Wampler - Plexi-Drive  [traced]
induction
Has thanked: 61 times
Been thanked: 116 times
Post by induction »
I'll just remind you of this:
indyguitarist wrote:
azrael wrote:bah, I would rather just make different drain resistors, hahaha.
Makes for less work, I think.
That's one way, but it'll change the gains and eq a bit. It won't be an accurate clone.
Nicht Bernd
Has thanked: 98 times
Been thanked: 7 times
Post by Nicht Bernd »
hmmm???? :hmmm:
indyguitarist
Been thanked: 161 times
Post by indyguitarist »
askwho69 wrote:Or just biased it with a potentiometer to 4.5-5v, then measure the potentiometer's value with DMM and put the closest resistor.
Don't do that unless you want it to not sound accurate.
Nicht Bernd
OK, if Indy says so...
induction
Post by induction »
Been playing with this on the breadboard. I bought a bag of 100 J201's from Tayda and sorted them for this and for the Black 65. Out of 100, exactly one biased at 4.7V on the Black 65 (the rest were over 5V), and none biased over 3V on the Plexi-Drive. I don't know if "fake J201's" can explain this, since they bias too high for the Black 65 and too low for the Plexi-Drive. Maybe these circuits favor the outliers, and mine fall right down the middle. Or maybe there's more to it than that, I don't know.
I wondered if there was a way to bias the transistors by connecting the gate resistors to a voltage divider instead of ground and/or swapping both the drain and the source resistors, but nothing I simmed worked out.
Anyway, with a trimpot, I found that 11k drain resistors would get my closest J201's to 4.7V on the Plexi-Drive. I tried both 10k and 12k resistors, and it sounded anemic. I put the original 15k drain resistors back in and it came to life and sounded much, much better. My only complaint was that is sounded a bit muffled, I assume this is because of the mis-biasing, but again, I don't really know. I found that replacing the 25k A tone pot with a 500k A pot brings up the available treble to acceptable levels. With this pot dimed it sounds identical to disconnecting it altogether, and since its just a variable resistor, the lower end of the pot travel gives the same sounds as the 25k pot. I also found the 2n2 cap on the bass switch was too overwhelming, but a 1n cap sounds great.
All in all the modified circuit sounds very nice. I don't know if it sounds identical to the genuine Wampler, but it definitely sounds Marshally, and I'm happy with it.
Just thought I'd share.
batak_man
Has thanked: 15 times
Post by batak_man »
finish build this pedal in breadboard and i like it
have some confuse with this pedal
when i max the gain the vol increase to (to loud)
so if i play with full gain, the vol max at 8 o'clock, more than that the vol to loud (if i compare with clean sound from amp):scratch:
i follow the schema from the earlier page
when i compare to the ori from youtube, the ori plexi not like this
is this normal, or i do some mistake? :scratch: :scratch:
or can someone tell me what should i do? :applause: :applause:
imnotgay
Post by imnotgay »
try audio taper pot
batak_man
Post by batak_man »
imnotgay wrote:try audio taper pot
your mean log pot?
alexradium
Has thanked: 64 times
Been thanked: 68 times
Post by alexradium »
You can't hear exactly through yt.
Anyway the current production plexidrive is not the same as the schematic floating around here.
Plus Mr Sampler has made various revisions of each pedal so what is "right"?
imnotgay
Post by imnotgay »
yep..
batak_man
Post by batak_man »
i see in plexi gutshot has more elect. capacitor
hmm.. i think he use it to boost gain in q1 andq3 (just a stupid guess) :mrgreen:
btw thx for reply :applause:
alexradium
Exactly,that's why maybe it sounds more gainy in videos.
andregarcia57
Has thanked: 74 times
Been thanked: 111 times
Post by andregarcia57 »
J201 of tayda really are not reliable, where they can find good J201 4.5va 5.0v with 15k?
Nocentelli
Has thanked: 1155 times
Been thanked: 954 times
Post by Nocentelli »
That's a big problem with this kind of design: I'd love to build another Velvet fuzz (which has a plexi drive stage) but only three of my 15+ J201s came anywhere near 4.5v with a 15k. I used a 15, 18 and 12k but the rest are useless. I don't fancy buying an expensive big batch to find only a couple of candidates, so I'm seriously thinking about getting a load of SMD and trying them. They're cheap, so if it's a disaster, it's not a waste of too much cash.
andregarcia57
Nocentelli wrote:That's a big problem with this kind of design: I'd love to build another Velvet fuzz (which has a plexi drive stage) but only three of my 15+ J201s came anywhere near 4.5v with a 15k. I used a 15, 18 and 12k but the rest are useless. I don't fancy buying an expensive big batch to find only a couple of candidates, so I'm seriously thinking about getting a load of SMD and trying them. They're cheap, so if it's a disaster, it's not a waste of too much cash.
I'm also seriously considering buying J201 SMD. where to find them Nocentelli?
Nocentelli
I think the parts number is MMBFJ201. They're available at mouser, digikey, farnell and other big electronics parts online places. They don't always appear to be much cheaper than the through-hole types for individual pieces, but you can get 100 for £10 at Mouser [edit - Farnell UK seems to do them for 13p each individually, so it seems well worth hunting around online].
copachino
Post by copachino »
what a horror to work with j201 a have a bag of 30 and only three are close to 4.5-5v, ut im still gated, i ant figure out the problems i use the correct schemactic values, i only change the 220pf cap for a 100pf cap.
Mbas974
Has thanked: 39 times
Been thanked: 40 times
Post by Mbas974 »
Hi ! I built my clone of this wonderfull pedal.
But to my taste it sound really too dark... I'd like to have the Tone pot full open like in 12 o'clock position ( or at least less dark sound )
What I should change ?
induction
Post by induction »
Mbas974 wrote:Hi ! I built my clone of this wonderfull pedal.
Increase the tone pot.
I replaced the 25K tone pot with a 500K A. Works well. Read more here.
jalmonsalmon
Has thanked: 97 times
Been thanked: 30 times
Post by jalmonsalmon »
I am not sure about buying a 100 x SMD 201's since it would be a pain to test them unless I missed something here :hmmm:
I suspect I am being just lazy but I can see me doing it LOL Spend a couple hours soldering those little SMDs on a conversion pcb and then having at it... I have seen a layout for this pedal on IvIark's site that has trimmers for biasing but as stated before, using the trimmers will not yield an accurate clone.
Any one try out SMDs for this one? You would think out of 100 SMD fairchilds, you could get a lot of working jfets vs buying the so called fakes from Tayda... thoughts? :?:
