Fulltone - OCD [traced]
- Blues Lyne
The links don't seem to work. They just end up here http://f.defaut.free.fr for me.
- gnognofasciani
He removed the pics , if anyone wants them just pm me
Search button is your friend
- bajaman
- Has thanked: 595 times
- Been thanked: 2056 times
He must have been pressured by Aron or maybe MF had a hissy fit
I always download this stuff double quick - all safe on my drive
- gnognofasciani
http://rapidshare.com/files/96427890/Pappice.zip.html
Save it fast, i don't know how long it will last...
- bajaman
Hey thanks gnognofasciani
At last a hand drawn schematic for the OCD
BUT - Do not try and build it from this schem - it will NOT work.
Take a look at that 10k resistor feeding the non inverting input of the second stage op amp
It should connect to the junction of the preceeding 10k resistor and mosfet/germanium diode clippers, NOT the half rail voltage as it is drawn
Great photos though - more than enough info to create a DIY project from this
https://www.freestompboxes.org/members/b ... matics.jpg
spot the mistakes
spot the mistakes
- gnognofasciani
I didn't have the time to check the schematic drawn by the autor of the photos, but I had the same impression at first look that something was wrong
- gnognofasciani
I was more interested in the components values than the schem itselfgnognofasciani wrote:I didn't have the time to check the schematic drawn by the autor of the photos, but I had the same impression at first look that something was wrong
- Gila_Crisis
are you sure the schem is wrong?
look here: https://s17.photobucket.com/albums/b72/ ... CDv2-1.png
this is another schem found for the OCD, and it looks preatty similar to the one posted above. there's a lovely mess in the part of the schem (the other posted here above) where there are the transistors... but the rest seam look ideantical
I've been watching the discussions over here and decided that now's about time to join in. So, first and foremost: thanks for being such a great platform for DIY-people !!!
I've read somewhere that the OCD is based on the Shaka Bradda III as designed by Aron Nelson. That design uses IRF510 or IRF520 trannies for clipping, while this design uses 2N7000's.
I'm thinking about building something that's based on clipping Mosfets. Anybody have a clue about the sonic differences between these two types of trannies??
Thank U!
BESTEGW
Thank U!
BESTEGW
- bajaman
positiveare you sure the schem is wrong?
check out Markm's photobucket schem - the two 10k resistors
Then tell me that there is no mistake on the hand drawn schem
- Gila_Crisis
then makm's schem is right?
i still must see a schem of this OCD that says Built verified and working like the real one!
- kusi
hi,
markM`s schematic is nearly correct. only one 220k resistor from the second non.inv.input to Vref is missing.
i could post my schematic with the different versions incl. pcb (verified) if someone would like to see it...
regards, kusi
regards, kusi
- gnognofasciani
- gnognofasciani
I think that the 1nF cap in the clipping section could be a 10nF, it would have much more sense...maybe a misreading?
- tuemmueh
yep, there is someone who's interested, especially in the pcb.kusi wrote:hi,
regards, kusi
- Ghandi
@ gnognofasciani,
that 1n cap parallel to the diodes should be a 10n.
@kusi
how is it going?
some friend of us told me that 220K resistor was removed in version3, it gives a bit more dynamics.
ghandi
@kusi
how is it going?
ghandi
Several other differences, R3 should connect to pin 3 of U1A (might not make much of a difference), C7 should be 1nF, and C11 should be 10uF. Other than that it looks pretty close. I've built one of these and have used it on every gig for months now, haven't compared it to a real one but it is the best distortion pedal I've ever heard or used. It sounds exactly like the manufacturer's sound files to me, it especially gets the clarity right. Keep the gain knob at 12 o'clock or lower, higher than that it starts sounding bad. Set the gain at 12 o'clock, and overdrive it's input with a Tube Screamer or other overdrive pedal for a special treat.kusi wrote:hi,
regards, kusi
It's basically a modified Voodoo Labs overdrive with a few tweaks and carefully selected part types (especially cap dielectrics, some of them are a bit out of the ordinary). I'm convinced the tweaking is where the magic lies.
Kusi traced a V1, a bit different from the V2 and V3 circuit.
Maybe there are some transition circuits too and acc. to Fuller all 220p are 330p. I've seen a gutshot of a V4 prototype with asym. clippers and some altered values.
I don't bother about V1, V2, V3, and V4 anymore, 'cos I designed the OCD++ (rev. H) which is able to emulate all the sound of the different versions due to some jumper and other mods. Furthermore I replaced the HP/LP switch with a pot for a continuous blend between the HP and LP mode.
The clarity comes from the mixture of multilayer, tantal and ceramic caps. With Mylar and NF caps it will sound a bit muffled w/o the clarity.
JHS
JHS
