Secretefx - Secret-1 STD overdrive  [traced]
YuGi
Been thanked: 25 times
Post by YuGi »
Hi all, I dissected the secret-1 pedal. The work is already on the italian forum http://www.fennecelectronics.it, http://www.fennecelectronics.it/smf/ind ... ic=11684.0
The soul of this hobby is sharing informations, so.. my two cents to the community :mrgreen:
As you can see, lot of degooping work :slap:
YuGi
Post by YuGi »
I removed and measured all components. This is the "naked" PCB :D
And finally the schematics :applause:
What you think about? On the other forum we are discussing about in and out buffers.. is not strange that biasing? :scratch:
IvIark
Has thanked: 562 times
Been thanked: 586 times
Post by IvIark »
Thanks for this :applause:
What are the transistors?
YuGi
Post by YuGi »
IvIark wrote:Thanks for this :applause:
All components values are scraped! Then i can only say BJT NPN, hFE around 200.
IvIark
Post by IvIark »
Great, thanks
AAntonio
Has thanked: 19 times
Been thanked: 16 times
Post by AAntonio »
Great!!!!! :applause:
okgb
Has thanked: 226 times
Been thanked: 38 times
Post by okgb »
Nice work , seems to be nothing special is that considered active tone control ?
and funny that those huge caps are even silk screened on the pcb .
Nocentelli
Has thanked: 1155 times
Been thanked: 954 times
Post by Nocentelli »
YuGi wrote:What you think about? On the other forum we are discussing about in and out buffers.. is not strange that biasing? :scratch:
+1
It looks like it's missing a 1M to ground from the base of both BJTs. That would make sense.
IvIark
Post by IvIark »
In the Tubescreamer and similar the base resistor goes to VCC/2
YuGi
Post by YuGi »
+1
The schematics is absolutely correct (I have the PCB on my desktop..).
I simulated the buffers with LTspice and the headroom is better then a classic bjt buffer (bias with 1M to v/2 and 10K emitter resistor). Why?! :scratch:
Cub
Has thanked: 102 times
Been thanked: 118 times
Post by Cub »
I don't remember where, but I saw a demo if it in front of a number of Big Muff pedals and it was a really nice sounding combination.
Thanks for sharing, YuGi ! :thumbsup
smanq
Post by smanq »
It's possible to bias a buffer in this way, but it's definitely the worse one, simply because it's higlhy hfe and temperature related.
A classic 2 resistors partition from supply and ground it's more stable and it permits to use a wide range of transistors (wide range of hfe), without any relevant difference in bias point. It will sound the same... or better (more dinamic, because you can adjust the bias point by design, not trying some different BJTs)!
If we connect the 1M resistor to V/2 like in a classic tube screamer, we've less trouble (less voltage difference across the resistor) and it will bias at good point.
If a circuit works fine from some decades, why we need to change it? :D
pamaz
Has thanked: 32 times
Post by pamaz »
hey smanq, its' exactly what I've written yesterday in the italian forum. We share the same thought.
Cannibal
Has thanked: 27 times
Been thanked: 15 times
Post by Cannibal »
Aside from the buffers, is R5 just a positive feedback resistor? Also the frist opamp max gain is around 500x, so this thing should have a massive amount of distortion going on, instead is just a medium gain overdrive. Am i missing something?
Seiche wrote:there's a difference between being drugged (I don't think it was only booze) and retarded.
IvIark
Post by IvIark »
Here's the vero:
YuGi
Post by YuGi »
Cannibal wrote:Aside from the buffers, is R5 just a positive feedback resistor? Also the frist opamp max gain is around 500x, so this thing should have a massive amount of distortion going on, instead is just a medium gain overdrive. Am i missing something?
The inverting opamp mixes dry and wet so the resulting wave is smootly distorted.
Nick123
Been thanked: 9 times
Post by Nick123 »
Schematic shows that the Gretsch Controfuzz could have been the source of the inspiration.
Mbas974
Has thanked: 39 times
Been thanked: 40 times
Post by Mbas974 »
Please note that IL072 JRC4558 will works but in the original unit the chip is too silent...
we do not know exactly what it is but an OPA will be better choice
Agent86
Been thanked: 13 times
Post by Agent86 »
is similars to Boss OD-1
IvIark
Post by IvIark »
Someone pointed out an error in the layout, the link to pin 2 should be going to pin 3, but I can't edit the post above so here is the updated layout.
