehman
Have to borrow a camera. Mine's lost somewhere.analogguru wrote:Hows about some pictures ?theehman wrote:Not much more to go. The ICs are Fairchild U6A7757393. Couldn't find any info on the interwebs on those. The transistors are 2N5133 and 2N3565.
grizzlytone: This must be an SS-1. There's only the 2 transistors and no FETs.
Ron Neely II
- toneman
The LM393 is a comparator and usually comes in an 8pin DIP package.
maybe the U6A7757393 is some sore of "house brand"??
hard to draw a schematic when one doesn't know what the opamp package is
Tone-to-the-Bone
- toneman
grizzly,
that blob that Ron has looks like only 1 9V connector
He also said it was in the same box as the ebay unit.
T
T
Tone-to-the-Bone
- theehman
I didn't get the box with the block so I may be wrong on that.toneman wrote:grizzly,
T
Ron Neely II
- grizzlytone
I haven't seen the blob in question. From the pictures that I've seen all three versions used two 9V batteries but it is possible that some of the SS-1's presented on eBay has been upgraded or modified I guess (SS-1 cover and SS-2 innards?). Here's pics of the three versions, notice same version blob in SS-1 and SS-2:theehman wrote:I didn't get the box with the block so I may be wrong on that.toneman wrote:grizzly,
T
SS-1: SS-2: SS-3:
Have you guys seen this?
Obviously AnalogGuru has since it's hosted on his site, but I wanted to post it here in case it helps the conversation.
Sorry, forgot to add, that's the SS-3 according to the ILoveFuzz forum folks.
- grizzlytone
Yep. That's the one PCB layout I was refering to in my post with the guesswork schematic. Thanks for the clarification.Effectsiation wrote:Have you guys seen this?
[ Image ]
